BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
We used to always do that - clean the interior, give the contacts a quick file. Same with the rotor if it wasn’t scorched away. New points, new condenser.
Has thanked: 1847 times
Been thanked: 1710 times
The main issue with caps is if the contacts get really worn then the gap increases added to the wear in the rotor arm. Eventually once worn enough the spark has difficulty jumping the gap. I had a 245 owned by 10 previous careless owners and it would not start when it rained or was cold and damp. Condensation build up was enough to prevent it work until I sprayed it with WD-40 and dried it out.
Anew cap and rotor fixed it.
Don't recall seeing the plastic behind the contacts on the cap.
jsrnsis
Year and Model: P80 enjoyer
Has thanked: 25 times
Been thanked: 68 times
Post by jsrnsis »
hausmeister wrote: 27 Sep 2024, 09:47 Regarding distributors, the last one I replaced (bosch) I tried to clean the contacts and it honestly looks pretty good and solid still. I kept it for a rainy day, but really - could it be reused for an extended period? Just curious, if the contacts are not worn out, are there other considerations?
(You know, keeping the ex as a spare ;) )
They are quite expensive now, I almost feel stupid for throwing 1 or 2 away when I replaced them as a tune up item.
1998 V70XC black 183xxx
2014 S80 T6 AWD 110xxx
1998 V70XC nautic blue 155xxx
1997 850 GLT 123xxx
2024 Honda CRF110F
Previous Volvos:
1997 850 GLT 239,577
1998 V70 NA silver 202,510
1994 850 NA gray 125,000
1998 V70 NA white 163xxx
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
That cap doesn't look to be worn, but rather it has deposits on it. I'd bet the rotor is what was worn. When I re-newed my ignition, my new cap hadn't arrived yet. I cleaned the original cap, but the rotor had metal missing. The car ran fine with a new rotor and cleaned cap. I did eventually get a new cap installed.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
Started like from under palm tree!
And after years mumbling that nozzles suck got new ones and very happy now of spray pattern and gets much cleaner too.
454cid
Post by 454cid »
xanthefin wrote: 28 Sep 2024, 11:13
What did you buy? Genuine Volvo? I bought some Proparts Sweden nozzles and my washers are still terrible on my 850. My S70 washers were fantastic. I should probably rebuild the entire washer system on the 850, but it's always low priority.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
xanthefin
Post by xanthefin »
454cid wrote: 28 Sep 2024, 11:43
Bought these biltema. I think S70 came too by default which spreads more from top of my head when i went through options months ago for these what to test and i looked which makes wider pattern and not just four pointy streams as cleans very poorly. These kind of can be found from various price ranges as most likely no brands generic ones.
Fit P2 nozzles. They are way better.
Has thanked: 1504 times
Been thanked: 3817 times
Why would you keep the old one when you can send it back to FCP for a free replacement, ( next time)
coop
Year and Model: 1998 s70 t5
Has thanked: 17 times
Been thanked: 15 times
Post by coop »
Replaced some vac lines. Couldn’t find good pictures of the intake to fuel pressure regulator line so here ya go if it helps. Helps to take the box out and lift the intake tube to access the nipple
