Stuck upper coolant drain valve
FireFox31
Has thanked: 158 times
Been thanked: 300 times
Re: Stuck upper coolant drain valve
Post by FireFox31 »
abscate wrote: 19 Sep 2021, 04:33 I would give that three hot cool cycles with 20 seconds of propane torch to break that brass steel bond.
Tangential question: Can I use a propane torch on a brake caliper bleed screw, or is the brake fluid flameable? I snapped off my bleed screw, now I must work carefully to remove it.
FireFox31
Has thanked: 1511 times
Been thanked: 3829 times
28 seconds on s brake bleeder screw is a perfect time. Brake fluid won’t ignite inside. Watch out for the hoses and cv boots. Don’t melt them.
If they don’t move after 28 seconds of heat , let them cool for 5 minutes, then reheat.
When they do move , replace them.
kallekula
Year and Model: S70 2000
Has thanked: 58 times
Been thanked: 75 times
Post by kallekula »
Deep creep won that round 😁
BMW 540i 2002
S70 Base 2000
