- Has thanked: 1506 times
- Been thanked: 3820 times
Not too hateful…
- Has thanked: 305 times
- Been thanked: 517 times
Nautic blue was certainly not my first guess...
nah it definitely was
- Has thanked: 1853 times
- Been thanked: 1714 times
That driver's door panel is in amazing condition! Well done sir!
Paint is a lot rougher than the photos , especially the hood.
Okay , true confession. My mantra for these cars is to look for 100k models even with major engine or transmission trouble, good bones, this one looked great with 108k on it.
Unofortunately , with the right glasses on, it listed at 180k
Doh!
Of course, it starts, runs, and shifts as smooth as silk, and the one code for evap was an unplugged hose.
Karma.
Doh!
Karma.
RedBrickCollector
- Year and Model: 1997 850 T-5 Wagon
- Has thanked: 40 times
- Been thanked: 28 times
Happened while my brother borrowed the car
Still processing. Looks like snapped lugs. Explanations as well as what to check for damage would be appreciated
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Ouch, should bolt back on for 95% perfect fit though.
Where you live, you can actually find people who can fix stuff like that
Chieber
- Year and Model: 1998 v70
- Has thanked: 45 times
- Been thanked: 30 times
Found out the condenser and evap of the ac was shot.
Then saw some metal flakes in the orifice.
So replaced everything:
Compressor
Condenser
Damper
Dryer
Oh. And also replaced heater core. Apparently it was leaking, causing loss of coolant.
Meanwhile cleaned up the bonnet latches, replaced bonnet release cable and accelerator cable and removed the pre-heat shield and pre-heat shield hose.
And the bumper bolts have seen better days.
Edit: added photo of a/c temp.
Compressor
Condenser
Damper
Dryer
1/2 a shitbox V70 1998 2.5 NA
I was about to ask if yo had replaced the orifice valve/filter, especially as you said you found debris in the system. Glad to see you had a picture of the valve and it had done it's job!
Major work you are going through. Very satisfying though!
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Where exactly in the system Is that orifice filter located ? Is it in the tube ?
1999 V70 GLT
1999 V70 GLT
- BlackBart
- Has thanked: 927 times
- Been thanked: 885 times
Wow! So the wheel started coming off and caught the fender and ripped it off?RedBrickCollector wrote: ↑11 Jun 2025, 01:38 Happened while my brother borrowed the car
