Electrical Problems
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 123 times
- Been thanked: 115 times
I would check the CEM in addition to the DIM. It's possible you have two separate issues. Especially with that plethora of error codes as you mentioned in your other thread. Check this flowchart for troubleshooting : https://xemodex.ca/ca/pdf/DIM%20CEM%20L ... eMODeX.pdf
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I melted/soldered the pins on the ICS, and a couple of other things described in this video, and the gauges and lights work now. However, all the error lights and messages are still present.
2002 v70 X/C 288k miles
- darylrobert
- Year and Model: V70 240 740t xc70
- Has thanked: 6 times
- Been thanked: 42 times
there is a switch in the brake booster servo that i think causes the brake failure warning.
edit: brake pedal position switch. I suggest getting a scan tool or Vida it makes life so much easier
- Has thanked: 1497 times
- Been thanked: 3810 times
You need a DICE interface box which runs from about $100 for a clone to $$$$ for the official one
- 02V70
Do you know where I can get a clone?
Would something like this: https://www.amazon.com/VCI-J2534-Cable-Toyota-Techstream/dp/B097YC5LSR/ref=sr_1_2?crid=3N76RFYZ885JB&keywords=volvo+J2534&qid=1648495449&sprefix=volvoj2534+%2Caps%2C490&sr=8-2 work for scanning and clearing codes?
