Just did my left side today, I drilled a little plastic to soften it and pulled it out using a homemade tool. (really ugly, but it worked).
It’s easier with wheels off since it’ll has less weight in the arms.RedEyeWalker wrote: ↑08 Oct 2025, 05:50 This is such a great write up!
I'd need to replace my delta link frame mount on the driver's side (left). I'm not touching the delta links this time.
It seems in the pictures that Ozark Lee's car is not jacked up - is it possible to remove and install the mounting bracket with wheels on the ground?
And how would you relieve the stress on the trailing arm and delta link bolt - jack near the link itself or under the spring cup?
If someone has experience in replacing the bracket only and have some pointers that'd be great.
I'm working with hand tools and jack stands.
