I am having trouble finding a clone DiCE. The only one I could find was on aliexpress, and takes over a month to deliver. Would a code reader that says it can read volvo specific codes like this work? Or does VIDA+DICE have some other functionality that I will need?vtl wrote: 22 Mar 2022, 21:40 Ticking noise is ok for these engines. Tappets are loud, injectors are loud, too. Hard to say if the noise is too much, but I don't hear anything immediately abnormal.
Looking at your fresh topics, you need DiCE+VIDA to really take care of this car.
Does my engine sound normal.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
2002 v70 X/C 288k miles
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
In theory, any J2534-compatible reader with two CAN buses implemented in hardware will work. I have a clone of xHorse that I use with Toyota Tundra (I lie: it does not break whatsoever, no need to read anything), VIDA "sees" the scanner, however it has only one CAN bus, so VIDA can't reach a better half of the car. If you find such a dual-bus scanner, it will work with VIDA.
- Has thanked: 311 times
- Been thanked: 817 times
In case you haven't seen it - check this thread for potential alternatives to DiCE: https://www.matthewsvolvosite.com/forum ... hp?t=9656502V70 wrote: 28 Mar 2022, 15:49I am having trouble finding a clone DiCE. The only one I could find was on aliexpress, and takes over a month to deliver. Would a code reader that says it can read volvo specific codes like this work? Or does VIDA+DICE have some other functionality that I will need?vtl wrote: 22 Mar 2022, 21:40 Ticking noise is ok for these engines. Tappets are loud, injectors are loud, too. Hard to say if the noise is too much, but I don't hear anything immediately abnormal.
- 2052 Views
Last post by June
- 13 Replies
- 2709 Views
Last post by befarrer
- 938 Views
- 732 Views
Last post by bmdubya1198
- 261 Views
