Has thanked: 1850 times
Been thanked: 1712 times
That is disappointing. We have found over the years using anything other than Bougicord could cause problems. Strange thing is that I think I mentioned that my friend has a 98 V70 NA and her friend and mechanic fitted NGK leads that have been on there for about 10 years now and they have been just fine. Maybe, just like many other things these days the quality is not what it once was. Let us know if you can find the leads as they are getting harder to find.
Glad you found a solution!
I had an issue with our 93 when a Volvo shop had worked on the car and it would randomly cut out. It was the way they had routed the cable for the cam sensor too close to the distributor so that the signal from the king lead would over power the signal to the cam position sensor. Re-routing that and all was then well.
DennisCA
Year and Model: 1996 850
Been thanked: 59 times
Post by DennisCA »
I think it's not a quality issue, I think the leads are made according to incorrect specifications. I know from before there is wrong information out there at least with regards to the Bougicord leads for instance. They have the incorrect info about the 10V and 20V engines, swapped around. So I think maybe there is something like that here, like it's made perhaps OK, just to the wrong specs for this engine.
Probably some property of the cables are wrong.
Has thanked: 1506 times
Been thanked: 3818 times
Picked up my last Muffin on Christmas Adam to make a full set of women home for a Holiday week…
Evita just keeps rolling…
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
abscate wrote: 26 Dec 2024, 04:55 Picked up my last Muffin on Christmas Adam to make a full set of women home for a Holiday week…
Christmas Adam... :lol: :lol:
Merry belated Christmas to the Abscate family, and everyone else here who celebrates!
Rolled the T5 with girls plus dog for a beach walk. More girls followed in the P2
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1001 times
Post by volvolugnut »
I just read today what Christmas Adam is about. (December 23 - Adam came before Eve)
Another holiday reason to celebrate.
clever
volvolugnut wrote: 27 Dec 2024, 18:25 I just read today what Christmas Adam is about. (December 23 - Adam came before Eve)
clever
:D :D :D
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
DennisCA wrote: 25 Dec 2024, 12:46 I think it's not a quality issue, I think the leads are made according to incorrect specifications. I know from before there is wrong information out there at least with regards to the Bougicord leads for instance. They have the incorrect info about the 10V and 20V engines, swapped around. So I think maybe there is something like that here, like it's made perhaps OK, just to the wrong specs for this engine.
In Finland if you use registry plate information on some part stores it might surprisingly show as mk1 V70 so you get some parts wrong even by that so need today go manually change it to 850.
It was a Man City Day
0 wins
3 losses
1 draw
Smoked the E83 and found cracked IM. Nit motivated to pull it, so reassembled and can be driven local. Draw
Installed battery switch on T5. But if struggle. Hard starting. Got code for bad cam sensor and cam timing. Not motivated. 0-1-1
Went to install new thermostat on house. Need C common 24VDc for that app. Traced thermo wire down to furnace and couldn’t find the same loom downstairs. Wtf? 0-2-1
Broken tray replacement on fridge arrived. Pulled drawers and food , found one guide rail not in box. On back order. Restocked fridge.
0-3-1
Did consolidate s70 AWD PARTS into nice boxes.
5underpressure
Year and Model: 1998 v70
Has thanked: 11 times
Been thanked: 13 times
Post by 5underpressure »
Replacing the Failing alternator. During Reassembly I found a melted vac line coming off a nipple right behind power steering pump side of the intake, guessing it goes to the PVC system? it’s kinda oil rotten. I should just stop right now order parts to do the timing belt water pump, or just tear the whole damn thing apart, lol
