ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
xanthefin wrote: 22 Jun 2024, 10:20
Last belt was replaced 2015... i am been playing with risk. but now i have some money to do.
Whoa 9 years? That belt is a ticking time bomb.
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 28 times
Post by RedBrickCollector »
volvolugnut wrote: 22 Jun 2024, 13:43 A healthy T5 should shift 1 to 2 in about a second at about 6000 RPM and a satisfying noise from tires. Insufficient air or fuel flow to engine?
jsrnsis wrote: 22 Jun 2024, 14:15 Have you already checked the upper shock mounts? The like to go bad. My shifting isnt a problem between 1st and 2nd. Between 2nd and 3rd gets up to 4000rpm in econ if I'm even a little heavy on the gas pedal, but it seems to be accelerating the whole way
Shock mounts were replaced together with the shocks, upper perch, and shocks, earlier this year. The main upper nuts had to be retightened also a couple months back. Seemed to be all tight now. Is it possible the spring needs to be reseated because of the loose lower retainer?
Regarding insufficient air or fuel, I'm not sure which it is. I have a fuel pressure gauge now but if it is in park the car doesn't boost, is this normal?
For insuffficient air, would a soft wastegate spring and/or hot ambient air (30-38C in the day, 26C on a rainy eveing) be enough?
For the shift itself it makes its way to 4000, 4500RPM well, then somewhere in that range it shifts out of 1st, no longer transmits power as RPM climbs slowly still, then shifts into second after about half a second that feels like forever. No tire chirp or anything.
2nd to 3rd is quick. happening at around 5k
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
RedBrickCollector wrote: 22 Jun 2024, 21:46
Have you done a drain and fill of the transmission too? That sounds like slipping to me. When I drained the transmission on the 94, the stuff that came out was super thin. Doing 3 drain and fills brought my reverse back, but it never truly worked right. At least I was able to back out of a space on flat ground, but I wish I had done it sooner.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
xanthefin
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
ZionXIX wrote: 22 Jun 2024, 17:40
I thought what i hear is my lifters ticking.
RedBrickCollector
jsrnsis wrote: 23 Jun 2024, 08:50 Have you done a drain and fill of the transmission too? That sounds like slipping to me. When I drained the transmission on the 94, the stuff that came out was super thin. Doing 3 drain and fills brought my reverse back, but it never truly worked right. At least I was able to back out of a space on flat ground, but I wish I had done it sooner.
Did a gibbon's method fluid change with 8L of aisin AFW+
'97 950 T-5 Wagon
Has thanked: 1836 times
Been thanked: 1709 times
Forgot to mention that an interesting guy I met a week ago that has 7 x 850's. He was telling me that there is a performance shop in the south end of Calgary that are building a trick white block. They are aiming to extract around 1000 bhp!!
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
scot850 wrote: 26 Jun 2024, 23:20 Forgot to mention that an interesting guy I met a week ago that has 7 x 850's. He was telling me that there is a performance shop in the south end of Calgary that are building a trick white block. They are aiming to extract around 1000 bhp!!
That should be interesting when it's running! These high horsepower white blocks seem to hold up pretty well, from what I see!
xanthefin
Post by xanthefin »
Was no news section for random talks so.. IAC Group Sweden Car part manufacturer in Sweden went bankrupt.
Made some car parts example for Volvos.
https://www.svt.se/nyheter/lokalt/vast/ ... a-paverkas
to thread itself.. gonna today replace some brake pads finally as has time and not raining on same day!
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 999 times
Post by volvolugnut »
Any build details shared?
Twin turbos? Big injectors? Special cams? Custom rods? Water injection? O ring head gasket?
No unfortunately. I will try to get hold of the guy to try to find out who it is working on it and get m ore info if I can.
