Has thanked: 1850 times
Been thanked: 1710 times
With a lack of oxygen on Pluto I am surprised it rusted!! :lol: :lol:
Looks like and east coast car. Yikes!
Has thanked: 1505 times
Been thanked: 3818 times
I had one like that on Shagg with a firm warning from seller to fix that , stat. When the pad pin hole has rusted through it has truly reached end of life.
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
BlackBart wrote: 04 Sep 2024, 11:59 wow...wow...
Conditions must be harsh on Pluto.
Tactical marker covering obvious.
P.S. Funnily this side works better than not so rusted side after i tried couple times. So needs replace both side then after engine work. My Volvo for various mess reasons has been now sitting almost 4 months but maybe now coming back. I have no idea what did sit on caliber to rust it..
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
I'd make a few prayers before trying to loosen that bleed screw given the state of the caliper :lol:
V70 is acting up a bit again :evil: Ordered stuff to log the fuel pressure, and if it's the issue AGAIN the pump might be thrown into low orbit :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
Goupil wrote: 05 Sep 2024, 13:06 I'd make a few prayers before trying to loosen that bleed screw given the state of the caliper :lol:
Burn some sort of tribute to Odin or whatever Norse gods are involved in brakes.
coop
Year and Model: 1998 s70 t5
Has thanked: 17 times
Been thanked: 15 times
Post by coop »
Pulled some premium rear deck speakers from a s60.
The brackets are mostly the same except for the tweeter piece and left is right and right is left to match up the mounting holes and it won’t fit correctly with the trunk hinge there. The cover doesn’t fit exactly as the tweeter is covered by the center cubby console in the deck but doesn’t seem to have any distortion or vibration. May just take the speakers out and put them in the older brackets but way more bass now
Year and Model: 2001 V70
Been thanked: 1000 times
Post by volvolugnut »
I have been driving my 1987 Volvo 244 around town about once a week. It starts and runs well, but has a few issues I need to address.
The steering is twitchy so It likely needs alignment.
The temperature and fuel gauges do not work most of the time. A few whacks on the dash and they may start working for a while.
The overdrive button seems to stick and overdrive does not engage all of the time.
A home car wash has cleaned up the original white paint and it looks better now (mostly).
STLV70
Year and Model: 1998 V70
Has thanked: 29 times
Been thanked: 5 times
Post by STLV70 »
I finally got the pinch bolt out of the driver's side control arm...a task started several weeks ago. Hopefully the new one goes on easily sometime this week, and the other side moves much quicker now that I own a cut-off wheel. I just need some coaching on how to explain our family's need to acquire a much larger air compressor to run the cut-off wheel efficiently in the future. :lol:
I wanted to get more done this weekend, but putting new low beam bulbs in my wife's 2013 Subaru used up far more time than a light bulb change should.
1998 V70 Base - "Lazarus" - 180XXX
2001 V70XC - "Gustav" - 200XXX
A compressor is justified by the savings on what you would pay a mechanic to do the repair! :roll: :lol:
Goupil
Post by Goupil »
Had noticed a while ago that the V70 handbrake was locking only one wheel, thought it just needed an adjustement.
Nope, 2020 parts sucks ! TRW brand, both side delaminated
Replaced with 1998 parts I had on the spare rear axle
