Adjust Battery Charging Voltage With ECU
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
MrAl wrote: 18 Jan 2022, 18:48 The flooded wet cell lead acid battery idea sounds interesting im not sure how to tell the difference though when you go to buy a new battery. Normally i just look for a battery that is specified for this car.
I doubt many cars specify an AGM battery. If you just go to a battery retailer, an AGM battery will likely advertise that it's an AGM battery since it's typically a fancy schamncy upgrade. It will also be significantly more expensive compared to a lead acid battery of the same Group size.
I know you don't have Menard's, but here is an example... two batteries of the same Group Size, one is AGM and one is the typical lead acid.... the AGM says AGM right on it, and is much more expensive.
https://www.menards.com/main/tools/auto ... 776&ipos=1
https://www.menards.com/main/tools/auto ... 776&ipos=2
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
454cid wrote: 18 Jan 2022, 19:00
Hello again,
Thanks for the info i couldnt find the price on that second battery in the link but i get the general idea and i looked up my battery.
It looks like it actually is a flooded cell type not an AGM but i will verify that when i go out there again.
Going by the pictures i found on the web, my battery top looks exacly like the picture of the one they say is their best non AGM battery and the shape of the top is the same too. Since i did not take a picture of the very front of the battery i can not see the actual part number yet, but i am pretty sure it is the one i found that they specify as non AGM.
So maybe i got the best battery i can get for that car.
What puzzels me yet though is why would the battery manufacturer (Interstate Battery) specify several non AGM batteries for this car and also specify at least one AGM battery (an actual AGM battery) for this car, any ideas? I would think they would know about the slight but significant differences. The difference in price is as you suggested, about $200 USD vs $300 USD for AGM. i did not pay near $300 so it cant be the AGM i would think and the pictures are different too.
454cid
Post by 454cid »
MrAl wrote: 19 Jan 2022, 04:15 Thanks for the info i couldnt find the price on that second battery in the link but i get the general idea and i looked up my battery.
That's weird. It shows up at $189 for the AGM and $114 the regular battery, for me. Maybe it's because I have the local store selected.
The AGM is just a more expensive option, using newer technology, and priced at a premium. When I said not many cars specify an AGM battery, I was meaning specifications by the automaker. The battery companies want to sell their higher priced products, so if they have a more expensive product that will fit, they'll list it in the catalog for the car.
I have not used an AGM battery yet. I usually buy Walmart's upper line lead-acid batteries for my vehicles, and have good success with them. They're aren't very many battery makers, just a lot of brands. Last I knew Walmart's batteries were made by Johnson Controls.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
yanga001
Has thanked: 62 times
Been thanked: 115 times
Post by yanga001 »
MrAl wrote: 19 Jan 2022, 04:15 What puzzels me yet though is why would the battery manufacturer (Interstate Battery) specify several non AGM batteries for this car and also specify at least one AGM battery (an actual AGM battery) for this car, any ideas? I would think they would know about the slight but significant differences. The difference in price is as you suggested, about $200 USD vs $300 USD for AGM. i did not pay near $300 so it cant be the AGM i would think and the pictures are different too.
Manufacturers tend to just list a size and the distributors or dealers have a database that has the car battery size. They usually only check to see if the battery size matches what is listed for the car. This is done in a lot of sectors because of cost and the ICBB or the " I cant be bothered" attitude of certain larger chains and online webstores to look into the specifics.
2008 S60 2.5T Auto (Sold)
MrAl
Post by MrAl »
454cid wrote: 19 Jan 2022, 07:58
Hello again,
Oh ok that makes sense.
I veriified that i do in fact have the non AGM battery. It is written on the top which i had pictures of already but the writing ws in bright yellow on a white background so the camera did not pick it up that well so it was very hard to read. Now that i have a better picture i can see it is the right one.
My battery was actually listed as $175 USD while the AGM wsa listed as $299 that's quite a difference.
So i have the best Interstate battery for this particular car. Now just hope it charges well each time :-)
Everyone says Interstate batteries are very good batteries so i hope that is true. My last battery was actuallly the very same make and model battery and it did last the proclaimed warrenty period and would have probably went longer if i did not have that sensor problem that made the car incredibly hard to start.
