Vida CEM swapping
AA2020
Year and Model: 2007/ V50
Post by AA2020 »
Hi
P2 working ok, but P1...
08690720 (2005) - Not working
08690722 (2005) - Ok
30728906 (2006) - Ok
30765015 (2007) - Not working
31254903 (2008,2009) - Ok
Last PIN cracker version example 08690720 (2005): Correct PIN : 15 82 06 59 81 62
Not working with any PIN cracker versions, any settings...
Code: Select all
CPU Maximum Frequency:   600000000
CPU Frequency:           600000000
Execution Rate:          600 cycles/us
PIN bytes to measure:    3
Number of samples:       100
CAN low-speed init done.
Reading part number from ECU 0x40 on CAN_LS
CAN_LS ---> ID=000ffffe data=cb 40 b9 f0 00 00 00 00
CAN_LS <--- ID=04301090 data=00 00 00 00 00 00 00 00
CAN_LS <--- ID=09c050b8 data=48 00 02 00 00 00 00 4c
CAN_LS <--- ID=19f010f8 data=80 00 00 00 00 00 05 60
CAN_LS <--- ID=00600005 data=8f 40 f9 f0 00 08 69 07
CAN_LS <--- ID=065373ba data=c4 00 20 e0 1f 00 00 a4
CAN_LS <--- ID=0a90f608 data=08 53 00 00 00 00 00 00
CAN_LS <--- ID=13f041ba data=00 40 1f ff 00 00 00 00
CAN_LS <--- ID=02120498 data=10 00 00 00 00 00 00 00
CAN_LS <--- ID=03c3f7fc data=60 00 00 00 00 20 18 00
CAN_LS <--- ID=00600005 data=09 20 20 20 20 31 26 46
Part Number: 8690720
Searching P/N 8690720 in 49 known CEMs
CAN HS baud rate: 500000
PIN shuffle order: 0 1 2 3 4 5
CAN high-speed init done.
Putting all ECUs into programming mode.
CAN_HS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff 86 00 00 00 00 00 00
Reading part number from ECU 0x50 on CAN_HS
CAN_HS ---> ID=000ffffe data=50 88 00 00 00 00 00 00
CAN_HS <--- ID=00000003 data=50 8e 00 00 08 69 07 20
Initialization done.
Calculating bytes 0-2
1000 pins in 702 ms, 1424 pins/s, average response: 151 us, histogram 75 to 226 us
                   us:   143   144   145   146   147   148   149   150   151   152   153   154   155   156   157   158   159   160   161   162
[ 00 -- -- -- -- -- ]:     0  1138     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1408846; std 381.66
[ 01 -- -- -- -- -- ]:     0  3971     0  1166     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428932; std 386.36
[ 02 -- -- -- -- -- ]:     0  3907     0  1121     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428378; std 381.50
[ 03 -- -- -- -- -- ]:     0  4001     0  1158     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428896; std 382.13
[ 04 -- -- -- -- -- ]:     0  3613     0   980     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1426366; std 372.94
[ 05 -- -- -- -- -- ]:     0  3989     0  1164     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428948; std 384.03
[ 06 -- -- -- -- -- ]:     0  3891     0  1109     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428374; std 383.03
[ 07 -- -- -- -- -- ]:     0  3960     0  1177     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428964; std 384.13
[ 08 -- -- -- -- -- ]:     0  2982     0   731     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1422200; std 361.96
[ 09 -- -- -- -- -- ]:     0  3981     0  1160     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428988; std 385.50
[ 10 -- -- -- -- -- ]:     0  1693     0   224     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1413248; std 369.74
[ 11 -- -- -- -- -- ]:     0  3966     0  1194     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428938; std 381.65
[ 12 -- -- -- -- -- ]:     0  3937     0  1136     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428364; std 376.63
[ 13 -- -- -- -- -- ]:     0  3980     0  1172     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428982; std 381.90
[ 14 -- -- -- -- -- ]:     0  3517     0  1032     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1426262; std 365.61
[ 15 -- -- -- -- -- ]:     0  3474     0  3743     0   945     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446646; std 379.31
[ 16 -- -- -- -- -- ]:     0  3832     0  1159     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1428350; std 379.00
[ 17 -- -- -- -- -- ]:     0  3985     0  1175     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428938; std 383.29
[ 18 -- -- -- -- -- ]:     0  2925     0   764     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1422184; std 357.90
[ 19 -- -- -- -- -- ]:     0  3934     0  1177     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1428928; std 384.31
[ 20 -- -- -- -- -- ]:     0  4008     0  1168     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428988; std 384.15
[ 21 -- -- -- -- -- ]:     0  3411     0  3956     0  1141     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448934; std 383.12
[ 22 -- -- -- -- -- ]:     0  3422     0  3900     0  1138     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448496; std 382.36
[ 23 -- -- -- -- -- ]:     0  3331     0  4036     0  1125     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448862; std 386.04
[ 24 -- -- -- -- -- ]:     0  3503     0  3629     0   995     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446468; std 372.56
[ 25 -- -- -- -- -- ]:     0  3396     0  3946     0  1156     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448818; std 384.12
[ 26 -- -- -- -- -- ]:     0  3361     0  3957     0  1120     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448522; std 380.81
[ 27 -- -- -- -- -- ]:     0  3352     0  3972     0  1156     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448818; std 385.84
[ 28 -- -- -- -- -- ]:     0  3736     0  2982     0   721     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442288; std 362.46
[ 29 -- -- -- -- -- ]:     0  3364     0  3964     0  1151     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448824; std 386.14
[ 30 -- -- -- -- -- ]:     0  3923     0  1750     0   233     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1433308; std 367.93
[ 31 -- -- -- -- -- ]:     0  3356     0  3968     0  1161     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448884; std 383.81
[ 32 -- -- -- -- -- ]:     0  3352     0  3912     0  1150     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448504; std 380.50
[ 33 -- -- -- -- -- ]:     0  3424     0  3904     0  1167     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448830; std 383.64
[ 34 -- -- -- -- -- ]:     0  3545     0  3570     0  1008     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446468; std 374.64
[ 35 -- -- -- -- -- ]:     0  3429     0  3895     0  1175     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448830; std 383.20
[ 36 -- -- -- -- -- ]:     0  3321     0  3897     0  1165     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448452; std 378.72
[ 37 -- -- -- -- -- ]:     0  3382     0  3955     0  1151     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448848; std 384.39
[ 38 -- -- -- -- -- ]:     0  3725     0  2990     0   733     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442272; std 360.34
[ 39 -- -- -- -- -- ]:     0  3406     0  3946     0  1166     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448900; std 384.42
[ 40 -- -- -- -- -- ]:     0  3866     0  1129     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428390; std 381.79
[ 41 -- -- -- -- -- ]:     0  3950     0  1181     0     0     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1429002; std 384.01
[ 42 -- -- -- -- -- ]:     0  3424     0  3868     0  1134     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448438; std 381.60
[ 43 -- -- -- -- -- ]:     0  3358     0  3935     0  1198     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448966; std 382.29
[ 44 -- -- -- -- -- ]:     0  3484     0  3605     0   996     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446404; std 369.20
[ 45 -- -- -- -- -- ]:     0  3395     0  3918     0  1190     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448940; std 382.94
[ 46 -- -- -- -- -- ]:     0  3376     0  3909     0  1124     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448432; std 381.62
[ 47 -- -- -- -- -- ]:     0  3349     0  3971     0  1173     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448966; std 383.77
[ 48 -- -- -- -- -- ]:     0  3615     0  3012     0   730     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1442148; std 357.55
[ 49 -- -- -- -- -- ]:     0  3403     0  3945     0  1178     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448934; std 386.30
[ 50 -- -- -- -- -- ]:     0  4025     0  1690     0   210     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1433256; std 371.84
[ 51 -- -- -- -- -- ]:     0  3338     0  4000     0  1163     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448982; std 384.64
[ 52 -- -- -- -- -- ]:     0  3342     0  3877     0  1150     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448370; std 376.49
[ 53 -- -- -- -- -- ]:     0  3374     0  3970     0  1179     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449060; std 384.75
[ 54 -- -- -- -- -- ]:     0  3461     0  3593     0  1001     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446344; std 370.09
[ 55 -- -- -- -- -- ]:     0  3342     0  3997     0  1165     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449004; std 382.53
[ 56 -- -- -- -- -- ]:     0  3382     0  3908     0  1133     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448438; std 381.38
[ 57 -- -- -- -- -- ]:     0  3359     0  3958     0  1184     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1449008; std 385.73
[ 58 -- -- -- -- -- ]:     0  3646     0  2983     0   744     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1442160; std 357.80
[ 59 -- -- -- -- -- ]:     0  3364     0  3984     0  1164     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448950; std 384.68
[ 60 -- -- -- -- -- ]:     0  3950     0  1181     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428970; std 383.48
[ 61 -- -- -- -- -- ]:     0  3381     0  3953     0  1150     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448838; std 384.35
[ 62 -- -- -- -- -- ]:     0  3416     0  3874     0  1161     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448532; std 383.17
[ 63 -- -- -- -- -- ]:     0  3416     0  3919     0  1170     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448864; std 383.81
[ 64 -- -- -- -- -- ]:     0  3510     0  3592     0  1009     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1446484; std 371.86
[ 65 -- -- -- -- -- ]:     0  3422     0  3939     0  1152     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448880; std 385.20
[ 66 -- -- -- -- -- ]:     0  3372     0  3915     0  1146     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448552; std 381.51
[ 67 -- -- -- -- -- ]:     0  3369     0  3976     0  1140     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448864; std 385.22
[ 68 -- -- -- -- -- ]:     0  3683     0  2985     0   741     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1442282; std 359.64
[ 69 -- -- -- -- -- ]:     0  3411     0  3909     0  1167     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448758; std 380.67
[ 70 -- -- -- -- -- ]:     0  3963     0  1768     0   223     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1433368; std 368.37
[ 71 -- -- -- -- -- ]:     0  3398     0  3958     0  1167     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448930; std 384.64
[ 72 -- -- -- -- -- ]:     0  3366     0  3941     0  1130     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448524; std 382.31
[ 73 -- -- -- -- -- ]:     0  3388     0  3925     0  1173     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448882; std 383.14
[ 74 -- -- -- -- -- ]:     0  3474     0  3618     0  1002     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446646; std 369.73
[ 75 -- -- -- -- -- ]:     0  3364     0  3970     0  1163     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448902; std 381.87
[ 76 -- -- -- -- -- ]:     0  3321     0  3913     0  1152     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448480; std 381.85
[ 77 -- -- -- -- -- ]:     0  3396     0  3964     0  1154     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1448922; std 387.57
[ 78 -- -- -- -- -- ]:     0  3679     0  2986     0   745     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1442254; std 358.77
[ 79 -- -- -- -- -- ]:     0  3327     0  3984     0  1155     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448866; std 383.53
[ 80 -- -- -- -- -- ]:     0  3611     0   999     0     0     0     0     0     0     0     1     0     0     0     0     0     0     0     0 : latency    1426408; std 371.05
[ 81 -- -- -- -- -- ]:     0  3972     0  1175     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428974; std 381.47
[ 82 -- -- -- -- -- ]:     0  3891     0  1136     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428408; std 380.67
[ 83 -- -- -- -- -- ]:     0  4009     0  1166     0     0     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1428982; std 381.67
[ 84 -- -- -- -- -- ]:     0  3501     0  3585     0  1002     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1446366; std 371.11
[ 85 -- -- -- -- -- ]:     0  3369     0  3972     0  1174     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1449014; std 384.60
[ 86 -- -- -- -- -- ]:     0  3393     0  3872     0  1145     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448446; std 378.39
[ 87 -- -- -- -- -- ]:     0  3311     0  4020     0  1152     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448952; std 384.76
[ 88 -- -- -- -- -- ]:     0  3666     0  2960     0   751     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1442152; std 357.61
[ 89 -- -- -- -- -- ]:     0  3308     0  3974     0  1188     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448944; std 382.20
