Car stalls. Hard start. MAF questions
surfbug1
Year and Model: 1998 V70, 2006 S80
Has thanked: 41 times
Been thanked: 9 times
Re: Car stalls. Hard start. MAF questions
Post by surfbug1 »
misha wrote: 31 Mar 2022, 12:59 Maf or fuel delivery(fuel pump,filter,fuel pump relay).
But...if it runs good with Maf disconnected and not stalling or cutting out...it's bad Maf.
Ok I will check tomorrow.
I did clean the MAF, or do I need to buy a new one
Is this something that has to be Bosch or Volvo, or can I go aftermarket.
And, what about grabbing one out of a wrecking yard?
Al
Got a C3 Corvette corvette for sale? 1968 to 1981...not the 1982 crossfire injection
Ping me!
:D
Has thanked: 1502 times
Been thanked: 3817 times
Bosch or Volvo from a reputable source, not eBay or Amazon. Junkyard part is fine. Look for a wreck
surfbug1
Post by surfbug1 »
Abscate-- thanks
Now question. Can I drive the car with the MAF disconnected, so I can 'test' the theory that the MAF is bad?
How far can I drive it? 20-30 miles?
Will I ruin anything?
Al
Ping me!
:D
surfbug1 wrote: 31 Mar 2022, 21:28 Abscate-- thanks
Al
With the MAF dosconnected the ECU doesn’t get the airflow information so it guesses it based on rpm. It deliberately sends more fuel than design because lean running destroys engines.
In modern cars , several things contribute to the fuel / air mix. Disconnecting the MAF isn’t a good diagnostic procedure since the car defaults to open loop running.
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Al
Abscate hates this as a test for the good reasons he mentioned, but yes you can do it. Disconnect the MAF before starting, not while it is running. You can run it for a half hour that way with zero risk to your engine. 20-30 miles is fine. If running it that way removes all the symptoms, 99% chance the MAF is the problem. On the other hand if it runs like crap with the MAF disconnected then you haven't learned anything. You haven't harmed anything either.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
A junkyard MAF is a cheap swap and it’s not a bad part to have in stock, cheap.
The place it burns you is when you have an induction leak after the math, so called “ unmetered air”
With MAF ON, the air isn’t detected by the MAF so not enough fuel is sent. The engine runs lean and crappy.
Unplugging the MAF the car suddenly runs decently, so you think the MAF is bad. The car runs well because now the ECU sets it to run on rpm and also rich…usually enough to compensate for the air leak.
You bolt in your shiny new $200 MAF… and you are right back to closed loop poor running.
You are now poorer , but wiser.
See the saga of Sir MAF here…
https://www.matthewsvolvosite.com/forum ... se+failure
surfbug1
Post by surfbug1 »
abscate wrote: 01 Apr 2022, 03:06 A junkyard MAF is a cheap swap and it’s not a bad part to have in stock, cheap.
Read thru that, and learned more about Sir MAF
Thanks!
Still working on the issue ....
Al
Ping me!
:D
surfbug1
Post by surfbug1 »
Ok, so I unhooked the MAF. Started right up. Let's see if the CEL comes back (went out for now)
Cel would come on and off for no reason, and wouldn't effect driveability
So, let's see how she runs with the MAF discoed
Funny that cleaning it didn't change anything. (but I just pulled out the element, didn't remove the whole assembly)
Thanks
Al
Ping me!
:D
Post by erikv11 »
Yes, always check for unmetered air (or err!) first. But more often there are codes to send you looking for that (e.g. P0172) when there is unmetered air.
surfbug1 wrote: 01 Apr 2022, 09:26 ...
It's not surprising at all. Unless you can see oil smudge of some kind on the MAF filament, "dirty MAF" is almost never an issue. I harp too much on this one but - MAF cleaner is mostly useless!
'06 S60 R, 197k
surfbug1
Post by surfbug1 »
erikv11 wrote: 02 Apr 2022, 13:26 Yes, always check for unmetered air (or err!) first. But more often there are codes to send you looking for that (e.g. P0172) when there is unmetered air.
Yeah thanks. But had to try!
Do I need to take the whole assembly out to do a throro cleaning?
I have been running it with the MAF disconnected and it is running fine for the last 15 miles or so, about 4 different drive cycles. No issues running it like this , so far
Al
Ping me!
:D
