Timing Marks Okay? 94 850 turbo Topic is solved
wyoben
- Year and Model: 1993 940
- Been thanked: 2 times
I'm having a difficult time getting the belt back on...I'm wondering now if I should remove tensioner piston , lace the belt on the pulley's , then re-install tensioner ? .I put the belt on previously ,and it didnt give me near as much resistance ...Oh well ,Onward thru the fog ,and Damn the Torpedoes ,it's just a SMALL iceberg ?
wyoben
Okay , I removed the plastic bushing that gave me enough slack to get belt on ,then weasled the cap back in to its place . I used the 1'' foam block trick as suggested , to be honest ,at first didn't think the material would hold ,but it did !Checked all marks, all looked good even after the 2 revolutions , now the only bullets to sweat out is the PIA water pump W/ no goop on gasket { fingers crossed } ,it's a good thing I replaced it however ,as the original impeller was wearing into its housing , hopefully all will be decent for a while and I can add a 94 white 850 Turbo to the fleet of Sveedish Viking BattleAxe's, next mission will be thermostat and PCV system , after I install a complete new dash ...but that is another Saga in ...Drum Roll Please ' The Revival of Orphaned Sveede's " thanks a MILLION to all my fellow Mathew Minion and Minionette's .I will give a final prognosis if desired .
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
Sometimes Found Objects are just the right stuff. Glad you wrestled it into submission.wyoben wrote: 05 Apr 2021, 14:06 Okay , I removed the plastic bushing that gave me enough slack to get belt on ,then weasled the cap back in to its place . I used the 1'' foam block trick as suggested , to be honest ,at first didn't think the material would hold ,but it did !Checked all marks, all looked good even after the 2 revolutions , now the only bullets to sweat out is the PIA water pump W/ no goop on gasket { fingers crossed } ,it's a good thing I replaced it however ,as the original impeller was wearing into its housing , hopefully all will be decent for a while and I can add a 94 white 850 Turbo to the fleet of Sveedish Viking BattleAxe's, next mission will be thermostat and PCV system , after I install a complete new dash ...but that is another Saga in ...Drum Roll Please ' The Revival of Orphaned Sveede's " thanks a MILLION to all my fellow Mathew Minion and Minionette's .I will give a final prognosis if desired .
wyoben
" It's alive, It's Alive " So far sounds sweet , I havent checked H2O pump for leaks , I'm waiting on T-stat to fill it up w/ coolant ,but ran it briefly and it sounds Sweet-ish !Thanks again to all for the help !
- 1958 Views
Last post by benpineapple
- 10654 Views
Last post by vtl
- 19 Replies
- 1760 Views
Last post by cn90
- 1895 Views
Last post by algopyguy
- 567 Views
Last post by erikv11