[ 90 -- -- -- -- -- ]:     0  3999     0  1722     0   209     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1433282; std 369.76
[ 91 -- -- -- -- -- ]:     0  3378     0  3953     0  1176     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448916; std 383.65
[ 92 -- -- -- -- -- ]:     0  3383     0  3904     0  1138     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448454; std 381.24
[ 93 -- -- -- -- -- ]:     0  3369     0  3918     0  1199     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448902; std 381.66
[ 94 -- -- -- -- -- ]:     0  3551     0  3551     0  1011     0     0     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1446420; std 371.73
[ 95 -- -- -- -- -- ]:     0  3340     0  3977     0  1176     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448928; std 383.35
[ 96 -- -- -- -- -- ]:     0  3396     0  3850     0  1153     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448424; std 382.13
[ 97 -- -- -- -- -- ]:     0  3365     0  3970     0  1171     0     0     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1448968; std 382.05
[ 98 -- -- -- -- -- ]:     0  3679     0  2955     0   742     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1442134; std 358.47
[ 99 -- -- -- -- -- ]:     0  3396     0  3933     0  1184     0     0     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1448932; std 381.28
best candidates ordered by latency:
0: 53 lat = 1449060
1: 85 lat = 1449014
2: 57 lat = 1449008
3: 55 lat = 1449004
4: 51 lat = 1448982
95: 14 lat = 1426262
96: 08 lat = 1422200
97: 18 lat = 1422184
98: 10 lat = 1413248
99: 00 lat = 1408846
best candidates ordered by std:
0: 77 std = 387.57
1: 01 std = 386.36
2: 49 std = 386.30
3: 29 std = 386.14
4: 23 std = 386.04
95: 98 std = 358.47
96: 18 std = 357.90
97: 58 std = 357.80
98: 88 std = 357.61
99: 48 std = 357.55
lat_k 0-1 0.00%, lat_k 98-99 0.31%, lat_k 0-99 2.85%
std_k 0-1 0.31%, std_k 98-99 0.02%, std_k 0-99 8.40%
pin[0] choose candidate: 53 (latency only)
[ 53 00 -- -- -- -- ]:     0  2764     0  3971     0  2171     0    54     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1454404; std 376.58
[ 53 01 -- -- -- -- ]:     0  1961     0  3975     0  3447     0    80     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460922; std 400.93
[ 53 02 -- -- -- -- ]:     0  1966     0  4055     0  3328     0    88     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460532; std 397.66
[ 53 03 -- -- -- -- ]:     0  1970     0  4019     0  3435     0    74     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460984; std 401.04
[ 53 04 -- -- -- -- ]:     0  2205     0  4060     0  2937     0    76     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1458552; std 387.06
[ 53 05 -- -- -- -- ]:     0  1948     0  3964     0  3442     0    93     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460866; std 397.40
[ 53 06 -- -- -- -- ]:     0  1952     0  4000     0  3362     0    89     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1460534; std 395.80
[ 53 07 -- -- -- -- ]:     0  2357     0  3676     0  2784     0    77     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1456098; std 365.09
[ 53 08 -- -- -- -- ]:     0   971     0  2706     0  3894     0  2200     0    52     0     0     0     0     0     1     0     0     0     0 : latency    1474106; std 371.12
[ 53 09 -- -- -- -- ]:     0   442     0  2004     0  4048     0  3365     0    92     0     0     0     0     0     0     0     1     0     0 : latency    1480912; std 398.10
[ 53 10 -- -- -- -- ]:     0  1570     0  3653     0  3640     0   716     0    13     0     0     0     0     0     0     0     1     0     0 : latency    1465216; std 383.41
[ 53 11 -- -- -- -- ]:     0   432     0  1928     0  4191     0  3324     0    74     0     0     0     0     0     0     0     0     0     1 : latency    1480934; std 407.10
[ 53 12 -- -- -- -- ]:     0   466     0  2014     0  4099     0  3298     0    67     0     0     0     0     0     1     0     0     0     0 : latency    1480508; std 402.47
[ 53 13 -- -- -- -- ]:     0   449     0  1954     0  4093     0  3348     0    95     0     0     0     0     0     0     0     1     0     0 : latency    1480886; std 400.69
[ 53 14 -- -- -- -- ]:     0   626     0  2248     0  4018     0  2918     0    80     0     0     0     0     0     1     0     0     0     0 : latency    1478358; std 384.90
[ 53 15 -- -- -- -- ]:     0   452     0  1931     0  4112     0  3359     0    88     0     0     0     0     0     0     0     1     0     0 : latency    1480928; std 403.91
[ 53 16 -- -- -- -- ]:     0   475     0  2016     0  4068     0  3288     0    83     0     0     0     0     0     1     0     0     0     0 : latency    1480426; std 397.93
[ 53 17 -- -- -- -- ]:     0   482     0  1847     0  4163     0  3362     0    73     0     0     0     0     0     0     0     0     0     1 : latency    1480836; std 403.11
[ 53 18 -- -- -- -- ]:     0   910     0  2717     0  3965     0  2195     0    50     0     0     0     0     0     0     0     1     0     0 : latency    1474382; std 375.33
[ 53 19 -- -- -- -- ]:     0   474     0  1892     0  4019     0  3442     0    85     0     0     0     0     0     0     0     0     0     1 : latency    1480890; std 399.23
[ 53 20 -- -- -- -- ]:     0  1971     0  4051     0  3415     0    81     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1461020; std 401.88
[ 53 21 -- -- -- -- ]:     0   508     0  1852     0  4040     0  3440     0    89     0     0     0     0     0     0     0     1     0     0 : latency    1480938; std 401.61
[ 53 22 -- -- -- -- ]:     0   477     0  2036     0  3975     0  3340     0    93     0     0     0     0     0     0     0     0     0     1 : latency    1480474; std 395.28
[ 53 23 -- -- -- -- ]:     0   436     0  1908     0  4149     0  3351     0    94     0     0     0     0     0     0     0     1     0     0 : latency    1481024; std 403.10
[ 53 24 -- -- -- -- ]:     0   577     0  2322     0  3982     0  2937     0    85     0     0     0     0     0     0     0     1     0     0 : latency    1478556; std 385.78
[ 53 25 -- -- -- -- ]:     0   470     0  1964     0  3956     0  3468     0    80     0     0     0     0     0     0     0     0     0     1 : latency    1480956; std 400.87
[ 53 26 -- -- -- -- ]:     0   503     0  1935     0  4087     0  3304     0    94     0     0     0     0     0     0     0     0     0     1 : latency    1480518; std 397.68
[ 53 27 -- -- -- -- ]:     0   465     0  1940     0  4021     0  3436     0    90     0     0     0     0     0     0     0     0     0     1 : latency    1481222; std 398.38
[ 53 28 -- -- -- -- ]:     0   919     0  2715     0  3952     0  2169     0    52     0     0     0     0     0     0     0     1     0     0 : latency    1474126; std 375.77
[ 53 29 -- -- -- -- ]:     0   465     0  1937     0  4132     0  3340     0    87     0     0     0     0     0     0     0     0     0     1 : latency    1480944; std 402.44
[ 53 30 -- -- -- -- ]:     0  1536     0  3710     0  3572     0   731     0    20     0     0     0     0     0     1     0     0     0     0 : latency    1465180; std 384.45
[ 53 31 -- -- -- -- ]:     0   434     0  1943     0  4139     0  3334     0    89     0     0     0     0     0     0     0     1     0     0 : latency    1480912; std 404.62
[ 53 32 -- -- -- -- ]:     0   462     0  1986     0  4152     0  3235     0    92     0     0     0     0     0     0     0     1     0     0 : latency    1480444; std 401.77
[ 53 33 -- -- -- -- ]:     0   457     0  1893     0  4139     0  3350     0    83     0     0     0     1     0     0     0     0     0     0 : latency    1480820; std 404.10
[ 53 34 -- -- -- -- ]:     0   632     0  2210     0  4053     0  2911     0    74     0     0     0     0     0     0     0     0     0     1 : latency    1478328; std 385.61
[ 53 35 -- -- -- -- ]:     0   428     0  1993     0  4079     0  3365     0    85     0     0     0     0     0     0     0     0     0     1 : latency    1480950; std 403.84
[ 53 36 -- -- -- -- ]:     0   504     0  1968     0  4141     0  3252     0    85     0     0     0     0     0     0     0     0     0     1 : latency    1480472; std 399.58
[ 53 37 -- -- -- -- ]:     0   435     0  2040     0  3970     0  3398     0    93     0     0     0     0     0     0     0     0     0     1 : latency    1480836; std 400.08
[ 53 38 -- -- -- -- ]:     0   876     0  2743     0  3955     0  2201     0    51     0     0     0     0     0     0     0     1     0     0 : latency    1474426; std 375.63
[ 53 39 -- -- -- -- ]:     0   460     0  1983     0  3951     0  3446     0    93     0     0     0     0     0     0     0     1     0     0 : latency    1480928; std 397.77
[ 53 40 -- -- -- -- ]:     0  1998     0  4028     0  3334     0    92     0     0     0     0     0     1     0     0     0     0     0     0 : latency    1460616; std 397.30
[ 53 41 -- -- -- -- ]:     0  1963     0  3916     0  3479     0    83     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1460900; std 399.15
[ 53 42 -- -- -- -- ]:     0   501     0  1973     0  3967     0  3376     0    90     0     0     0     0     0     0     0     0     0     1 : latency    1480486; std 394.87
[ 53 43 -- -- -- -- ]:     0   473     0  1932     0  4056     0  3392     0    94     0     0     0     0     0     0     0     0     0     1 : latency    1480964; std 402.18
[ 53 44 -- -- -- -- ]:     0   618     0  2238     0  4025     0  2954     0    74     0     0     0     0     0     0     0     0     0     1 : latency    1478576; std 386.69
[ 53 45 -- -- -- -- ]:     0   443     0  1982     0  4010     0  3404     0    94     0     0     0     0     0     1     0     0     0     0 : latency    1480918; std 399.12
[ 53 46 -- -- -- -- ]:     0   488     0  1951     0  4089     0  3325     0    76     0     0     0     0     0     0     0     0     0     1 : latency    1480556; std 399.34
[ 53 47 -- -- -- -- ]:     0   431     0  1920     0  4132     0  3370     0    86     0     0     0     0     0     0     0     1     0     0 : latency    1481030; std 403.32
[ 53 48 -- -- -- -- ]:     0   898     0  2753     0  3953     0  2160     0    52     0     0     0     0     0     1     0     0     0     0 : latency    1474168; std 376.96
[ 53 49 -- -- -- -- ]:     0   438     0  1904     0  4208     0  3320     0    77     0     0     0     0     0     0     0     0     0     1 : latency    1480952; std 405.30
[ 53 50 -- -- -- -- ]:     0  1563     0  3642     0  3606     0   739     0    17     0     0     0     0     0     0     0     1     0     0 : latency    1465180; std 380.83
[ 53 51 -- -- -- -- ]:     0   410     0  1948     0  4182     0  3285     0   103     0     0     0     0     0     0     0     1     0     0 : latency    1480882; std 404.92
[ 53 52 -- -- -- -- ]:     0   461     0  2048     0  4026     0  3309     0    86     0     0     0     0     0     1     0     0     0     0 : latency    1480470; std 399.31
[ 53 53 -- -- -- -- ]:     0   440     0  1969     0  4082     0  3353     0    90     0     0     0     0     0     0     0     0     0     1 : latency    1480838; std 402.70
[ 53 54 -- -- -- -- ]:     0   616     0  2228     0  4050     0  2912     0    77     0     0     0     0     0     1     0     0     0     0 : latency    1478382; std 385.96
[ 53 55 -- -- -- -- ]:     0   428     0  1923     0  4199     0  3305     0    90     0     0     0     0     0     0     0     0     0     1 : latency    1480960; std 404.41
[ 53 56 -- -- -- -- ]:     0   485     0  2005     0  4117     0  3264     0    80     0     0     0     0     0     0     0     1     0     0 : latency    1480482; std 399.64
[ 53 57 -- -- -- -- ]:     0   427     0  1973     0  4106     0  3324     0    97     0     0     0     0     0     0     0     1     0     0 : latency    1480812; std 402.78
[ 53 58 -- -- -- -- ]:     0   892     0  2732     0  3980     0  2173     0    57     0     0     0     0     0     0     0     1     0     0 : latency    1474408; std 376.01
[ 53 59 -- -- -- -- ]:     0   474     0  1920     0  4029     0  3407     0    99     0     0     0     0     0     0     0     1     0     0 : latency    1480914; std 400.87
[ 53 60 -- -- -- -- ]:     0  2010     0  4036     0  3402     0    89     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461058; std 401.39
[ 53 61 -- -- -- -- ]:     0   449     0  1888     0  4075     0  3421     0    84     0     0     0     0     0     0     0     1     0     0 : latency    1480974; std 403.52
[ 53 62 -- -- -- -- ]:     0   488     0  2011     0  3959     0  3381     0    83     0     0     0     0     0     0     0     1     0     0 : latency    1480522; std 395.74
[ 53 63 -- -- -- -- ]:     0   470     0  1931     0  4034     0  3425     0    89     0     0     0     0     0     0     0     0     0     1 : latency    1481042; std 400.44
[ 53 64 -- -- -- -- ]:     0   654     0  2173     0  4098     0  2906     0    84     0     0     0     0     0     0     0     1     0     0 : latency    1478548; std 387.31
[ 53 65 -- -- -- -- ]:     0   493     0  1962     0  3972     0  3436     0    90     0     0     0     0     0     0     0     1     0     0 : latency    1480934; std 398.14
[ 53 66 -- -- -- -- ]:     0   501     0  1886     0  4108     0  3314     0    91     0     0     0     0     0     0     0     1     0     0 : latency    1480484; std 398.11
[ 53 67 -- -- -- -- ]:     0   471     0  1869     0  4117     0  3396     0    88     0     0     0     0     0     1     0     0     0     0 : latency    1481042; std 402.46
