Vida CEM swapping
- RickHaleParker
- Been thanked: 958 times
It is a CEM-L out of a 2006 V70 on the bench. Things where getting squirrely ... I'll look into this later.
Might have something for you later. I was experimenting with your new code. I ran it with CALC_BYTES = 6 and it almost got all six. That is with B3 - B5 the correct weights where making the shortlist up to a point. I have not ran through all the data yet but at first glance it look like if you select B0 - B2 by latency then B3 - B5 by lowest STD it would get all six correct.
vtl
- Year and Model: 2005 XC70
- Has thanked: 114 times
- Been thanked: 606 times
Max CALC_BYTES is 4, or you'll be getting array access that is out of boundary. The algo uses +1 and +2 pin positions while it assesses latency, so it can't do more than 4 positions.RickHaleParker wrote: ↑08 Oct 2021, 08:46 Might have something for you later. I was experimenting with your new code. I ran it with CALC_BYTES = 6 and it almost got all six. That is with B3 - B5 the correct weights where making the shortlist up to a point. I have not ran through all the data yet but at first glance it look like if you select B0 - B2 by latency then B3 - B5 by lowest STD it would get all six correct.
- RickHaleParker
Ran it again with CALC_BYTES 4 & CALC_BYTES 6. It is unreliable. Stick with CALC_BYTES 3 .
- RickHaleParker
Anybody got an answer for this?RickHaleParker wrote: ↑08 Oct 2021, 02:34 If the PIN is 85 20 47 55 20 00 and the shuffle order is 3 1 5 0 2 4 should the detection order be 55 20 20 -- -- -- not 55 20 00 -- -- -- ?
85 20 47 55 20 00
03 01 05 00 02 04
55 20 20 85 00 47
Detection order is 55 20 00 -- -- -- and it works.
Did I doing something wrong when I shuffled them above?
vtl
You are doing it in reverse: shuffling CAN/transport bytes to get in-flash bytes. Should do in reverse, the algo searches the in-flash bytes.RickHaleParker wrote: ↑08 Oct 2021, 10:13Anybody got an answer for this?RickHaleParker wrote: ↑08 Oct 2021, 02:34 If the PIN is 85 20 47 55 20 00 and the shuffle order is 3 1 5 0 2 4 should the detection order be 55 20 20 -- -- -- not 55 20 00 -- -- -- ?
85 20 47 55 20 00
03 01 05 00 02 04
55 20 20 85 00 47
Code: Select all
85 20 47 55 20 00 <- what you send over CAN
0 1 2 3 4 5
55 20 00 85 47 20 <- how it looks like in flash
3 1 5 0 2 4
- RickHaleParker
I forgot you consider what is send over the Com line in order ( decrypted ) and what is in flash shuffled ( encrypted ).
The way I think is you encrypt to send and decrypt to use. That is what got me inverted.
85 20 47 55 20 00
00 01 02 03 04 05
55 20 00 85 47 20
03 01 05 00 02 04
- 6431 Views
Last post by RickHaleParker
- 8699 Views
Last post by forumoto
