Throttle body cleaning issues EPIC Volvo saga...RESOLVED!!
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
The communication missing was NOT with throttle body.
It says "Communication with TCM control module" which is transmission control module.
Nothing I've read so far indicates that there is direct connection b/w CEM and throttle body.
The throttle reports to ECM (engine control module), however having said that the CEM can influence a lot of other systems in the vehicle
sergio
Year and Model: S60 2002
Post by sergio »
Hi to both of you :) :)
Following Mike's suggestion I did call Xemodex.
A technician called me back. I asked how I could have my CEM checked by them.
He said they don't charge for verification! But he wanted me to tell more about the symptoms. I did.
He said that I may not need a new CEM and suggested that using Vidas I should go to;
>Vehicle communication > CEM > Parameters > Immobilizer
He also said that by going trough the steps under "immobilizer" I should see what is wrong.
Here's it is
But I don't fully understand the responses on the right side box.
Do you guys know what I am supposed to understand?
What are the "keys" and "numbers" referring to?
S60 2002 180K miles looks and runs like new (except when sulking)
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
That 10.0v doesn't look good at all.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
precopster
Uncharted territory for me. Jimmy?
DO have at least 12V on the battery before testing so you don't misdiagnose.
There have been 4 keys programmed to the car including the dealer supplied ones upon delivery.
It has to be back to testing power input to the throttle body at the loom and of course checking earth integrity to throttle motor.
sergio
Post by sergio »
It starts with 12+ V then it goes down. Pretty quickly I must say.
precopster
Please see my amended post above
draser
Year and Model: 2005 S60 2.5T
Been thanked: 2 times
Post by draser »
Here are the wiring diag's of TB and pedal sensor.
ETA.pdf
(468.5 KiB) Downloaded 272 times
pedal.pdf
(436.72 KiB) Downloaded 242 times
The TB, or ETA, has a six wire connector going to ECM. Easy continuity check between the two. The pedal or device 7/51 also has a 6 wire conn going to ECM. You can see the batt voltage on pin 1, and ground on pin 3. So you'll have 2 checks: one for continuity (batt disconnected) and one for volts (batt connected) connector plugged in, needle in the back of conn, key on 2.
You should be able to get a pretty good idea of what's going on after these tests. Good luck!
2005 Volvo S60 2.5T, Zimmerman/Akebono brakes
2012 Honda Accord, EBC slotted rotors
sergio
Post by sergio »
Thanks draser
This afternoon I went trough my copy of "electrical volvo 2002_S60_S80.pdf" and printed something to work with. Yours seems different.
Can you have a look at mine and tell me why ETM cables don't end up same place as yours?
Maybe I got the wrong set.
I'm always scared of breaking more things when trying to repair something.
page 38 ETM ECM wiring.pdf
ETM wiring
(60.89 KiB) Downloaded 222 times
precopster
That's because you DON'T have an ETM, which was the pre '02 system made by Magnetti Marelli. You have an ETA made by Bosch
sergio
Post by sergio »
Thank you Mike for the clarification.
I would have been lost in the wrong forest.
