Another option for a fresh cable is
having one of the online shops build
one to length for you. The good places
provide high quality cable, connectors and
use a solid, professional crimping machine.
You can usually get these with a good, goop
filled shrink tubing over the connections, too.
A couple extra bucks, but a time saver and
cheap insurance for your charging system.
98 S70 voltage drop? Topic is solved
shegarty
- Year and Model: 1998
- Has thanked: 12 times
- Been thanked: 8 times
I used some marine grade 2awg that I had from another project. I prefer to use soldered lugs instead of crimps. The solder provides some added corrosion prevention insurance. Most corrosion at the terminals is a result of the corrosive gasses produced through charging. Having the solder coat the wire provides an additional layer of corrosion prevention.
98 S70 T5 SE 298k km (daily)
87 740T sedan (current project)
previous - 90 745T; 94 855 T5
- 28 Replies
- 12054 Views
- 1358 Views
Last post by RavagedPheonix
- 21 Replies
- 3252 Views
Last post by MrAl
- 2010 Views
Last post by dj_v70
- 918 Views
Last post by Kags1969