[ 53 68 -- -- -- -- ]:     0   897     0  2753     0  3914     0  2175     0    55     0     0     0     0     0     1     0     0     0     0 : latency    1474062; std 372.64
[ 53 69 -- -- -- -- ]:     0   412     0  1912     0  4201     0  3317     0    82     0     0     0     0     0     0     0     0     0     1 : latency    1480912; std 404.76
[ 53 70 -- -- -- -- ]:     0  1548     0  3659     0  3628     0   718     0    19     0     0     0     0     0     1     0     0     0     0 : latency    1465246; std 382.71
[ 53 71 -- -- -- -- ]:     0   430     0  1947     0  4158     0  3314     0    98     0     0     0     0     0     0     0     1     0     0 : latency    1480962; std 402.88
[ 53 72 -- -- -- -- ]:     0   491     0  1988     0  4106     0  3276     0    82     0     0     0     0     0     0     0     1     0     0 : latency    1480480; std 399.04
[ 53 73 -- -- -- -- ]:     0   425     0  1981     0  4090     0  3345     0    93     0     0     0     0     0     1     0     0     0     0 : latency    1480874; std 401.03
[ 53 74 -- -- -- -- ]:     0   610     0  2211     0  4056     0  2923     0    67     0     0     0     0     0     0     0     1     0     0 : latency    1478320; std 386.23
[ 53 75 -- -- -- -- ]:     0   438     0  1832     0  4318     0  3253     0    94     0     0     0     0     0     0     0     0     0     1 : latency    1480940; std 409.22
[ 53 76 -- -- -- -- ]:     0   480     0  2012     0  4094     0  3271     0    82     0     0     0     0     0     0     0     0     0     1 : latency    1480438; std 398.66
[ 53 77 -- -- -- -- ]:     0   447     0  1944     0  4075     0  3372     0    88     0     0     0     0     0     0     0     0     0     1 : latency    1480852; std 400.47
[ 53 78 -- -- -- -- ]:     0   913     0  2717     0  3990     0  2159     0    60     0     0     0     0     0     0     0     1     0     0 : latency    1474368; std 375.78
[ 53 79 -- -- -- -- ]:     0   474     0  1947     0  3969     0  3442     0    98     0     0     0     0     0     0     0     0     0     1 : latency    1480946; std 397.67
[ 53 80 -- -- -- -- ]:     0  2287     0  3994     0  2951     0    74     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1458704; std 384.14
[ 53 81 -- -- -- -- ]:     0  1956     0  4017     0  3419     0    99     0     0     0     0     0     0     0     1     0     0     0     0 : latency    1461034; std 401.67
[ 53 82 -- -- -- -- ]:     0  1968     0  4058     0  3337     0    78     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1460542; std 398.41
[ 53 83 -- -- -- -- ]:     0  1934     0  4146     0  3363     0    95     0     0     0     0     0     0     0     0     0     1     0     0 : latency    1461138; std 404.10
[ 53 84 -- -- -- -- ]:     0   650     0  2188     0  4021     0  2957     0    82     0     0     0     0     0     0     0     1     0     0 : latency    1478522; std 387.19
[ 53 85 -- -- -- -- ]:     0   441     0  1884     0  4089     0  3405     0    94     0     0     0     0     0     0     0     0     0     1 : latency    1481006; std 403.41
[ 53 86 -- -- -- -- ]:     0   527     0  1998     0  3963     0  3350     0    97     0     0     0     0     0     0     0     0     0     1 : latency    1480468; std 396.26
[ 53 87 -- -- -- -- ]:     0   436     0  1944     0  4066     0  3383     0   108     0     0     0     0     0     0     0     0     0     1 : latency    1481066; std 402.49
[ 53 88 -- -- -- -- ]:     0   884     0  2714     0  3962     0  2169     0    62     0     0     0     0     0     1     0     0     0     0 : latency    1474212; std 373.71
[ 53 89 -- -- -- -- ]:     0   432     0  1959     0  4101     0  3363     0    84     0     0     0     0     0     0     0     1     0     0 : latency    1480926; std 402.08
[ 53 90 -- -- -- -- ]:     0  1526     0  3647     0  3668     0   704     0    22     0     0     0     0     0     1     0     0     0     0 : latency    1465272; std 383.64
[ 53 91 -- -- -- -- ]:     0   466     0  1903     0  4169     0  3316     0    97     0     0     0     0     0     0     0     0     0     1 : latency    1480930; std 404.66
[ 53 92 -- -- -- -- ]:     0   408     0  2061     0  4092     0  3307     0    58     0     0     0     0     0     0     0     1     0     0 : latency    1480524; std 401.59
[ 53 93 -- -- -- -- ]:     0   461     0  1947     0  4094     0  3366     0    75     0     0     0     0     0     0     0     1     0     0 : latency    1480832; std 401.59
[ 53 94 -- -- -- -- ]:     0   615     0  2255     0  3991     0  2898     0   114     0     0     0     0     0     1     0     0     0     0 : latency    1478384; std 382.27
[ 53 95 -- -- -- -- ]:     0   414     0  1908     0  4176     0  3425     0    11     0     0     0     0     0     0     0     0     0     1 : latency    1480902; std 410.82
[ 53 96 -- -- -- -- ]:     0   437     0  2012     0  4122     0  3204     0   136     0     0     0     0     0     0     0     1     0     0 : latency    1480518; std 396.76
[ 53 97 -- -- -- -- ]:     0   466     0  1833     0  4193     0  3332     0    87     0     0     0     0     0     0     0     0     0     1 : latency    1480814; std 403.00
[ 53 98 -- -- -- -- ]:     0   976     0  2680     0  3912     0  2193     0    75     0     0     0     0     0     0     0     1     0     0 : latency    1474302; std 370.94
[ 53 99 -- -- -- -- ]:     0   444     0  1888     0  4080     0  3387     0   111     0     0     0     0     0     0     0     1     0     0 : latency    1480996; std 401.97
0: 27 lat = 1481222
1: 87 lat = 1481066
2: 63 lat = 1481042
3: 67 lat = 1481042
4: 47 lat = 1481030
95: 02 lat = 1460532
96: 80 lat = 1458704
97: 04 lat = 1458552
98: 07 lat = 1456098
99: 00 lat = 1454404
0: 95 std = 410.82
1: 75 std = 409.22
2: 11 std = 407.10
3: 49 std = 405.30
4: 51 std = 404.92
95: 88 std = 373.71
96: 68 std = 372.64
97: 08 std = 371.12
98: 98 std = 370.94
99: 07 std = 365.09
lat_k 0-1 0.01%, lat_k 98-99 0.12%, lat_k 0-99 1.84%
std_k 0-1 0.39%, std_k 98-99 1.60%, std_k 0-99 12.53%
pin[1] choose candidate: 27 (latency only)
[ 53 27 00 -- -- -- ]:     0   391     0  1436     0  3314     0  3457     0  1344     0    15     0     0     0     0     0     0     0     0 : latency    1487572; std 358.96
[ 53 27 01 -- -- -- ]:     0   150     0   837     0  2763     0  4100     0  2105     0    29     0     0     0     1     0     0     0     0 : latency    1494302; std 382.56
[ 53 27 02 -- -- -- ]:     0   150     0   943     0  2744     0  4014     0  2110     0    18     0     1     0     0     0     0     0     0 : latency    1493842; std 377.39
[ 53 27 03 -- -- -- ]:     0   139     0   899     0  2684     0  4144     0  2083     0    33     0     0     0     0     0     0     0     1 : latency    1494238; std 382.08
[ 53 27 04 -- -- -- ]:     0   206     0  1128     0  2962     0  3834     0  1817     0    29     0     0     0     0     0     1     0     0 : latency    1491764; std 369.27
[ 53 27 05 -- -- -- ]:     0   163     0   826     0  2783     0  4079     0  2105     0    28     0     0     0     0     0     1     0     0 : latency    1494230; std 379.74
[ 53 27 06 -- -- -- ]:     0   171     0   913     0  2765     0  4034     0  2062     0    39     0     1     0     0     0     0     0     0 : latency    1493822; std 377.64
[ 53 27 07 -- -- -- ]:     0   384     0  1322     0  2880     0  3627     0  1677     0    33     0     0     0     0     0     1     0     0 : latency    1489384; std 353.91
[ 53 27 08 -- -- -- ]:     0    37     0   370     0  1472     0  3330     0  3399     0  1361     0    25     0     0     0     0     0     1 : latency    1507582; std 359.82
[ 53 27 09 -- -- -- ]:     0     8     0   142     0   866     0  2763     0  4073     0  2113     0    32     0     0     0     0     0     1 : latency    1514304; std 379.17
[ 53 27 10 -- -- -- ]:     0   114     0   673     0  2338     0  3889     0  2543     0   417     0    12     0     0     0     1     0     0 : latency    1498542; std 367.99
[ 53 27 11 -- -- -- ]:     0    12     0   141     0   888     0  2747     0  4083     0  2098     0    27     0     0     0     1     0     0 : latency    1514160; std 381.07
[ 53 27 12 -- -- -- ]:     0    14     0   162     0   933     0  2778     0  4016     0  2054     0    38     0     0     0     1     0     0 : latency    1513720; std 379.20
[ 53 27 13 -- -- -- ]:     0    16     0   138     0   893     0  2721     0  4103     0  2118     0     7     0     1     0     0     0     0 : latency    1514134; std 382.06
[ 53 27 14 -- -- -- ]:     0    21     0   217     0  1110     0  3011     0  3781     0  1828     0    28     0     0     0     1     0     0 : latency    1511680; std 368.32
[ 53 27 15 -- -- -- ]:     0    16     0   142     0   873     0  2760     0  4101     0  2076     0    27     0     0     0     0     0     0 : latency    1514106; std 381.95
[ 53 27 16 -- -- -- ]:     0    11     0   163     0   914     0  2830     0  4008     0  2030     0    41     0     0     0     0     0     1 : latency    1513698; std 375.65
[ 53 27 17 -- -- -- ]:     0     8     0   137     0   900     0  2730     0  4105     0  2090     0    27     0     0     0     0     0     0 : latency    1514200; std 379.54
[ 53 27 18 -- -- -- ]:     0    42     0   345     0  1516     0  3293     0  3460     0  1322     0    17     0     1     0     0     0     0 : latency    1507488; std 359.20
[ 53 27 19 -- -- -- ]:     0    12     0   139     0   898     0  2760     0  4051     0  2109     0    28     0     0     0     0     0     1 : latency    1514144; std 377.80
[ 53 27 20 -- -- -- ]:     0   135     0   876     0  2813     0  4013     0  2119     0    27     0     0     0     0     0     0     0     1 : latency    1494156; std 377.72
[ 53 27 21 -- -- -- ]:     0    15     0   151     0   887     0  2722     0  4102     0  2094     0    25     0     0     0     0     0     0 : latency    1514118; std 381.10
[ 53 27 22 -- -- -- ]:     0    11     0   160     0   951     0  2772     0  4005     0  2062     0    36     0     1     0     0     0     0 : latency    1513724; std 374.32
[ 53 27 23 -- -- -- ]:     0    19     0   131     0   890     0  2732     0  4114     0  2094     0    17     0     0     0     0     0     0 : latency    1514152; std 380.25
[ 53 27 24 -- -- -- ]:     0    21     0   214     0  1150     0  2965     0  3777     0  1861     0     7     0     0     0     0     0     1 : latency    1511604; std 367.46
[ 53 27 25 -- -- -- ]:     0    16     0   142     0   894     0  2683     0  4152     0  2086     0    24     0     0     0     0     0     1 : latency    1514202; std 380.48
[ 53 27 26 -- -- -- ]:     0    15     0   129     0   974     0  2821     0  3936     0  2089     0    32     0     0     0     0     0     1 : latency    1513718; std 375.41
[ 53 27 27 -- -- -- ]:     0    14     0   146     0   878     0  2774     0  4033     0  2120     0    32     0     0     0     1     0     0 : latency    1514174; std 377.32
[ 53 27 28 -- -- -- ]:     0    49     0   344     0  1505     0  3294     0  3461     0  1333     0     8     0     0     0     0     0     1 : latency    1507460; std 359.28
[ 53 27 29 -- -- -- ]:     0    11     0   145     0   871     0  2760     0  4091     0  2081     0    36     0     0     0     0     0     0 : latency    1514182; std 381.40
[ 53 27 30 -- -- -- ]:     0   117     0   667     0  2346     0  3855     0  2580     0   420     0    10     0     0     0     1     0     0 : latency    1498682; std 365.36
[ 53 27 31 -- -- -- ]:     0    12     0   146     0   862     0  2754     0  4087     0  2108     0    26     0     1     0     0     0     0 : latency    1514224; std 381.67
[ 53 27 32 -- -- -- ]:     0    19     0   169     0   897     0  2764     0  4037     0  2087     0    23     0     0     0     0     0     1 : latency    1513830; std 378.45
[ 53 27 33 -- -- -- ]:     0     8     0   161     0   839     0  2770     0  4086     0  2101     0    34     0     0     0     0     0     1 : latency    1514422; std 377.46
[ 53 27 34 -- -- -- ]:     0    13     0   216     0  1132     0  2949     0  3820     0  1849     0    15     0     0     0     0     0     1 : latency    1511752; std 371.02
[ 53 27 35 -- -- -- ]:     0     7     0   135     0   881     0  2751     0  4097     0  2088     0    34     0     0     0     0     0     0 : latency    1514232; std 383.94
[ 53 27 36 -- -- -- ]:     0    17     0   177     0   855     0  2834     0  4016     0  2066     0    32     0     0     0     0     0     1 : latency    1513830; std 376.83
[ 53 27 37 -- -- -- ]:     0    10     0   136     0   888     0  2744     0  4084     0  2109     0    26     0     0     0     0     0     1 : latency    1514242; std 379.21
[ 53 27 38 -- -- -- ]:     0    37     0   366     0  1498     0  3284     0  3395     0  1403     0    10     0     0     0     0     0     1 : latency    1507610; std 356.20
[ 53 27 39 -- -- -- ]:     0    10     0   151     0   866     0  2723     0  4113     0  2094     0    39     0     0     0     1     0     0 : latency    1514290; std 381.62
[ 53 27 40 -- -- -- ]:     0   173     0   932     0  2730     0  4073     0  2055     0    20     0     1     0     0     0     0     0     0 : latency    1493704; std 378.78
[ 53 27 41 -- -- -- ]:     0   158     0   865     0  2795     0  4056     0  2075     0    41     0     0     0     0     0     1     0     0 : latency    1494120; std 378.16
[ 53 27 42 -- -- -- ]:     0    19     0   168     0   880     0  2827     0  4034     0  2037     0    30     0     0     0     0     0     1 : latency    1513696; std 379.25
[ 53 27 43 -- -- -- ]:     0    10     0   137     0   874     0  2789     0  4051     0  2114     0    22     0     1     0     0     0     0 : latency    1514192; std 379.01
