Do you mean a Reinitialization by disconnecting the negative terminal and reconnecting with the key in POSII ?
Vida CEM swapping
- RickHaleParker
- Been thanked: 980 times
Active
Past
Past
raikonen
- Year and Model: 2007 c70
- Has thanked: 1 time
I was trying around 10 times and nothing was happening, my key was in as I was doing manual conversion(and if ECU,CEM thinks that gearshifter is not in P you cannot get key out)... but not in second position, just tried to disconnect battery and give another try and it worked for meRickHaleParker wrote: 08 Aug 2021, 08:47Do you mean a hard reset by disconnecting the negative terminal and reconnecting with the key in POSII ?
- RickHaleParker
The P2s crack without the key in. The above process will force all control units to reinitialize to a ready state.raikonen wrote: 08 Aug 2021, 08:58 I was trying around 10 times and nothing was happening, my key was in as I was doing manual conversion(and if ECU,CEM thinks that gearshifter is not in P you cannot get key out)... but not in second position, just tried to disconnect battery and give another try and it worked for me
Active
Past
Past
- RickHaleParker
CEM-L & CEM-H always on power pins ( No key inserted condition ).
B2, B3, B16, B24
E:A & E:B The heavy red wires. Power to the fuse banks.
Grounds D:6 & B:5
Ignition switch symbols
30 = Constant power from the battery to switch
Switched side of Ignition switch.
S = Powered upon insertion of key, CEM D:15.
X = Accessories, CEM D:8.
15 = The switch remains connected during start, CEM D:16.
15l = Contact is broken while starting. Not use on CEM-L & CEM-H.
50 = Start. CEM D:60.
Key insertion ( S ) CEM D:15 .
POS I ( S, X ) CEM D:15, D:8 .
POS II ( S, X, 15 ) CEM D:15, D:8, D:16 .
POS III ( 15, 50) CEM D:16, D60 .
B2, B3, B16, B24
Grounds D:6 & B:5
Active
Past
Past
raikonen
c70 mk2 is P1RickHaleParker wrote: 08 Aug 2021, 09:05The P2s crack without the key in. The above process will force all control units to reinitialize to a ready state.raikonen wrote: 08 Aug 2021, 08:58 I was trying around 10 times and nothing was happening, my key was in as I was doing manual conversion(and if ECU,CEM thinks that gearshifter is not in P you cannot get key out)... but not in second position, just tried to disconnect battery and give another try and it worked for me
- RickHaleParker
Has any of the P1 owners tried cracking without the key inserted.
Active
Past
Past
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Yes. Not the owner, but tried on @sparacis C30. The P1 code was overcomplicated back then, the crack attempts failed, buy he got it cracked with P2 code path. It cracked even with the wrong pin bytes shuffle orderRickHaleParker wrote: 08 Aug 2021, 10:10Has any of the P1 owners tried cracking without the key inserted.![]()
- RickHaleParker
That is interesting!
Makes me wonder if the byte order even matters on a P1. Could it be that a P1 will accept any of the 720 permutations ... ?
Active
Past
Past
vtl
Motorola in P1 is very slow. The cracking code essentially does permutations while it cycles through the value. For Motorola it's enough just to step on a right pin subsequence to raise the latency significantly enough for cracker sw to notice it.RickHaleParker wrote: 08 Aug 2021, 11:12 That is interesting!
But with the correct pin order the process is more reliable.
- RickHaleParker
Correct me if I am wrong, for the three unknown bytes not all six bytes.vtl wrote: 09 Aug 2021, 08:29
Would only need to measure 100 latencies to step on all six. If it works for a sub-sequence of one.For Motorola it's enough just to step on a right pin subsequence to raise the latency significantly enough for cracker sw to notice it.
At least in theory, the top six candidates could be the correct six bytes. Knowing the six correct values, narrows it down to 720 possible pins numbers. Would fail if two or more bytes are the same value. I do not see any way to detect that two or more are the same.
Recall somebody saying their cracker would not crack a known Pin but the correct byte values where coming up the the top five candidates. I keep that in the back of my head because that could exploitable if it is reliable. Possibly, could be used to factor out anomalies that strew the latency measurements.But with the correct pin order the process is more reliable.
Active
Past
Past
- 9999 Views
Last post by RickHaleParker
- 10420 Views
- 27 Replies
- 31911 Views
Last post by cn90
- 12299 Views
Last post by jonesg
- 7205 Views
