PCV job V70 and S70 non-turbo
This topic is in the MVS Volvo Repair Database » PCV Job for V70 and S70 Non-turbo
rspi
Has thanked: 34 times
Been thanked: 72 times
Re: PCV job V70 and S70 non-turbo
Post by rspi »
The lower intake manifold bolts don't have to be removed, just loosened. The 2 bolts that hold the bracket on the bottom of the intake manifold can be removed from up top if you are a little flexiable. Also, the bolt that holds the oil dip stick tube. Try not to drop and loose an intake manifold bolt. The first time I did the job it took almost 7 hours because I had to run to the store twice to get tools. A good pair of long curved needle nose pliers and those funny clamp crimpers will be good to have on hand. Also, there is a fuel line that is very short and will likely not come loose will need to be replaced. Make sure you get FUEL INJECTOR rated hose to replace that small hose.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
I am feeling comfortable with taking it on. Few questions...
Would oil change be a good first step after PCV job?
Do I drain before starting to take things off?
What parts in the kit must be oem/oes?
What make of part to avoid?
Which hoses must have fixed size crimp clamps?