[ 53 27 44 -- -- -- ]:     0    22     0   251     0  1109     0  2906     0  3868     0  1820     0    20     0     0     0     1     0     0 : latency    1511634; std 368.57
[ 53 27 45 -- -- -- ]:     0    13     0   146     0   882     0  2775     0  3998     0  2183     0     0     0     0     0     0     0     1 : latency    1514164; std 375.13
[ 53 27 46 -- -- -- ]:     0    14     0   177     0   924     0  2728     0  4083     0  2048     0    23     0     0     0     0     0     1 : latency    1513718; std 376.84
[ 53 27 47 -- -- -- ]:     0    16     0   147     0   919     0  2719     0  4025     0  2141     0    30     0     0     0     1     0     0 : latency    1514132; std 375.53
[ 53 27 48 -- -- -- ]:     0    57     0   344     0  1484     0  3315     0  3456     0  1322     0    17     0     0     0     0     0     1 : latency    1507462; std 359.41
[ 53 27 49 -- -- -- ]:     0    17     0   147     0   890     0  2717     0  4090     0  2108     0    27     0     0     0     0     0     0 : latency    1514160; std 380.56
[ 53 27 50 -- -- -- ]:     0   130     0   656     0  2323     0  3868     0  2580     0   428     0     5     0     0     0     0     0     1 : latency    1498658; std 365.25
[ 53 27 51 -- -- -- ]:     0    14     0   140     0   856     0  2751     0  4114     0  2104     0    18     0     1     0     0     0     0 : latency    1514254; std 381.03
[ 53 27 52 -- -- -- ]:     0    15     0   130     0   920     0  2769     0  4107     0  2052     0     0     0     0     0     0     0     1 : latency    1513802; std 380.48
[ 53 27 53 -- -- -- ]:     0    16     0   124     0   892     0  2760     0  4052     0  2117     0    36     0     0     0     0     0     1 : latency    1514274; std 378.04
[ 53 27 54 -- -- -- ]:     0    23     0   210     0  1104     0  2949     0  3873     0  1823     0    12     0     0     0     1     0     0 : latency    1511760; std 371.00
[ 53 27 55 -- -- -- ]:     0    10     0   138     0   852     0  2800     0  4072     0  2084     0    40     0     0     0     0     0     0 : latency    1514260; std 381.80
[ 53 27 56 -- -- -- ]:     0    10     0   134     0   951     0  2814     0  3968     0  2070     0    49     0     0     0     1     0     0 : latency    1513864; std 376.23
[ 53 27 57 -- -- -- ]:     0    13     0   126     0   886     0  2760     0  4066     0  2132     0    13     0     0     0     0     0     0 : latency    1514240; std 381.67
[ 53 27 58 -- -- -- ]:     0    46     0   342     0  1518     0  3262     0  3466     0  1342     0    16     0     1     0     0     0     0 : latency    1507534; std 358.24
[ 53 27 59 -- -- -- ]:     0    11     0   145     0   884     0  2719     0  4059     0  2153     0    25     0     0     0     0     0     1 : latency    1514320; std 380.02
[ 53 27 60 -- -- -- ]:     0   147     0   875     0  2732     0  4113     0  2091     0    29     0     0     0     0     0     0     0     1 : latency    1494234; std 379.88
[ 53 27 61 -- -- -- ]:     0    10     0   130     0   889     0  2761     0  4074     0  2100     0    33     0     0     0     0     0     0 : latency    1514252; std 378.99
[ 53 27 62 -- -- -- ]:     0    10     0   135     0   933     0  2787     0  4067     0  2032     0    32     0     0     0     0     0     1 : latency    1513842; std 380.19
[ 53 27 63 -- -- -- ]:     0    11     0   134     0   887     0  2755     0  4046     0  2132     0    31     0     0     0     0     0     1 : latency    1514284; std 380.06
[ 53 27 64 -- -- -- ]:     0    25     0   205     0  1114     0  2957     0  3846     0  1829     0    20     0     0     0     1     0     0 : latency    1511782; std 369.94
[ 53 27 65 -- -- -- ]:     0     6     0   143     0   841     0  2812     0  4060     0  2103     0    31     0     0     0     0     0     1 : latency    1514280; std 382.07
[ 53 27 66 -- -- -- ]:     0    10     0   162     0   916     0  2818     0  3980     0  2080     0    30     0     0     0     0     0     1 : latency    1513774; std 377.11
[ 53 27 67 -- -- -- ]:     0     6     0   136     0   872     0  2782     0  4036     0  2131     0    31     0     0     0     0     0     1 : latency    1514296; std 380.40
[ 53 27 68 -- -- -- ]:     0    52     0   345     0  1477     0  3310     0  3446     0  1351     0    15     0     0     0     0     0     1 : latency    1507594; std 358.99
[ 53 27 69 -- -- -- ]:     0    19     0   152     0   821     0  2791     0  4067     0  2115     0    31     0     0     0     1     0     0 : latency    1514268; std 381.72
[ 53 27 70 -- -- -- ]:     0   112     0   664     0  2365     0  3850     0  2574     0   417     0     4     0     0     0     0     0     1 : latency    1498556; std 365.47
[ 53 27 71 -- -- -- ]:     0    11     0   149     0   880     0  2783     0  4038     0  2107     0    29     0     0     0     1     0     0 : latency    1514116; std 377.67
[ 53 27 72 -- -- -- ]:     0    10     0   169     0   910     0  2771     0  4056     0  2052     0    27     0     0     0     0     0     1 : latency    1513770; std 381.25
[ 53 27 73 -- -- -- ]:     0    11     0   157     0   885     0  2743     0  4074     0  2098     0    29     0     0     0     0     0     1 : latency    1514112; std 378.06
[ 53 27 74 -- -- -- ]:     0    28     0   218     0  1114     0  2947     0  3864     0  1799     0    26     0     0     0     0     0     1 : latency    1511666; std 369.73
[ 53 27 75 -- -- -- ]:     0     7     0   161     0   870     0  2766     0  4057     0  2103     0    32     0     0     0     0     0     0 : latency    1514148; std 380.11
[ 53 27 76 -- -- -- ]:     0    12     0   173     0   909     0  2767     0  4070     0  2037     0    27     0     0     0     0     0     1 : latency    1513712; std 381.51
[ 53 27 77 -- -- -- ]:     0     9     0   154     0   875     0  2743     0  4087     0  2098     0    30     0     0     0     1     0     0 : latency    1514176; std 381.00
[ 53 27 78 -- -- -- ]:     0    47     0   341     0  1514     0  3335     0  3373     0  1363     0    21     0     0     0     1     0     0 : latency    1507484; std 359.53
[ 53 27 79 -- -- -- ]:     0    13     0   142     0   907     0  2763     0  4013     0  2129     0    30     0     0     0     0     0     1 : latency    1514124; std 376.15
[ 53 27 80 -- -- -- ]:     0   219     0  1083     0  3053     0  3762     0  1837     0    23     0     0     0     1     0     0     0     0 : latency    1491710; std 369.08
[ 53 27 81 -- -- -- ]:     0   147     0   886     0  2807     0  3986     0  2126     0    35     0     0     0     0     0     0     0     1 : latency    1494130; std 378.17
[ 53 27 82 -- -- -- ]:     0   150     0   946     0  2784     0  4016     0  2062     0    25     0     0     0     0     0     1     0     0 : latency    1493718; std 377.77
[ 53 27 83 -- -- -- ]:     0   156     0   844     0  2837     0  4005     0  2107     0    34     0     0     0     0     0     0     0     1 : latency    1494112; std 379.67
[ 53 27 84 -- -- -- ]:     0    19     0   227     0  1144     0  2911     0  3847     0  1834     0    14     0     0     0     0     0     1 : latency    1511658; std 368.44
[ 53 27 85 -- -- -- ]:     0     9     0   128     0   927     0  2730     0  4067     0  2102     0    34     0     1     0     0     0     0 : latency    1514184; std 377.68
[ 53 27 86 -- -- -- ]:     0     8     0   164     0   958     0  2715     0  4081     0  2049     0    24     0     0     0     0     0     1 : latency    1513894; std 374.43
[ 53 27 87 -- -- -- ]:     0    12     0   135     0   898     0  2754     0  4075     0  2095     0    27     0     0     0     0     0     1 : latency    1514138; std 380.87
[ 53 27 88 -- -- -- ]:     0    50     0   334     0  1501     0  3329     0  3444     0  1321     0    15     0     0     0     0     0     1 : latency    1507462; std 359.87
[ 53 27 89 -- -- -- ]:     0    19     0   130     0   857     0  2818     0  4055     0  2091     0    26     0     0     0     0     0     0 : latency    1514138; std 381.78
[ 53 27 90 -- -- -- ]:     0   125     0   645     0  2317     0  3913     0  2547     0   431     0     8     0     0     0     1     0     0 : latency    1498674; std 366.52
[ 53 27 91 -- -- -- ]:     0    17     0   145     0   890     0  2687     0  4089     0  2151     0    17     0     0     0     0     0     1 : latency    1514276; std 380.66
[ 53 27 92 -- -- -- ]:     0    17     0   157     0   907     0  2759     0  4082     0  2050     0    23     0     0     0     0     0     1 : latency    1513800; std 382.35
[ 53 27 93 -- -- -- ]:     0    12     0   148     0   860     0  2742     0  4070     0  2139     0    25     0     0     0     1     0     0 : latency    1514314; std 381.02
[ 53 27 94 -- -- -- ]:     0    22     0   213     0  1116     0  2928     0  3884     0  1803     0    30     0     0     0     0     0     1 : latency    1511796; std 370.27
[ 53 27 95 -- -- -- ]:     0    10     0   150     0   848     0  2775     0  4058     0  2127     0    29     0     0     0     0     0     1 : latency    1514304; std 378.96
[ 53 27 96 -- -- -- ]:     0    24     0   135     0   940     0  2764     0  4042     0  2070     0    22     0     0     0     0     0     1 : latency    1513794; std 376.59
[ 53 27 97 -- -- -- ]:     0    18     0   138     0   837     0  2797     0  4067     0  2105     0    34     0     0     0     0     0     1 : latency    1514278; std 381.84
[ 53 27 98 -- -- -- ]:     0    51     0   324     0  1521     0  3318     0  3391     0  1368     0    20     0     0     0     0     0     1 : latency    1507560; std 357.52
[ 53 27 99 -- -- -- ]:     0    11     0   140     0   847     0  2782     0  4090     0  2097     0    28     0     0     0     1     0     0 : latency    1514260; std 382.59
0: 33 lat = 1514422
1: 59 lat = 1514320
2: 93 lat = 1514314
3: 95 lat = 1514304
4: 09 lat = 1514304
95: 40 lat = 1493704
96: 04 lat = 1491764
97: 80 lat = 1491710
98: 07 lat = 1489384
99: 00 lat = 1487572
0: 35 std = 383.94
1: 99 std = 382.59
2: 01 std = 382.56
3: 92 std = 382.35
4: 03 std = 382.08
95: 00 std = 358.96
96: 58 std = 358.24
97: 98 std = 357.52
98: 38 std = 356.20
99: 07 std = 353.91
lat_k 0-1 0.01%, lat_k 98-99 0.12%, lat_k 0-99 1.80%
std_k 0-1 0.35%, std_k 98-99 0.65%, std_k 0-99 8.49%
pin[2] choose candidate: 33 (latency only)
Candidate PIN 53 27 33 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 702 seconds
Progress: 0%..5%..10%..15%..20%..25%..30%..35%..40%..45%..50%..55%..60%..65%..70%..75%..80%..85%..90%..95%..
PIN is NOT cracked in 2809.36 seconds
done
Resetting all ECUs.
CAN_HS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
CAN_LS ---> ID=000ffffe data=ff c8 00 00 00 00 00 00
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
AA2020 wrote: 03 Aug 2021, 03:07 Hi
On the bench or in the cars?
Active
Past
AA2020
Post by AA2020 »
This 08690720 (2005) on the bench, the others CEMs in the car.
31254903 - This CEM needed 2 minutes to get the PIN in the Car or on the bench. :)
08690720 (2005) - XXX (on the bench)
30765015 (2007) - XXX
30765471 (2008) - Ok
31254749 (2010) - XXX
31296881 (2011) - XXX
RickHaleParker
I have another CEM-L on the bench. Part number is 31314468. The correct bytes are B0 = 55, B1 = 20, B2 = 00.
The latest master gets B0 & B1 correct every time but misses B2 every time. B2 selection is inconsistent LAT_ONLY on or off does not matter. Samples = 100.
Dug up some ancient code and it works.
Code: Select all
Candidate PIN 0x55 0x20 0x00 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 657 seconds
Progress: 0%..5%..10%..15%..20%..done
found PIN: 0x85 0x20 0x47 0x55 0x20 0x00
PIN is cracked in 717.98 seconds
Validating PIN
PIN verified.
Done
I attached the old code so you can do a comparison. Maybe something will jump out and byte you.
volvo-cem-cracker-ancient-master.zip
(101.13 KiB) Downloaded 150 times
Active
Past
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
One of the changes is the removal of CPU 180 MHz clock. Try to uncomment this line and run: https://github.com/vtl/volvo-cem-cracke ... .ino#L1031
If it works, your USB power is not sufficient.
RickHaleParker
AA2020 wrote: 03 Aug 2021, 13:13 This 08690720 (2005) on the bench, the others CEMs in the car.
Only one on the bench. That means you have not confirmed your bench setup works ... correct?
Active
Past
RickHaleParker
vtl wrote: 03 Aug 2021, 19:51 One of the changes is the removal of CPU 180 MHz clock. Try to uncomment this line and run: https://github.com/vtl/volvo-cem-cracke ... .ino#L1031
With CPU @ 180 MHz it cracked. To test your theory, I switched back to 600 MHz and used my powered USB hub connected to the 5V 3A output of my bench power supply. At 600 MHz & 15 Watts of USB power capacity, it did not crack got B2 wrong again. I am inclined to think insufficient power is not the issue.
Possible issues:
  • 1. The size of the trace between Vusb and Vin on the back of the Teensy 4.0.
    2. Ripple on the power supply line.
( Voltage drop across the trace as current goes up )
Next I am going to add some test points to the board so I can watch the power supply on the scope as it runs.
Might try a jumper from the Vusb through hole to the to the ( + ) power supply rails on the PCB board. That would give two parallel paths to the rail and lower the resistance.
Active
Past
vtl
Post by vtl »
That's a good data point, Rick, thanks!
@AA2020, could you try locking the CPU to 180 MHz as described above and give it a try on your uncrackable CEMs?
AA2020
Post by AA2020 »
vtl wrote: 03 Aug 2021, 22:24 That's a good data point, Rick, thanks!
Yes, I had tried 180Mhz before. Same problem.
