Hard steering Volvo v70 2006
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Year and Model: 2004 V70 2.5T
Been thanked: 468 times
Re: Hard steering Volvo v70 2006
Post by cn90 »
I am not talking about the fluid, I am talking about the broken pipe inside the PS Reservoir.
Did you check that?
thomas larsen
Year and Model: volvo v70
Post by thomas larsen »
Do you have an picture of it? can i see it with fluid in the reservoir??
Post by cn90 »
- The thread below shows you the "good" bottle and "bad" bottle...
https://volvoforums.com/forum/volvo-s80 ... uid-16276/
- If you need to replace the reservoir, stick to genuine Volvo part.
- If you need to flush it:
1. Search for ATF vs Pentosin
2. No need to run engine.
I did it with engine off, return hose fed into a bottle and wiggle the steering wheel between 11 and 1 o'clock position, very very easy. Please see link below!
viewtopic.php?f=9&t=34745
thomas larsen
Mine dont have that, my hoses goes in and out on the bottom off the bottle.. i did the flush when i changed the pump first time..
Post by cn90 »
As a diagnostic test, try to get a used PS Pump (a known good used PS Pump) and swap to see what happens.
Sometimes you have to use the "process of elimination" to diagnose issues...
OTOH, if you have > 180K-200K miles, not a bad idea to get a new PS Pump and see what happens.
I am not a parts swapper, wasting $, but if you have > 180K-200K miles, then the PS Pump is at the end of its life.
thomas larsen
I have already tried with 2 used one, but with same result..
Post by cn90 »
Then I guess the next culprit is the steering rack. I'd live with the problem for now until it is worse, then replace the steering rack (not a fun job)...
thomas larsen
I was afraid of that, but think i will trie with the lower u joint first, and see if that does it.
Skymongrel
Year and Model: 2023 XC90, S80 2007
Has thanked: 19 times
Been thanked: 19 times
Post by Skymongrel »
Don't know if you resolved this...probably as I see no recent posts. I had this same problem this summer on my 2006 XC70! The steering was variable in stiffness. I really thought I had a steering rack problem. After online research, I tried lubing the u-joint under the steering boot inside the car and it got better then much worst after a day or so. Not sure why.
I replaced that u-joint even though on inspection it looked fine. This solved the problem. Steering is totally fine. You do have to be a contortionist to do this job. Note: I did have a part sourcing problem from an on-line supplier so be careful and look at pictures carefully.
As I recall my u-joint shaft had a recess at one end of the shaft and the sourced part did not, so it did not fit! I actually (cringing here) used a dremel tool and made a recess to get the part to fit. No problems.
thomas larsen
No i have not resolved it yet, i have now got worse, i get stiffness steering, i can turn 1/4 of a turn, then it get stiff, then a little better, and then stiff again. so now i am sure it is a u-joint problem..
the u-joint you changed, is that the one on the steering rack under the boot, or the one inside the car? do you have a picture of the part you changed??
