The Resurrection of (10/1998 to 01/2021, 11/21- 11/25) Elizabeth 1999 V70T5M56 Cylinder Head Job Topic is solved
- Has thanked: 312 times
- Been thanked: 818 times
What Neil said - the compression test is just for checking cylinder health. Won't give you any clues on the valve stem seals but sounds like you have a handle on them already. Will only tell you about valves if one is really bad - you'd know already.
- Has thanked: 2215 times
- Been thanked: 1853 times
Yep! I'd say they are well past due! LoL!
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Thanks guys...i'm gathering all info i can get.
I trust my mechanic....but i would like to be prepared for this...for myself.
So....compression on warm engine first.
Opinions are divided on this....somebody says on cold engine....somebody on warm engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Warmer engine is better but you can do both and compare. It may give you a read on the piston ring condition or bore wear. Argument for not doing when engine is cold is engine is harder to turn over and may not give consistent results
Neil
Neil
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I think the other part of the 'luck' equation was the errant piece escaped, instead of dancing around for a while on top of the piston. We lost a big chunk of an intake valve on the racecar once, it imbedded itself on top of the piston and stayed there for the rest of the race. We weren't running all that well that day, so the poor thing didn't even slow down much. Quite a scramble at the shop that night to swap motors and be ready for the afternoon race the next day. I was fresh out of the Navy, so I was still used to operating on no sleep.abscate wrote: 09 Feb 2021, 11:56I think this exactly what happened to me. I didn’t burn a lot with Castrol High Mileage Synthetic but the Pennzoil synthetic burned nasty.There is a lot of carbon build up in that head. I am wondering if the issues we are having with valves burning is due to stem seals leaking into the cylinders and burning causing hot spots taking the valves out?
I started smoking on overrun at about 180k miles, 80k ago.
I got lucky in the valve drop, 5 miles from home on a 500 mile round trip, didn’t even need a tow.
Ah, those were the days. Sure glad I don't do that anymore.
- Has thanked: 1613 times
- Been thanked: 4078 times
Ah, Navy. I knew I liked you for a good reason?
What do the Air Force, Army, and Navy all have in common?
They all want to be in the Navy.
- Has thanked: 317 times
- Been thanked: 531 times
That and all tolerances are closer to proper spec when warm, so you'll have more accurate numbers. There's no real reason to do a compression test on a cold engine unless you're trying to diagnose a cold running issue.scot850 wrote: 09 Feb 2021, 15:20 Warmer engine is better but you can do both and compare. It may give you a read on the piston ring condition or bore wear. Argument for not doing when engine is cold is engine is harder to turn over and may not give consistent results
Neil
Got my valves in from FCP,today, waiting on the valve stem seal kit from Tasca to drop,off at machine shop
Reflections....on my engine there are none of those semi circle divots that look like valve hits on any of my piston tops
I also got the front end up supported up in preparation for the steering rack replacement, on order.
The four large subframe bolts, 18mm hex heads, cracked easily with the 2 foot breaker bar and a 1/2 inch drive impact socket
- foggydogg
When some of my Shipmates felt like getting frisky at the bar, they would remind any Marine in earshot that we were happy to give them a ride - and that at the top of their paycheck, it said 'United States Navy'.abscate wrote: 09 Feb 2021, 18:04 Ah, Navy. I knew I liked you for a good reason?
Submariners never consider themselves part of the Navy, mostly because wherever we went, we were utterly alone and on our own.
Plus, some of them fellers were slightly off-center.
I, however, am nearly normal.
Looks like your machine shop/part delivery pause was timed right for weather.
Submariners are their own breed, indeed.
There is another joke about Marines and sheep being too obvious which will definitely start a bar fight
- 21 Replies
- 6040 Views
- 1693 Views
- 32 Replies
- 8523 Views
Last post by SoCalV70T5
- 28 Replies
- 5799 Views
- 12 Replies
- 1542 Views