AA2020
Post by AA2020 »
Same problem with CEM cracker last version (180Mhz):
Hardware number 0008690720
Correct PIN: 15 82 06 59 81 62
CEM on bench
CAN L: 60 Ohm
CAN H: 60 Ohm
Code: Select all
CPU Frequency:           180000000
Execution Rate:          180 cycles/us
CAN_LS <--- ID=065373ba data=04 00 20 e0 1f 00 00 24
1000 pins in 703 ms, 1422 pins/s, average response: 145 us, histogram 72 to 217 us
                   us:   137   138   139   140   141   142   143   144   145   146   147   148   149   150   151   152   153   154   155   156
[ 00 -- -- -- -- -- ]:     0  3932     0  1073     0    71     0     0     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1368832; std 392.97
[ 01 -- -- -- -- -- ]:     0  3390     0  3897     0  1110     0    81     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389114; std 387.57
[ 02 -- -- -- -- -- ]:     0  3389     0  3850     0  1091     0    54     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388560; std 385.83
[ 03 -- -- -- -- -- ]:     0  3359     0  3926     0  1103     0    78     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389082; std 385.58
[ 04 -- -- -- -- -- ]:     0  3503     0  3565     0   946     0    59     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1386402; std 381.24
[ 05 -- -- -- -- -- ]:     0  3322     0  3947     0  1118     0    62     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389132; std 388.33
[ 06 -- -- -- -- -- ]:     0  3467     0  3810     0  1069     0    70     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388556; std 386.80
[ 07 -- -- -- -- -- ]:     0  3374     0  3906     0  1123     0    72     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388998; std 392.23
[ 08 -- -- -- -- -- ]:     0  3719     0  2911     0   719     0    47     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1382384; std 367.06
[ 09 -- -- -- -- -- ]:     0  3399     0  3886     0  1143     0    62     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389170; std 388.12
[ 10 -- -- -- -- -- ]:     0  3934     0  1649     0   267     0    14     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1373418; std 373.57
[ 11 -- -- -- -- -- ]:     0  3304     0  3943     0  1122     0    70     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388968; std 391.22
[ 12 -- -- -- -- -- ]:     0  3291     0  3869     0  1105     0    55     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388540; std 380.98
[ 13 -- -- -- -- -- ]:     0  3387     0  3897     0  1139     0    62     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389162; std 385.93
[ 14 -- -- -- -- -- ]:     1  3479     0  3474     0   991     0    55     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1386295; std 377.37
[ 15 -- -- -- -- -- ]:     0  1486     0  3378     0  3729     0  1007     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1406838; std 379.78
[ 16 -- -- -- -- -- ]:     0  3434     0  3769     0  1097     0    81     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388536; std 382.91
[ 17 -- -- -- -- -- ]:     0  3353     0  3918     0  1128     0    70     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388976; std 391.60
[ 18 -- -- -- -- -- ]:     0  3683     0  2879     0   743     0    49     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1382372; std 362.50
[ 19 -- -- -- -- -- ]:     0  3451     0  3862     0  1131     0    70     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389118; std 388.37
[ 20 -- -- -- -- -- ]:     0  3343     0  3928     0  1128     0    67     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389164; std 385.56
[ 21 -- -- -- -- -- ]:     1  1248     0  3425     0  3900     0  1088     0    70     0     0     0     0     0     0     0     0     0     0 : latency    1408825; std 396.02
[ 22 -- -- -- -- -- ]:     0  1249     0  3456     1  3835     0  1090     0    65     0     0     0     0     0     0     0     0     0     0 : latency    1408673; std 389.33
[ 23 -- -- -- -- -- ]:     0  1275     0  3333     0  3982     0  1078     0    67     0     0     0     0     0     0     0     0     0     0 : latency    1409048; std 390.09
[ 24 -- -- -- -- -- ]:     0  1489     0  3498     0  3587     0   941     0    68     0     0     0     0     0     0     0     0     0     0 : latency    1406498; std 381.44
[ 25 -- -- -- -- -- ]:     0  1260     0  3435     0  3853     0  1112     0    75     0     0     0     0     0     0     0     0     0     0 : latency    1409000; std 385.34
[ 26 -- -- -- -- -- ]:     0  1289     0  3384     0  3888     0  1078     0    67     0     0     0     0     0     0     0     0     0     0 : latency    1408706; std 384.76
[ 27 -- -- -- -- -- ]:     0  1283     0  3366     0  3902     1  1113     0    68     0     0     0     0     0     0     0     0     0     0 : latency    1409003; std 389.54
[ 28 -- -- -- -- -- ]:     0  2025     0  3715     0  2918     0   724     0    42     0     0     0     0     0     0     0     0     0     0 : latency    1402316; std 370.70
[ 29 -- -- -- -- -- ]:     0  1295     0  3385     0  3899     0  1089     0    79     0     0     0     0     0     0     0     0     0     0 : latency    1409012; std 388.04
[ 30 -- -- -- -- -- ]:     0  2910     0  3893     0  1675     0   287     0    17     0     0     0     0     0     0     0     0     0     0 : latency    1393490; std 372.11
[ 31 -- -- -- -- -- ]:     0  1276     0  3386     0  3894     0  1108     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1408914; std 392.15
[ 32 -- -- -- -- -- ]:     0  1305     0  3377     0  3856     0  1098     0    67     0     0     0     0     0     0     0     0     0     0 : latency    1408680; std 382.89
[ 33 -- -- -- -- -- ]:     0  1306     0  3409     0  3864     0  1107     0    74     0     0     0     0     0     0     0     0     0     0 : latency    1409012; std 387.61
[ 34 -- -- -- -- -- ]:     0  1498     0  3547     0  3529     0   969     0    58     0     0     0     0     0     0     0     0     0     0 : latency    1406502; std 381.46
[ 35 -- -- -- -- -- ]:     0  1276     0  3409     0  3862     0  1118     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1409020; std 387.10
[ 36 -- -- -- -- -- ]:     0  1355     0  3325     0  3867     0  1097     0    70     0     0     0     0     0     0     0     0     0     0 : latency    1408640; std 383.87
[ 37 -- -- -- -- -- ]:     0  1286     0  3413     0  3859     0  1125     0    67     0     0     0     0     0     0     0     0     0     0 : latency    1409036; std 387.45
[ 38 -- -- -- -- -- ]:     0  1955     0  3699     0  2929     0   735     0    42     0     0     0     0     0     0     0     0     0     0 : latency    1402310; std 368.56
[ 39 -- -- -- -- -- ]:     0  1237     0  3439     0  3872     0  1114     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1409088; std 388.67
[ 40 -- -- -- -- -- ]:     0  3431     0  3839     0  1059     0    74     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388572; std 388.99
[ 41 -- -- -- -- -- ]:     0  3411     0  3863     0  1143     0    69     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389038; std 389.60
[ 42 -- -- -- -- -- ]:     0  1335     0  3427     0  3813     0  1090     0    65     0     0     0     0     0     0     0     0     0     0 : latency    1408620; std 385.70
[ 43 -- -- -- -- -- ]:     0  1269     0  3376     0  3880     0  1150     0    65     0     0     0     0     0     0     0     0     0     0 : latency    1409148; std 386.80
[ 44 -- -- -- -- -- ]:     0  1558     0  3447     0  3594     0   942     0    63     0     0     0     0     0     0     0     0     0     0 : latency    1406588; std 373.66
[ 45 -- -- -- -- -- ]:     0  1263     0  3412     0  3858     0  1137     0    71     0     0     0     0     0     0     0     0     0     0 : latency    1408976; std 391.50
[ 46 -- -- -- -- -- ]:     0  1331     0  3395     0  3862     0  1049     0    82     0     0     0     0     0     0     0     0     0     0 : latency    1408614; std 386.29
[ 47 -- -- -- -- -- ]:     0  1275     0  3366     0  3907     0  1129     0    67     0     0     0     0     0     0     0     0     0     0 : latency    1409150; std 387.80
[ 48 -- -- -- -- -- ]:     0  2019     0  3601     0  2956     0   722     0    49     0     0     0     0     0     0     0     0     0     0 : latency    1402186; std 365.67
[ 49 -- -- -- -- -- ]:     0  1244     0  3404     0  3863     0  1142     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1409116; std 386.65
[ 50 -- -- -- -- -- ]:     0  2956     0  4006     0  1588     0   278     0    14     0     0     0     0     0     0     0     0     0     0 : latency    1393440; std 376.95
[ 51 -- -- -- -- -- ]:     0  1274     0  3322     0  3958     0  1112     0    69     0     0     0     0     0     0     0     0     0     0 : latency    1409018; std 392.81
[ 52 -- -- -- -- -- ]:     0  1353     0  3377     0  3828     0  1079     0    75     0     0     0     0     0     0     0     0     0     0 : latency    1408552; std 381.73
[ 53 -- -- -- -- -- ]:     0  1263     0  3377     0  3919     0  1117     0    76     0     0     0     0     0     0     0     0     0     0 : latency    1409238; std 388.76
[ 54 -- -- -- -- -- ]:     0  1597     0  3458     0  3530     0   968     0    60     0     0     0     0     0     0     0     0     0     0 : latency    1406522; std 374.05
[ 55 -- -- -- -- -- ]:     0  1270     0  3343     0  3940     0  1116     0    70     0     0     0     0     0     0     0     0     0     0 : latency    1409038; std 390.57
[ 56 -- -- -- -- -- ]:     0  1310     0  3401     0  3836     0  1079     0    78     0     0     0     0     0     0     0     0     0     0 : latency    1408622; std 384.97
[ 57 -- -- -- -- -- ]:     0  1266     0  3382     0  3902     0  1120     0    76     0     0     0     0     0     0     0     0     0     0 : latency    1409190; std 388.04
[ 58 -- -- -- -- -- ]:     0  2032     0  3625     0  2927     0   738     0    44     0     0     0     0     0     0     0     0     0     0 : latency    1402174; std 366.11
[ 59 -- -- -- -- -- ]:     0  1247     0  3389     0  3914     0  1118     0    68     0     0     0     0     0     0     0     0     0     0 : latency    1409134; std 388.81
[ 60 -- -- -- -- -- ]:     0  3400     0  3878     0  1135     0    69     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389150; std 387.64
[ 61 -- -- -- -- -- ]:     0  1302     0  3394     0  3886     0  1107     0    68     0     0     0     0     0     0     0     0     0     0 : latency    1409024; std 388.14
[ 62 -- -- -- -- -- ]:     0  1255     0  3441     0  3828     0  1112     0    59     0     0     0     0     0     0     0     0     0     0 : latency    1408566; std 390.71
[ 63 -- -- -- -- -- ]:     0  1258     0  3434     0  3871     0  1100     0    79     0     0     0     0     0     0     0     0     0     0 : latency    1409052; std 388.46
[ 64 -- -- -- -- -- ]:     1  1530     0  3508     0  3534     0   984     0    54     0     0     0     0     0     0     0     0     0     0 : latency    1406658; std 380.39
[ 65 -- -- -- -- -- ]:     0  1264     0  3452     0  3857     0  1108     0    71     0     0     0     0     0     0     0     0     0     0 : latency    1408910; std 393.27
[ 66 -- -- -- -- -- ]:     0  1326     0  3363     0  3856     0  1111     0    63     0     0     0     0     0     0     0     0     0     0 : latency    1408738; std 384.99
[ 67 -- -- -- -- -- ]:     0  1312     0  3395     0  3901     0  1095     0    69     0     0     0     0     0     0     0     0     0     0 : latency    1409044; std 389.17
[ 68 -- -- -- -- -- ]:     0  2022     0  3649     0  2937     0   731     0    49     0     0     0     0     0     0     0     0     0     0 : latency    1402312; std 367.62
[ 69 -- -- -- -- -- ]:     0  1244     0  3434     0  3886     0  1080     0    78     0     0     0     0     0     0     0     0     0     0 : latency    1408940; std 386.65
[ 70 -- -- -- -- -- ]:     0  2867     0  3907     0  1719     0   267     0    16     0     0     0     0     0     0     0     0     0     0 : latency    1393556; std 369.84
[ 71 -- -- -- -- -- ]:     0  1235     0  3411     0  3905     0  1108     0    72     0     0     0     0     0     0     0     0     0     0 : latency    1409110; std 389.10
[ 72 -- -- -- -- -- ]:     0  1295     0  3377     0  3878     0  1077     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1408558; std 390.49
[ 73 -- -- -- -- -- ]:     0  1282     0  3390     0  3880     0  1127     0    64     0     0     0     0     0     0     0     0     0     0 : latency    1409072; std 387.52
[ 74 -- -- -- -- -- ]:     0  1553     0  3513     0  3529     0   973     0    61     0     0     0     0     0     0     0     0     0     0 : latency    1406682; std 376.20
[ 75 -- -- -- -- -- ]:     0  1256     0  3383     0  3908     0  1108     0    71     0     0     0     0     0     0     0     0     0     0 : latency    1408922; std 390.32
[ 76 -- -- -- -- -- ]:     0  1357     0  3328     0  3878     0  1091     0    66     0     0     0     0     0     0     0     0     0     0 : latency    1408660; std 384.76
[ 77 -- -- -- -- -- ]:     0  1258     0  3436     0  3890     0  1098     0    75     0     0     0     0     0     0     0     0     0     0 : latency    1409110; std 389.78
