is this the end
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Year and Model: 2001 V70
Has thanked: 930 times
Been thanked: 1005 times
Re: is this the end
Post by volvolugnut »
I believe this is a case (someone correct me if I am wrong) where if the leak is not repaired, the result is only loss of oil and complaints for creating oil slicks. The loss of oil will likely be a predicable rate. With caution you could keep a supply of oil with you and replenish as it leaks. It would be messy where you park (but you could use a pan as suggested) and it would make an oily mess going to the rear from the transmission/ engine. The labor to refill the oil is minimal and the cost of oil acceptable.
