I recorded about 8 minutes of drive following rpm, throttle position, cam angle unfortunately I didn’t have a load parameter available on my AUTEL. I did half suburban driving then a few minutes hard acceleration to highway speeds
I’ll try to figure out how to port the data here. From the glances I took at the screen, it looks like the VVT only runs on full advance / retard mode and only modulates when running down at no load/ idle
It might be that you need the valve to control the oil pressure at the VVT head over the varying oil pressure on over run and at cold engine temps
1999 ME7 exhaust VVT CAM MAPPING
- Been thanked: 4063 times
- 120 Views
- 3762 Views
Last post by alschnertz
- 6431 Views
Last post by matthew1
- 15 Replies
- 3519 Views
Last post by xHeart
- 5163 Views
Last post by LT South Africa