[ 78 -- -- -- -- -- ]:     0  1997     0  3683     0  2923     0   729     0    48     0     0     0     0     0     0     0     0     0     0 : latency    1402430; std 363.65
[ 79 -- -- -- -- -- ]:     0  1298     0  3345     0  3919     0  1108     0    68     0     0     0     0     0     0     0     0     0     0 : latency    1408904; std 389.75
[ 80 -- -- -- -- -- ]:     0  3471     0  3546     0   958     0    68     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1386578; std 374.85
[ 81 -- -- -- -- -- ]:     0  3378     0  3907     0  1117     0    74     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389156; std 385.79
[ 82 -- -- -- -- -- ]:     0  3366     0  3860     0  1082     0    66     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1388452; std 389.48
[ 83 -- -- -- -- -- ]:     0  3321     0  3950     0  1105     0    74     0     0     0     0     0     0     0     0     0     0     0     0 : latency    1389168; std 386.18
[ 84 -- -- -- -- -- ]:     0  1541     0  3511     0  3502     0   984     0    59     0     0     0     0     0     0     0     0     0     0 : latency    1406546; std 372.02
[ 85 -- -- -- -- -- ]:     0  1263     0  3360     0  3931     0  1116     0    72     0     0     0     0     0     0     0     0     0     0 : latency    1409048; std 390.78
[ 86 -- -- -- -- -- ]:     0  1336     0  3414     0  3821     0  1076     0    79     0     0     0     0     0     0     0     0     0     0 : latency    1408634; std 382.97
[ 87 -- -- -- -- -- ]:     0  1268     0  3357     0  3942     0  1130     0    51     0     0     0     0     0     0     0     0     0     0 : latency    1409148; std 389.50
[ 88 -- -- -- -- -- ]:     0  2043     0  3612     0  2942     0   719     0    53     0     0     0     0     0     0     0     0     0     0 : latency    1402330; std 361.54
[ 89 -- -- -- -- -- ]:     0  1301     0  3300     0  3937     0  1128     0    70     0     0     0     0     0     0     0     0     0     0 : latency    1408986; std 390.98
[ 90 -- -- -- -- -- ]:     0  2895     0  3930     0  1694     0   254     0    14     0     0     0     0     0     0     0     0     0     0 : latency    1393472; std 372.23
[ 91 -- -- -- -- -- ]:     0  1245     0  3393     0  3888     0  1126     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1409106; std 385.19
[ 92 -- -- -- -- -- ]:     0  1308     0  3384     0  3850     0  1085     0    73     0     0     0     0     0     0     0     0     0     0 : latency    1408498; std 387.21
[ 93 -- -- -- -- -- ]:     0  1266     0  3386     0  3868     1  1133     0    75     0     0     0     0     0     0     0     0     0     0 : latency    1409091; std 386.23
[ 94 -- -- -- -- -- ]:     0  1513     0  3555     0  3500     0   976     0    59     0     0     0     0     0     0     0     0     0     0 : latency    1406612; std 376.17
[ 95 -- -- -- -- -- ]:     0  1264     0  3357     0  3892     0  1142     0    69     0     0     0     0     0     0     0     0     0     0 : latency    1408970; std 390.70
[ 96 -- -- -- -- -- ]:     0  1381     0  3380     0  3813     0  1107     0    62     0     0     0     0     0     0     0     0     0     0 : latency    1408606; std 386.43
[ 97 -- -- -- -- -- ]:     0  1267     0  3370     0  3898     0  1136     0    68     0     0     0     0     0     0     0     0     0     0 : latency    1409156; std 385.14
[ 98 -- -- -- -- -- ]:     0  2029     0  3668     0  2879     0   753     0    42     0     0     0     0     0     0     0     0     0     0 : latency    1402322; std 361.89
[ 99 -- -- -- -- -- ]:     0  1229     0  3426     0  3862     0  1135     0    72     0     0     0     0     0     0     0     0     0     0 : latency    1408972; std 389.67
0: 53 lat = 1409238
1: 57 lat = 1409190
2: 97 lat = 1409156
3: 47 lat = 1409150
4: 87 lat = 1409148
95: 14 lat = 1386295
96: 08 lat = 1382384
97: 18 lat = 1382372
98: 10 lat = 1373418
99: 00 lat = 1368832
0: 21 std = 396.02
1: 65 std = 393.27
2: 00 std = 392.97
3: 51 std = 392.81
4: 07 std = 392.23
95: 48 std = 365.67
96: 78 std = 363.65
97: 18 std = 362.50
98: 98 std = 361.89
99: 88 std = 361.54
lat_k 0-1 0.00%, lat_k 98-99 0.34%, lat_k 0-99 2.95%
std_k 0-1 0.70%, std_k 98-99 0.10%, std_k 0-99 9.54%
[ 53 00 -- -- -- -- ]:     0   889     0  2758     0  3930     0  2169     0    85     0     0     0     0     0     0     0     0     0     0 : latency    1414580; std 378.99
[ 53 01 -- -- -- -- ]:     0   498     0  1973     0  3963     0  3386     0   133     0     0     0     0     0     0     0     0     0     0 : latency    1421116; std 401.13
[ 53 02 -- -- -- -- ]:     0   488     0  1980     0  4024     0  3292     0   132     0     0     0     0     0     0     0     0     0     0 : latency    1420572; std 404.38
[ 53 03 -- -- -- -- ]:     0   455     0  1966     0  4025     0  3344     0   147     0     0     0     0     0     0     0     0     0     0 : latency    1421174; std 402.41
[ 53 04 -- -- -- -- ]:     0   642     0  2208     0  4034     0  2892     0   127     0     0     0     0     0     0     0     0     0     0 : latency    1418742; std 389.06
[ 53 05 -- -- -- -- ]:     0   492     0  1955     0  3931     0  3420     0   130     0     0     0     0     0     0     0     0     0     0 : latency    1421058; std 400.29
[ 53 06 -- -- -- -- ]:     0   546     0  1955     0  3973     0  3322     0   136     0     0     0     0     0     0     0     0     0     0 : latency    1420572; std 402.26
[ 53 07 -- -- -- -- ]:     0   869     0  2388     0  3646     0  2740     0   124     0     0     0     0     0     0     0     0     0     0 : latency    1416290; std 367.33
[ 53 08 -- -- -- -- ]:     0   165     0   974     0  2709     0  3884     0  2162     0    92     0     0     0     0     0     0     0     0 : latency    1434302; std 374.47
[ 53 09 -- -- -- -- ]:     0    50     0   450     0  2016     0  4008     0  3328     0   144     0     0     0     0     0     0     0     0 : latency    1440956; std 404.11
[ 53 10 -- -- -- -- ]:     0   357     0  1576     1  3637     0  3621     0   725     0    27     0     0     0     0     0     0     0     0 : latency    1425407; std 389.34
[ 53 11 -- -- -- -- ]:     0    47     0   440     0  1945     0  4173     0  3257     0   135     0     0     0     0     0     0     0     0 : latency    1441128; std 409.11
[ 53 12 -- -- -- -- ]:     0    54     0   475     0  2023     0  4098     0  3205     0   139     0     0     0     0     0     0     0     0 : latency    1440544; std 408.16
[ 53 13 -- -- -- -- ]:     0    57     0   462     0  1959     1  4060     0  3331     0   128     0     0     0     0     0     0     0     0 : latency    1441081; std 405.99
[ 53 14 -- -- -- -- ]:     0   101     0   636     0  2250     0  3982     0  2914     0   107     0     0     0     0     0     0     0     0 : latency    1438552; std 388.07
[ 53 15 -- -- -- -- ]:     0    52     0   460     0  1961     0  4075     0  3301     0   148     0     0     0     0     0     0     0     0 : latency    1441126; std 403.30
[ 53 16 -- -- -- -- ]:     0    64     0   486     0  2042     0  4001     0  3267     0   131     0     0     0     0     0     0     0     0 : latency    1440468; std 403.51
[ 53 17 -- -- -- -- ]:     0    69     0   497     0  1855     1  4147     0  3292     0   136     0     0     0     0     0     0     0     0 : latency    1441023; std 406.81
[ 53 18 -- -- -- -- ]:     0   145     0   925     0  2727     0  3909     0  2183     0    91     0     0     0     0     0     0     0     0 : latency    1434574; std 377.08
[ 53 19 -- -- -- -- ]:     0    77     0   494     0  1901     0  3975     0  3417     0   127     0     0     0     0     0     0     0     0 : latency    1440928; std 405.62
[ 53 20 -- -- -- -- ]:     0   436     0  1952     0  4042     0  3362     0   137     0     0     0     0     0     0     0     0     0     0 : latency    1421214; std 403.98
[ 53 21 -- -- -- -- ]:     0    60     0   517     0  1868     0  4017     0  3392     0   138     0     0     0     0     0     0     0     0 : latency    1441134; std 404.04
[ 53 22 -- -- -- -- ]:     0    73     0   483     0  2046     0  3953     0  3306     0   133     0     0     0     0     0     0     0     0 : latency    1440666; std 398.26
[ 53 23 -- -- -- -- ]:     0    57     0   447     0  1933     1  4092     0  3326     0   138     0     0     0     0     0     0     0     0 : latency    1441055; std 411.18
[ 53 24 -- -- -- -- ]:     0    91     0   598     0  2316     0  3941     0  2934     0   115     0     0     0     0     0     0     0     0 : latency    1438748; std 388.48
[ 53 25 -- -- -- -- ]:     0    59     0   479     0  1988     0  3914     0  3420     0   137     0     0     0     0     0     0     0     0 : latency    1441150; std 402.32
[ 53 26 -- -- -- -- ]:     1    74     0   515     0  1959     0  4018     0  3290     0   137     0     0     0     0     0     0     0     0 : latency    1440549; std 405.53
[ 53 27 -- -- -- -- ]:     0    46     0   478     0  1950     0  3995     0  3392     0   137     0     0     0     0     0     0     0     0 : latency    1441260; std 402.73
[ 53 28 -- -- -- -- ]:     0   181     0   921     0  2722     1  3919     0  2159     0    80     0     0     0     0     0     0     0     0 : latency    1434311; std 378.90
[ 53 29 -- -- -- -- ]:     0    37     0   476     0  1939     0  4121     0  3293     0   130     0     0     0     0     0     0     0     0 : latency    1440968; std 407.52
[ 53 30 -- -- -- -- ]:     0   396     0  1545     0  3702     0  3513     0   771     0    29     0     0     0     0     0     0     0     0 : latency    1425372; std 384.50
[ 53 31 -- -- -- -- ]:     0    55     0   447     0  1944     0  4139     0  3273     0   139     0     0     0     0     0     0     0     0 : latency    1441102; std 405.52
[ 53 32 -- -- -- -- ]:     0    64     0   464     0  2017     0  4097     0  3224     0   125     0     0     0     0     0     0     0     0 : latency    1440634; std 402.43
[ 53 33 -- -- -- -- ]:     0    72     0   465     0  1913     1  4120     0  3274     0   148     0     0     0     0     0     0     0     0 : latency    1440857; std 409.76
[ 53 34 -- -- -- -- ]:     0   115     0   641     0  2230     0  4010     0  2883     0   117     0     0     0     0     0     0     0     0 : latency    1438518; std 387.77
[ 53 35 -- -- -- -- ]:     0    44     0   450     0  1983     0  4080     0  3304     0   137     0     0     0     0     0     0     0     0 : latency    1441142; std 404.44
[ 53 36 -- -- -- -- ]:     0    48     0   506     0  1969     0  4136     0  3216     0   119     0     0     0     0     0     0     0     0 : latency    1440510; std 407.67
[ 53 37 -- -- -- -- ]:     0    54     0   446     0  2045     0  3970     0  3337     0   142     0     0     0     0     0     0     0     0 : latency    1441028; std 400.87
[ 53 38 -- -- -- -- ]:     0   162     0   889     0  2753     0  3906     0  2183     0    93     0     0     0     0     0     0     0     0 : latency    1434624; std 375.33
[ 53 39 -- -- -- -- ]:     0    60     0   480     0  1986     0  3912     0  3409     0   146     0     0     0     0     0     0     0     0 : latency    1441126; std 399.35
[ 53 40 -- -- -- -- ]:     0   497     0  2002     0  4025     0  3264     0   150     0     0     0     0     0     0     0     0     0     0 : latency    1420652; std 403.73
[ 53 41 -- -- -- -- ]:     0   523     0  1973     0  3898     0  3409     0   147     0     0     0     0     0     0     0     0     0     0 : latency    1421092; std 398.32
[ 53 42 -- -- -- -- ]:     0    88     0   517     0  1964     0  3961     0  3334     0   133     0     0     0     0     0     0     0     0 : latency    1440684; std 397.88
[ 53 43 -- -- -- -- ]:     0    49     0   485     0  1948     0  4001     0  3380     0   131     0     0     0     0     0     0     0     0 : latency    1441006; std 406.68
[ 53 44 -- -- -- -- ]:     0    78     0   629     0  2233     0  4021     0  2917     0   111     0     0     0     0     0     0     0     0 : latency    1438770; std 390.21
[ 53 45 -- -- -- -- ]:     0    62     0   463     0  1982     0  3975     0  3368     0   145     0     0     0     0     0     0     0     0 : latency    1441116; std 400.96
[ 53 46 -- -- -- -- ]:     0    66     0   495     1  1977     1  4048     0  3273     0   133     0     0     0     0     0     0     0     0 : latency    1440592; std 409.16
[ 53 47 -- -- -- -- ]:     0    54     0   441     0  1945     0  4086     0  3330     0   139     0     0     0     0     0     0     0     0 : latency    1441230; std 405.00
[ 53 48 -- -- -- -- ]:     0   172     0   906     0  2748     0  3945     0  2120     0    93     0     0     0     0     0     0     0     0 : latency    1434358; std 378.00
[ 53 49 -- -- -- -- ]:     0    49     0   454     0  1912     0  4201     0  3240     0   143     0     0     0     0     0     0     0     0 : latency    1441142; std 404.98
[ 53 50 -- -- -- -- ]:     0   384     0  1567     0  3633     1  3559     0   771     0    25     0     0     0     0     0     0     0     0 : latency    1425215; std 390.10
[ 53 51 -- -- -- -- ]:     0    62     0   435     0  1936     0  4139     0  3289     0   131     0     0     0     0     0     0     0     0 : latency    1441080; std 408.17
[ 53 52 -- -- -- -- ]:     0    69     0   457     0  2073     0  3999     0  3250     0   145     0     0     0     0     0     0     0     0 : latency    1440666; std 399.02
