Has thanked: 1505 times
Been thanked: 3818 times
Pushed 7 liters of Volvo Maxlife ATF Dex 6 into KarlaKat transmission via pumpout through the radiator hose. Managed to do this on a conference call while getting paid.
:D
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
abscate wrote: 16 Dec 2024, 10:22 Pushed 7 liters of Volvo Maxlife ATF Dex 6 into KarlaKat transmission via pumpout through the radiator hose. Managed to do this on a conference call while getting paid.
:D
Bevel gear juice too.
NC855R
Year and Model: 1997 850 R
Has thanked: 45 times
Been thanked: 28 times
Post by NC855R »
Not today, but Sunday. On my way to re-assembling the car from the manual swap I decided to do the preventative maintenance items while I had the suspension off. So did timing belt, water pump, aux belt, spark plugs, wires, rotor and cap. So 1 day diversion from putting the car back on the ground, Now I can button everything up and see it it all works after the swap :)
Has thanked: 1850 times
Been thanked: 1710 times
Always good to get the 'while you are in there' stuff done as well. especially the service stuff.
I'm still in the 850 AWD dash repair for my buddies car. I hate 850 dashes as they are needlessly more difficult to work on the the 98- P80's.
I have replaced the broken direction flap on the RHS of the airbox. Also checked the LHS as they like to become gooey and stick causing the flap drive to snap. Fortunately the LHS was ok as they are NLA and have been so for some reason for 10+ years if I recall.
Took the opportunity to clean most of the accessible airbox and my buddy brought some cleaning foam that looks like shaving foam, and sprayed the evaporator that looks really clean. He added the cabin air filter many years ago and it shows. Now starting to reassemble.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 417 times
Been thanked: 457 times
Post by Sveedy »
NC855R wrote: 17 Dec 2024, 05:42 Not today, but Sunday. On my way to re-assembling the car from the manual swap I decided to do the preventative maintenance items while I had the suspension off. So did timing belt, water pump, aux belt, spark plugs, wires, rotor and cap. So 1 day diversion from putting the car back on the ground, Now I can button everything up and see it it all works after the swap :)
I think someone is going to be having some fun :)
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
:D
Double dipping without the dripping!
volvolugnutr
Can someone help my Google Fu this morning? Searching unsuccessfully for the thread on master tabulation of drive axle part numbers …can’t find it.
I am author, has photo of a sheet I made culled from Volvo online stuff
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 21 Dec 2024, 04:58 Can someone help my Google Fu this morning? Searching unsuccessfully for the thread on master tabulation of drive axle part numbers …can’t find it.
This one? viewtopic.php?t=94409
DennisCA
Year and Model: 1996 850
Been thanked: 59 times
Post by DennisCA »
Replaced the original spark plug leads with NGK ones. Keep getting misfire errors on the ECU now :/ I guess it's back to the originals...
DennisCA
Post by DennisCA »
I have tried to empirically work my way through the problem today.
  • I found the ignition coil cable was touching the AMM. I moved the cable so that it was not touching. Cleared the fault codes, went on a test ride of 8km.
    Result: No difference, the same kind of fault codes returned after the trip.
  • I replaced the ignition coil cable with the old one but left the other cables. Cleared the fault codes, went on the same trip again.
  • Now I finally replaced all the spark plug leads with the old ones. Cleared the fault codes, went on the same trip again.
    Result: Yes! No fault codes after this trip!
Everything back to how it was then with the old cables:
I guess I will have to find bougicord cables now. Apparently EFI Automotive are the ones who make Bougicord cables and I've been able to find what looks like the right leads now under that name.
