Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Mine's a 6 speed manual and 2004, so no CVT issues in sight, just a gearbox that's struggling to keep fluids inside :roll: Gonna have to be careful, it's not an M56, i cant get a spare for 200 bucks :lol:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Goupil wrote: 03 Apr 2024, 14:06 Mine's a 6 speed manual and 2004, so no CVT issues in sight, just a gearbox that's struggling to keep fluids inside :roll: Gonna have to be careful, it's not an M56, i cant get a spare for 200 bucks :lol:
Oooh, you guys got the H6 with a manual over there? That was never an option here in the states, unfortunately.
Goupil
Post by Goupil »
Yeah it got a quite rare manual variant on the Spec B 3.0, took me a while to find a decently priced one in the area !
V70 still jealous, blew off an intercooler hose on the o-nramp today, that was interesting :shock: Managed to just about roll to safety where i got it back where it belongs and drove very carefuly back home :lol:
lionblaze55
Year and Model: 1998 S70 T5
Has thanked: 3 times
Been thanked: 7 times
Post by lionblaze55 »
scot850 wrote: 08 Nov 2023, 17:44 Are you replacing all the cooling lines or just the connection 'O' rings at the radiator?
On the assumption yours is a 98 T5, then does it have the engine oil cooling lines still fitted? The reason is that Robert DIY has suggested replacing the oil cooler thermostats with a blanking plate and doing away with the thermostat al together.
If you plan to continue using the oil cooler and the lines are being replaced the biggest pain is getting to the bolt at the front of the block which is at a slight angle.
The 2nd thing to ensure the oil thermostat holes do not have old oil burnt into the O' ring holes. Carefully scrape any old oil residue out or you are guaranteed to tear the new 'O' rings on fitting the pipes. Also make sure the retaining strip at the thermostat is flat or it allows the pipes to pull out slightly and leak.
I should add:
When fitting the oil cooler lines at the radiator ends, make sure you watch carefully which way around the metal cages are fitted or they will allow the pipes to leak or blow off. Zip-ties around the cages also help if they are being re-used.
Good Luck!
Apologies for pulling this post out of the past, but I never saw the reply! Yes I am now just planning on deleting these lines, I like the results Robert had with his testing of this solution. Got my block off plate ready to go, now just waiting for the oil to get a little more miles on it as I don't like filtering used motor oil out and back in the engine, just feels wrong... :lol:
1998 S70 T5 Turbo - 220k
1998 S70 NA - Totaled at 250k
P80GLT
Has thanked: 154 times
Been thanked: 176 times
Post by P80GLT »
My plan for taking Val for an MOT in better weather never quite went to plan, but at least there was no salt on the roads this year which is a bonus. Storm Kathleen decided to arrive during the night so it was a very wet drive to the MOT station this morning with the temperature at only 2°C
The car had a straight pass with no advisories, then off to visit a mate and then over to East Kilbride to do a Volvo estate thing and fill the boot with freshly powder coated wheels. Back home and the car will need to sit outside until the underside dries off before I put it back in the garage
Some nice beading porn when the car was moved into the MOT station after sitting outside for an hour
1997 850 GLT website
2010 XC90 SE...SOLD
2005 V70 2.5T SE
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
lionblaze55 wrote: 04 Apr 2024, 12:17
I should add:
Good Luck!
Won't be any need for that. At rest it's above the oil level in the pan, so all that would be wasted is anything left in the cooler or lines which isn't part of the base capacity anyways. I was worried about that too until I tried it.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
bmdubya1198
P80GLT wrote: 05 Apr 2024, 05:46 My plan for taking Val for an MOT in better weather never quite went to plan, but at least there was no salt on the roads this year which is a bonus. Storm Kathleen decided to arrive during the night so it was a very wet drive to the MOT station this morning with the temperature at only 2°C
Sorry about the nasty weather, but at least the car looks great!
P80GLT
Post by P80GLT »
Thanks bmdubya1198, the weather's not getting any better and gale force winds forecast for tomorrow so hope it dries off enough to get her inside. In the mean time it's looking like she's going to spend a second night in 4 years outdoors.
2010 XC90 SE...SOLD
2005 V70 2.5T SE
Has thanked: 1850 times
Been thanked: 1711 times
Well look at the bright side, it could be snowing the heavy white kind like it is over here today and for the last couple of days. Forecast for more over the next 2 days before temperature rises back above the 0C mark. Now off in the wet slushy roads to run some errands. I'll leave the car outside as the boss needs to be run somewhere later so no point dragging all the crud into the garage twice!
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
That beading would make for a nice ad for what ever type of wax your using.
1999 V70 GLT