[ 53 53 -- -- -- -- ]:     0    59     0   445     0  1981     0  4060     0  3308     0   136     0     0     0     0     0     0     0     0 : latency    1440874; std 409.55
[ 53 54 -- -- -- -- ]:     0   112     0   629     0  2239     0  4011     0  2876     0   127     0     0     0     0     0     0     0     0 : latency    1438574; std 387.72
[ 53 55 -- -- -- -- ]:     0    52     0   440     0  1930     2  4169     0  3261     0   142     0     0     0     0     0     0     0     0 : latency    1441156; std 408.58
[ 53 56 -- -- -- -- ]:     0    41     0   499     0  2014     0  4098     0  3207     0   136     0     0     0     0     0     0     0     0 : latency    1440676; std 401.75
[ 53 57 -- -- -- -- ]:     0    69     0   431     0  1981     0  4085     0  3286     0   139     0     0     0     0     0     0     0     0 : latency    1440852; std 409.96
[ 53 58 -- -- -- -- ]:     0   161     0   903     0  2730     1  3937     0  2169     0    89     0     0     0     0     0     0     0     0 : latency    1434607; std 378.35
[ 53 59 -- -- -- -- ]:     0    63     0   477     0  1930     0  4026     0  3355     0   142     0     0     0     0     0     0     0     0 : latency    1441106; std 402.07
[ 53 60 -- -- -- -- ]:     0   429     0  2013     0  4002     1  3352     0   146     0     0     0     0     0     0     0     0     0     0 : latency    1421097; std 409.05
[ 53 61 -- -- -- -- ]:     0    77     0   461     0  1910     0  4031     0  3368     0   146     0     0     0     0     0     0     0     0 : latency    1441170; std 402.41
[ 53 62 -- -- -- -- ]:     0    71     0   494     0  2025     0  3941     0  3324     0   138     0     0     0     0     0     0     0     0 : latency    1440722; std 399.99
[ 53 63 -- -- -- -- ]:     0    48     0   476     0  1958     1  3984     0  3382     0   145     0     0     0     0     0     0     0     0 : latency    1441085; std 408.06
[ 53 64 -- -- -- -- ]:     0    75     0   669     0  2190     0  4044     0  2892     0   123     0     0     0     0     0     0     0     0 : latency    1438744; std 389.36
[ 53 65 -- -- -- -- ]:     0    45     0   501     0  1985     1  3921     0  3405     0   139     0     0     0     0     0     0     0     0 : latency    1441129; std 401.99
[ 53 66 -- -- -- -- ]:     0    89     0   511     0  1895     0  4086     0  3273     0   137     0     0     0     0     0     0     0     0 : latency    1440684; std 400.75
[ 53 67 -- -- -- -- ]:     0    54     0   476     0  1912     1  4040     0  3375     0   135     0     0     0     0     0     0     0     0 : latency    1441081; std 409.93
[ 53 68 -- -- -- -- ]:     0   180     0   910     0  2757     0  3858     0  2182     0    84     0     0     0     0     0     0     0     0 : latency    1434258; std 374.76
[ 53 69 -- -- -- -- ]:     0    69     0   425     0  1933     0  4162     0  3262     0   144     0     0     0     0     0     0     0     0 : latency    1441114; std 406.04
[ 53 70 -- -- -- -- ]:     0   403     0  1566     0  3645     0  3533     0   790     0    24     0     0     0     0     0     0     0     0 : latency    1425286; std 385.14
[ 53 71 -- -- -- -- ]:     0    48     0   437     0  1955     1  4145     0  3259     0   150     0     0     0     0     0     0     0     0 : latency    1441161; std 407.60
[ 53 72 -- -- -- -- ]:     0    54     0   496     0  2016     0  4066     0  3235     0   132     0     0     0     0     0     0     0     0 : latency    1440678; std 398.95
[ 53 73 -- -- -- -- ]:     0    54     0   444     0  1990     0  4044     0  3329     0   132     0     0     0     0     0     0     0     0 : latency    1441078; std 403.55
[ 53 74 -- -- -- -- ]:     0   128     0   606     0  2225     0  4038     0  2872     0   118     0     0     0     0     0     0     0     0 : latency    1438360; std 393.06
[ 53 75 -- -- -- -- ]:     0    57     0   437     0  1873     1  4244     0  3246     0   132     0     0     0     0     0     0     0     0 : latency    1441135; std 411.20
[ 53 76 -- -- -- -- ]:     0    56     0   497     0  2002     0  4074     0  3237     0   128     0     0     0     0     0     0     0     0 : latency    1440640; std 403.44
[ 53 77 -- -- -- -- ]:     0    67     0   459     0  1962     0  4014     0  3360     0   129     0     0     0     0     0     0     0     0 : latency    1440896; std 406.69
[ 53 78 -- -- -- -- ]:     0   150     0   928     0  2752     0  3880     0  2184     0    95     0     0     0     0     0     0     0     0 : latency    1434572; std 376.38
[ 53 79 -- -- -- -- ]:     0    71     0   474     0  1970     0  3931     0  3408     0   144     0     0     0     0     0     0     0     0 : latency    1441146; std 399.99
[ 53 80 -- -- -- -- ]:     0   630     0  2277     0  3977     0  2914     0   117     0     0     0     0     0     0     0     0     0     0 : latency    1418592; std 393.12
[ 53 81 -- -- -- -- ]:     0   460     0  1958     0  3973     0  3419     0   126     0     0     0     0     0     0     0     0     0     0 : latency    1421226; std 402.91
[ 53 82 -- -- -- -- ]:     0   496     0  1972     0  4031     0  3282     0   139     0     0     0     0     0     0     0     0     0     0 : latency    1420738; std 399.83
[ 53 83 -- -- -- -- ]:     0   403     0  1941     0  4152     0  3284     0   155     0     0     0     0     0     0     0     0     0     0 : latency    1421326; std 406.68
[ 53 84 -- -- -- -- ]:     0    95     0   658     0  2213     0  3972     0  2927     0   126     0     0     0     0     0     0     0     0 : latency    1438558; std 391.28
[ 53 85 -- -- -- -- ]:     0    85     0   444     0  1900     0  4072     0  3347     0   148     0     0     0     0     0     0     0     0 : latency    1441200; std 403.60
[ 53 86 -- -- -- -- ]:     0    60     0   541     0  2005     1  3922     0  3329     0   137     0     0     0     0     0     0     0     0 : latency    1440663; std 398.70
[ 53 87 -- -- -- -- ]:     0    56     0   447     0  1937     0  4055     0  3361     0   137     0     0     0     0     0     0     0     0 : latency    1441108; std 410.74
[ 53 88 -- -- -- -- ]:     0   195     0   892     0  2720     0  3919     0  2167     0    90     0     0     0     0     0     0     0     0 : latency    1434408; std 374.12
[ 53 89 -- -- -- -- ]:     0    53     0   448     0  1976     1  4066     0  3303     0   148     0     0     0     0     0     0     0     0 : latency    1441125; std 405.33
[ 53 90 -- -- -- -- ]:     0   382     0  1542     0  3628     0  3614     0   753     0    25     0     0     0     0     0     0     0     0 : latency    1425468; std 385.67
[ 53 91 -- -- -- -- ]:     0    43     0   469     0  1926     1  4117     0  3317     0   120     0     0     0     0     0     0     0     0 : latency    1440969; std 414.38
[ 53 92 -- -- -- -- ]:     0    70     0   430     0  2070     0  4055     0  3240     0   131     0     0     0     0     0     0     0     0 : latency    1440722; std 402.00
[ 53 93 -- -- -- -- ]:     0    56     0   462     0  1959     1  4086     0  3302     0   131     0     0     0     0     0     0     0     0 : latency    1441031; std 406.16
[ 53 94 -- -- -- -- ]:     0   116     0   621     0  2247     0  3993     0  2879     0   133     0     0     0     0     0     0     0     0 : latency    1438426; std 391.27
[ 53 95 -- -- -- -- ]:     0    62     0   442     0  1959     0  4112     0  3266     0   155     0     0     0     0     0     0     0     0 : latency    1441092; std 403.74
[ 53 96 -- -- -- -- ]:     0    79     0   438     0  2011     0  4115     0  3206     0   144     0     0     0     0     0     0     0     0 : latency    1440716; std 402.36
[ 53 97 -- -- -- -- ]:     0    78     0   471     0  1844     0  4188     0  3256     0   149     0     0     0     0     0     0     0     0 : latency    1440856; std 409.30
[ 53 98 -- -- -- -- ]:     0   157     0   979     0  2683     0  3886     0  2190     0    96     0     0     0     0     0     0     0     0 : latency    1434494; std 374.52
[ 53 99 -- -- -- -- ]:     0    83     0   449     0  1898     0  4062     0  3354     0   148     0     0     0     0     0     0     0     0 : latency    1441196; std 403.28
0: 27 lat = 1441260
1: 47 lat = 1441230
2: 85 lat = 1441200
3: 99 lat = 1441196
4: 61 lat = 1441170
95: 02 lat = 1420572
96: 04 lat = 1418742
97: 80 lat = 1418592
98: 07 lat = 1416290
99: 00 lat = 1414580
0: 91 std = 414.38
1: 75 std = 411.20
2: 23 std = 411.18
3: 87 std = 410.74
4: 57 std = 409.96
95: 68 std = 374.76
96: 98 std = 374.52
97: 08 std = 374.47
98: 88 std = 374.12
99: 07 std = 367.33
lat_k 0-1 0.00%, lat_k 98-99 0.12%, lat_k 0-99 1.89%
std_k 0-1 0.77%, std_k 98-99 1.85%, std_k 0-99 12.81%
[ 53 27 00 -- -- -- ]:     0    37     0   382     0  1444     0  3318     0  3439     0  1362     0    13     0     0     0     0     0     0 : latency    1447756; std 363.64
[ 53 27 01 -- -- -- ]:     0    13     0   143     0   839     0  2760     0  4100     0  2111     0    29     0     0     0     0     0     0 : latency    1454342; std 392.69
[ 53 27 02 -- -- -- ]:     0    15     0   153     0   935     0  2746     0  4019     0  2106     0    24     0     0     0     0     0     0 : latency    1454040; std 383.06
[ 53 27 03 -- -- -- ]:     0    13     0   136     0   898     0  2695     0  4121     0  2105     0    30     0     0     0     0     0     0 : latency    1454438; std 387.32
[ 53 27 04 -- -- -- ]:     0    19     0   207     0  1129     0  2968     0  3805     0  1840     0    28     0     0     0     0     0     0 : latency    1451800; std 375.92
[ 53 27 05 -- -- -- ]:     0    12     0   167     0   810     0  2798     0  4078     0  2098     0    36     0     0     0     0     0     0 : latency    1454424; std 385.48
[ 53 27 06 -- -- -- ]:     0    13     0   166     0   926     0  2744     0  4031     0  2088     0    31     0     0     0     0     0     0 : latency    1454024; std 380.78
[ 53 27 07 -- -- -- ]:     0    68     0   389     0  1319     0  2863     0  3621     1  1711     0    21     0     0     0     0     0     0 : latency    1449581; std 360.86
[ 53 27 08 -- -- -- ]:     0     2     0    39     0   374     1  1455     0  3316     0  3424     0  1368     0    17     0     0     0     0 : latency    1467619; std 369.99
[ 53 27 09 -- -- -- ]:     0     0     0     6     0   144     0   857     0  2796     0  4020     0  2141     0    35     0     0     0     0 : latency    1474510; std 383.44
[ 53 27 10 -- -- -- ]:     0     9     0   114     0   688     0  2308     0  3891     0  2564     0   414     0    11     0     0     0     0 : latency    1458746; std 370.91
[ 53 27 11 -- -- -- ]:     0     0     0    12     0   139     0   900     0  2718     0  4085     0  2129     0    13     0     0     0     0 : latency    1474192; std 388.96
[ 53 27 12 -- -- -- ]:     0     1     0    15     0   155     0   933     0  2788     1  4000     0  2076     0    30     0     0     0     0 : latency    1473917; std 384.87
[ 53 27 13 -- -- -- ]:     0     0     0    16     0   140     0   896     0  2723     0  4094     0  2101     0    29     0     0     0     0 : latency    1474334; std 384.29
[ 53 27 14 -- -- -- ]:     0     0     0    23     0   211     0  1106     0  3005     0  3802     0  1822     0    27     0     0     0     0 : latency    1471716; std 376.68
[ 53 27 15 -- -- -- ]:     0     0     0    18     0   130     0   883     0  2749     0  4121     0  2073     0    25     0     0     0     0 : latency    1474312; std 386.27
[ 53 27 16 -- -- -- ]:     0     0     0    10     0   159     0   926     0  2798     0  4023     0  2057     0    26     0     0     0     0 : latency    1473900; std 381.72
[ 53 27 17 -- -- -- ]:     0     0     0     7     0   142     0   892     0  2718     0  4121     0  2092     0    27     0     0     0     0 : latency    1474400; std 385.63
[ 53 27 18 -- -- -- ]:     0     2     0    40     0   338     2  1526     0  3306     0  3410     0  1353     0    19     0     0     0     0 : latency    1467532; std 369.84
[ 53 27 19 -- -- -- ]:     0     0     0    13     0   133     0   908     0  2746     0  4053     0  2113     0    33     0     0     0     0 : latency    1474348; std 383.05
[ 53 27 20 -- -- -- ]:     0    11     0   133     0   886     0  2789     0  4029     0  2128     0    23     0     0     0     0     0     0 : latency    1454358; std 383.66
[ 53 27 21 -- -- -- ]:     0     1     0    14     0   149     0   875     0  2739     0  4091     0  2100     0    27     0     0     0     0 : latency    1474164; std 391.17
[ 53 27 22 -- -- -- ]:     0     0     0     9     0   153     0   953     0  2786     1  3976     0  2096     0    25     0     0     0     0 : latency    1473929; std 381.88
[ 53 27 23 -- -- -- ]:     0     0     0    18     0   130     0   891     0  2730     1  4114     0  2089     0    26     0     0     0     0 : latency    1474353; std 387.78
[ 53 27 24 -- -- -- ]:     0     1     0    21     0   222     0  1136     0  2974     1  3780     0  1835     0    29     0     0     0     0 : latency    1471799; std 374.55
[ 53 27 25 -- -- -- ]:     0     0     0    15     0   142     0   891     0  2674     0  4165     0  2078     0    31     0     0     0     0 : latency    1474242; std 390.67
[ 53 27 26 -- -- -- ]:     0     0     0    17     0   128     0   984     0  2809     0  3912     0  2118     0    31     0     0     0     0 : latency    1473920; std 377.52
