Anybody see this?
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: Anybody see this?
Post by MoVolvos »
It's been around 8 years since changing 2 of those. I do remember the OE differed in design and all 3 differed. I don't remember the OE or the URO collapsing into itself. Since the chugging has started it won't be long for that to get worse. Being the upper mount though a torque mount is also in bad shape it would best to take care of both to reduce the stress on the remaining mounts.
Here are more photos for comparison. That gap is a gap for sure!
https://duckduckgo.com/?q=volvo+right+e ... 434466.jpg
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
Not sure what the chugging is that you guys describe, but I changed the upper Mount. Only took 5 minutes because I didn't have to press it out, just pulled it out by hand. Anyway, the odd noise I could slightly hear is now gone. I will look into changing my other mounts. Are uro ones ok? From what I gather, I have 5 mounts left to address, the rear dogbone mount on the firewall, rear lower left trans mount, front trans torque strut, front engine round mount, and the right engine mount that I pictured earlier.
The rubber mount I just changed out was a Volvo part.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
General advice is don't buy URO brand anything. It's poor quality.
850oldschool
Year and Model: 1996 850 NA
Been thanked: 45 times
Post by 850oldschool »
BlackBart wrote: 12 Apr 2021, 14:33 General advice is don't buy URO brand anything. It's poor quality.
URO rubber products are molded from a proprietary formula whose main ingredients are diesel soot and spit.
BlackBart
Post by BlackBart »
You're more honest than I am!
Has thanked: 1836 times
Been thanked: 1709 times
The lower right mount is probably the most important one so going with a good one is worth paying up for. I have had a couple of aftermarket ones just detach the rubber portion from the metal part they are supposed to be bonded to. That happened as quickly as 6 months!!
Good luck!
MoVolvos
Post by MoVolvos »
befarrer wrote: 12 Apr 2021, 12:47
Not sure what the chugging is that you guys describe... Are uro ones ok? The rubber mount I just changed out was a Volvo part.
The new mount might have help bring the front engine mount position up slightly. The rubber looks a little worn and has sagged. With time it will bottom with subframe making the chugging / knocking noise at idle. Stay away from URO parts.
Didn't know Volvo made Blue Poly Upper Engine Mounts?
MoVolvos
Post by MoVolvos »
scot850 wrote: 12 Apr 2021, 16:29 The lower right mount is probably the most important one so going with a good one is worth paying up for. I have had a couple of aftermarket ones just detach the rubber portion from the metal part they are supposed to be bonded to. That happened as quickly as 6 months!!
Good luck!
I had lifted the URO replacement up with a pry bar and inserted a thick rubber radiator hose underneath to prolong / keep the sagging rubber material from further collapsing. Should have inserted something much stronger to see how much longer the mount would last and if it added any interior vibration?
MoVolvos
Post by MoVolvos »
Don't recall seeing many URO parts on FCP anymore.
Has thanked: 1498 times
Been thanked: 3810 times
MoVolvos wrote: 12 Apr 2021, 16:44
Good luck!
Nice. Instant membership as an honorary Scot.