[ 53 27 27 -- -- -- ]:     0     0     0    13     0   146     0   857     0  2774     0  4072     0  2113     0    24     0     0     0     0 : latency    1474382; std 385.04
[ 53 27 28 -- -- -- ]:     0     2     0    48     0   351     0  1497     0  3287     0  3458     0  1342     0    11     0     0     0     0 : latency    1467504; std 368.41
[ 53 27 29 -- -- -- ]:     0     2     0    12     0   142     0   870     0  2749     0  4098     0  2095     0    31     0     0     0     0 : latency    1474386; std 387.46
[ 53 27 30 -- -- -- ]:     0     3     0   119     0   665     0  2343     0  3834     0  2597     0   434     0     4     0     0     0     0 : latency    1458886; std 369.79
[ 53 27 31 -- -- -- ]:     0     2     0    11     0   151     1   856     0  2726     0  4121     0  2101     0    27     0     0     0     0 : latency    1474267; std 394.66
[ 53 27 32 -- -- -- ]:     0     0     0    19     0   170     1   878     0  2782     0  4043     0  2078     0    28     0     0     0     0 : latency    1474031; std 384.66
[ 53 27 33 -- -- -- ]:     0     0     0     8     0   166     0   827     0  2780     0  4060     0  2126     0    32     0     0     0     0 : latency    1474468; std 384.57
[ 53 27 34 -- -- -- ]:     0     2     0    13     0   217     0  1122     0  2941     0  3864     0  1815     0    25     0     0     0     0 : latency    1471952; std 375.37
[ 53 27 35 -- -- -- ]:     0     4     0     6     0   134     0   898     0  2728     0  4079     0  2117     0    30     0     0     0     0 : latency    1474264; std 390.73
[ 53 27 36 -- -- -- ]:     0     1     0    16     0   172     0   854     0  2841     0  4001     0  2085     0    29     0     0     0     0 : latency    1474036; std 384.50
[ 53 27 37 -- -- -- ]:     0     0     0     8     0   135     0   882     0  2743     0  4096     0  2110     0    25     0     0     0     0 : latency    1474450; std 385.52
[ 53 27 38 -- -- -- ]:     0     4     0    35     0   363     0  1485     0  3297     0  3421     0  1369     0    22     0     0     0     0 : latency    1467646; std 367.06
[ 53 27 39 -- -- -- ]:     0     1     0     8     0   148     0   874     0  2710     0  4111     0  2116     0    31     0     0     0     0 : latency    1474494; std 387.38
[ 53 27 40 -- -- -- ]:     0    12     0   175     0   930     0  2727     0  4072     0  2060     0    23     0     0     0     0     0     0 : latency    1453910; std 381.99
[ 53 27 41 -- -- -- ]:     0     7     0   159     0   861     0  2781     0  4058     0  2103     0    30     0     0     0     0     0     0 : latency    1454326; std 384.09
[ 53 27 42 -- -- -- ]:     0     2     0    19     0   158     0   880     0  2820     0  4043     0  2059     0    15     0     0     0     0 : latency    1473746; std 390.29
[ 53 27 43 -- -- -- ]:     0     0     0     9     0   134     0   882     0  2782     0  4050     0  2108     0    34     0     0     0     0 : latency    1474396; std 384.02
[ 53 27 44 -- -- -- ]:     0     1     0    21     0   251     0  1114     0  2892     1  3879     0  1806     0    34     0     0     0     0 : latency    1471843; std 375.80
[ 53 27 45 -- -- -- ]:     0     0     0    13     0   145     0   877     0  2771     0  4026     0  2139     0    25     0     0     0     0 : latency    1474204; std 387.33
[ 53 27 46 -- -- -- ]:     0     0     0    14     0   176     0   925     0  2722     0  4080     0  2052     0    30     0     0     0     0 : latency    1473930; std 381.96
[ 53 27 47 -- -- -- ]:     0     0     0    15     0   142     0   914     0  2724     0  4034     0  2140     0    30     0     0     0     0 : latency    1474340; std 381.73
[ 53 27 48 -- -- -- ]:     0     1     0    52     0   352     0  1494     0  3294     0  3445     0  1341     0    17     0     0     0     0 : latency    1467500; std 367.90
[ 53 27 49 -- -- -- ]:     0     1     0    17     0   142     0   900     0  2699     0  4094     0  2120     0    26     0     0     0     0 : latency    1474366; std 386.15
[ 53 27 50 -- -- -- ]:     0     7     0   125     0   648     0  2329     0  3878     0  2582     0   423     0     7     0     0     0     0 : latency    1458860; std 371.34
[ 53 27 51 -- -- -- ]:     0     0     0    15     0   139     0   856     0  2752     0  4098     0  2115     0    24     0     0     0     0 : latency    1474460; std 385.90
[ 53 27 52 -- -- -- ]:     0     3     0    14     0   141     0   929     0  2765     0  4056     0  2059     0    29     0     0     0     0 : latency    1473848; std 389.25
[ 53 27 53 -- -- -- ]:     0     0     0    15     0   118     0   890     0  2747     0  4078     0  2128     0    23     0     0     0     0 : latency    1474482; std 385.17
[ 53 27 54 -- -- -- ]:     0     2     0    23     0   203     0  1128     0  2918     1  3877     0  1833     0    14     0     0     0     0 : latency    1471965; std 378.02
[ 53 27 55 -- -- -- ]:     0     0     0    10     0   145     0   846     0  2798     1  4037     0  2129     0    30     0     0     0     0 : latency    1474293; std 390.81
[ 53 27 56 -- -- -- ]:     0     0     0    10     0   136     0   941     0  2789     1  4012     0  2074     0    36     0     0     0     0 : latency    1474067; std 383.55
[ 53 27 57 -- -- -- ]:     0     2     0    11     0   134     0   869     0  2764     0  4076     0  2113     0    30     0     0     0     0 : latency    1474448; std 387.23
[ 53 27 58 -- -- -- ]:     0     5     0    45     0   342     0  1518     0  3255     0  3468     0  1347     0    19     0     0     0     0 : latency    1467740; std 363.03
[ 53 27 59 -- -- -- ]:     0     1     0     7     0   156     0   864     0  2733     0  4043     0  2165     0    27     0     0     0     0 : latency    1474362; std 389.73
[ 53 27 60 -- -- -- ]:     0    11     0   144     0   871     0  2732     0  4110     0  2103     0    28     0     0     0     0     0     0 : latency    1454438; std 385.59
[ 53 27 61 -- -- -- ]:     0     0     0    10     0   130     0   873     0  2791     0  4031     0  2140     0    24     0     0     0     0 : latency    1474462; std 384.15
[ 53 27 62 -- -- -- ]:     0     1     0     8     0   138     0   933     0  2794     0  4024     0  2069     0    29     0     0     0     0 : latency    1473882; std 388.81
[ 53 27 63 -- -- -- ]:     0     1     0    10     0   132     0   891     0  2734     0  4070     0  2128     0    33     0     0     0     0 : latency    1474492; std 386.23
[ 53 27 64 -- -- -- ]:     0     0     0    23     0   204     0  1118     0  2946     0  3858     0  1828     0    22     0     0     0     0 : latency    1471986; std 373.22
[ 53 27 65 -- -- -- ]:     0     0     0     6     0   140     0   848     0  2791     1  4075     0  2109     0    26     0     0     0     0 : latency    1474309; std 392.45
[ 53 27 66 -- -- -- ]:     0     0     0     8     0   162     0   905     0  2833     0  3977     0  2084     0    30     0     0     0     0 : latency    1473984; std 380.85
[ 53 27 67 -- -- -- ]:     0     2     0     6     0   132     0   885     0  2772     0  4017     0  2154     0    31     0     0     0     0 : latency    1474506; std 385.17
[ 53 27 68 -- -- -- ]:     0     1     0    53     0   338     0  1488     0  3297     0  3448     0  1355     0    19     0     0     0     0 : latency    1467798; std 363.66
[ 53 27 69 -- -- -- ]:     0     1     0    15     0   156     0   828     0  2768     0  4063     0  2139     0    26     0     0     0     0 : latency    1474316; std 391.34
[ 53 27 70 -- -- -- ]:     0    10     0   113     0   663     0  2341     0  3873     0  2585     0   411     0     3     0     0     0     0 : latency    1458758; std 371.71
[ 53 27 71 -- -- -- ]:     0     0     0    12     0   142     0   893     0  2771     1  4024     0  2128     0    28     0     0     0     0 : latency    1474321; std 384.78
[ 53 27 72 -- -- -- ]:     0     1     0    10     0   169     0   916     0  2753     0  4059     0  2060     0    28     0     0     0     0 : latency    1473804; std 388.78
[ 53 27 73 -- -- -- ]:     0     0     0    12     0   157     0   883     0  2742     0  4058     0  2119     0    28     0     0     0     0 : latency    1474316; std 383.10
[ 53 27 74 -- -- -- ]:     0     1     0    25     0   217     0  1125     0  2914     0  3889     0  1809     0    19     0     0     0     0 : latency    1471872; std 375.56
[ 53 27 75 -- -- -- ]:     0     0     0     8     1   161     0   865     0  2772     1  4028     0  2138     0    25     0     0     0     0 : latency    1474352; std 387.34
[ 53 27 76 -- -- -- ]:     0     1     0    12     0   169     0   916     0  2759     0  4076     0  2025     0    38     0     0     0     0 : latency    1473750; std 389.04
[ 53 27 77 -- -- -- ]:     0     0     0    10     0   152     1   869     0  2758     1  4061     0  2119     0    28     0     0     0     0 : latency    1474378; std 388.34
[ 53 27 78 -- -- -- ]:     0     1     0    47     0   339     0  1520     0  3324     0  3378     0  1370     0    20     0     0     0     0 : latency    1467688; std 362.13
[ 53 27 79 -- -- -- ]:     0     0     0    12     0   142     0   911     0  2743     0  4021     0  2139     0    28     0     0     0     0 : latency    1474166; std 386.13
[ 53 27 80 -- -- -- ]:     0    19     0   212     0  1098     0  3030     0  3769     0  1849     0    21     0     0     0     0     0     0 : latency    1451912; std 374.22
[ 53 27 81 -- -- -- ]:     0     8     0   151     0   878     1  2811     0  3976     0  2140     0    34     0     0     0     0     0     0 : latency    1454327; std 383.58
[ 53 27 82 -- -- -- ]:     0    15     0   146     0   952     0  2774     0  4004     0  2080     0    25     0     0     0     0     0     0 : latency    1453764; std 384.90
[ 53 27 83 -- -- -- ]:     0    12     0   152     0   851     1  2840     0  3981     0  2128     0    34     0     0     0     0     0     0 : latency    1454315; std 384.54
[ 53 27 84 -- -- -- ]:     0     2     0    19     0   218     0  1148     0  2923     0  3838     0  1822     0    29     0     0     0     0 : latency    1471860; std 373.34
[ 53 27 85 -- -- -- ]:     0     0     0     9     0   130     0   916     0  2739     0  4053     0  2119     0    33     0     0     0     0 : latency    1474392; std 383.06
[ 53 27 86 -- -- -- ]:     0     0     0     7     0   174     0   956     0  2683     0  4101     0  2047     0    28     0     0     0     0 : latency    1473768; std 386.42
[ 53 27 87 -- -- -- ]:     0     0     0    11     0   134     0   911     0  2742     0  4060     0  2112     0    29     0     0     0     0 : latency    1474338; std 383.37
[ 53 27 88 -- -- -- ]:     0     2     0    48     0   333     0  1508     0  3307     0  3470     0  1312     0    19     0     0     0     0 : latency    1467668; std 365.17
[ 53 27 89 -- -- -- ]:     0     0     0    19     0   128     1   856     0  2820     0  4038     0  2113     0    21     0     0     0     0 : latency    1474169; std 391.48
[ 53 27 90 -- -- -- ]:     0    12     0   122     0   646     0  2306     0  3910     0  2571     0   424     0     8     0     0     0     0 : latency    1458878; std 372.11
[ 53 27 91 -- -- -- ]:     0     0     0    16     0   144     0   886     0  2693     1  4096     0  2136     0    27     0     0     0     0 : latency    1474473; std 386.40
[ 53 27 92 -- -- -- ]:     0     1     0    15     0   152     0   914     0  2766     0  4068     0  2058     0    25     0     0     0     0 : latency    1474004; std 385.46
[ 53 27 93 -- -- -- ]:     0     0     0    12     0   149     0   861     0  2723     0  4087     0  2135     0    29     0     0     0     0 : latency    1474354; std 389.00
[ 53 27 94 -- -- -- ]:     0     0     0    22     0   223     0  1104     0  2915     0  3895     0  1811     0    29     0     0     0     0 : latency    1471994; std 373.41
[ 53 27 95 -- -- -- ]:     0     0     0    12     0   139     0   858     0  2760     1  4069     0  2134     0    26     0     0     0     0 : latency    1474507; std 387.16
[ 53 27 96 -- -- -- ]:     0     0     0    26     0   132     0   932     0  2770     0  4038     0  2067     0    31     0     0     0     0 : latency    1473836; std 386.30
[ 53 27 97 -- -- -- ]:     0     0     0    18     0   141     0   841     0  2773     0  4075     0  2121     0    30     0     0     0     0 : latency    1474478; std 385.26
[ 53 27 98 -- -- -- ]:     0     3     0    51     0   326     0  1513     0  3318     0  3392     0  1379     0    17     0     0     0     0 : latency    1467762; std 362.60
[ 53 27 99 -- -- -- ]:     0     1     0    12     0   145     0   830     0  2787     0  4096     0  2093     0    32     0     0     0     0 : latency    1474296; std 392.92
0: 09 lat = 1474510
1: 95 lat = 1474507
2: 67 lat = 1474506
3: 39 lat = 1474494
4: 63 lat = 1474492
95: 82 lat = 1453764
96: 80 lat = 1451912
97: 04 lat = 1451800
98: 07 lat = 1449581
99: 00 lat = 1447756
0: 31 std = 394.66
1: 99 std = 392.92
2: 01 std = 392.69
3: 65 std = 392.45
4: 89 std = 391.48
95: 00 std = 363.64
96: 58 std = 363.03
97: 98 std = 362.60
98: 78 std = 362.13
99: 07 std = 360.86
lat_k 0-1 0.00%, lat_k 98-99 0.13%, lat_k 0-99 1.85%
std_k 0-1 0.44%, std_k 98-99 0.35%, std_k 0-99 9.36%
pin[2] choose candidate: 09 (latency only)
Candidate PIN 53 27 09 -- -- -- : brute forcing bytes 3 to 5 (3 bytes), will take up to 703 seconds
PIN is NOT cracked in 2809.24 seconds
done
Resetting all ECUs.
