Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Probably the most common failure of these cars! My car did that too shortly after I bought it. In my experience its a failure of the plastic clip that attaches the actuator to the window at the bottom rail. It's a pita to fix but I grabbed a few extra clips at the boneyard for the future. I remember driving around with duct tape on the window for 2 weeks until I had time to fix it!
2003 XC 70 (sold)
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
Common euro car problem - usually broken plastic clips, but can be regulator warp problem also. I have repaired 2 and need to work on third on Volvo and Mercedes I own. You have reminded me it would be good to carry tape in the cars just for this possibility. It might even be a preventive maintenance job to replace the clips before they fail.
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
Interesting you guys - thanks.
Now I feel like I should order the factory clips new and get them to the glass shop - but we won't know which until it's open.
Has thanked: 1610 times
Been thanked: 4068 times
I had a back window regulator break on the E83 Bavarian Money Waster in our first year of ownership.
True to form I fixed it with a drywall screw and wood for a while, then finally broke down and Bought the $50 part from FCP after the third failed repair.
Stupid is as stupid does.
-fg
BlackBart
Post by BlackBart »
Is it these little blue clips?
Trying to find them here.
https://www.volvopartswebstore.com/show ... evel=28254
Oh, #4 here, only 6 bucks. Are they the only thing holding the glass up?
With the weather, shipping is a problem.
A thought just popped into my head - I roll the window down only once in a while - on a nice day, roll it down, roll it up when you get home. Why would it wear out? But the busy professional previous owner was the type to be hitting the coffee window constantly, and I'll bet that drivers window got a workout!
Starbuck
Year and Model: 2004 XC70
Has thanked: 47 times
Been thanked: 9 times
Post by Starbuck »
Right this very minute Ben is getting new CV boots on his passenger side. Have any of you ever encountered the dry rust dust (I have no idea what it is) on the inner shaft? I am driving up to Jersey in two weeks. I don't need any more stressors!
Hilariously, I can't find the axle dust sealing rings I ordered in October so I'll be driving the BMW home today. Erg.
2004 XC70 - "Benjamin Wash"
2008 XC90 3.2 - "Norman" (RIP totalled)
2004 S60R - "Nial" (Sold to a good home)
1991 Mazda Miata - "Origami"
1982 VW Rabbit Pickup - "Judy"
Blacklab467
Yeah, that rust is common, same on the driver's side. The axles go into a dry female spline on the transmission. It's also dry where it goes through the angle gear. You might want to put some grease on the splines when it goes back in.
2003 XC 70 (sold)
Starbuck
Post by Starbuck »
Awesome, thanks. I got it to where you see in the pictures. I couldn't find the clip people were talking about and I was starting to get hangry so opted to leave it to revisit later.
The Bav Money Waster's headlights flicker, remember (probably a ground issue somewhere)...so I opted to leave to get home by dark. Right now the mood is waffling between buying a whole new driveshaft from FCP and trying to find a good video that's applicable to my car to help me out. Food first before I get in trouble with my grumpiness.
You will be ok with that driveshaft, it’s holding grease in so it’s not letting water In.
I have to put a fuel pump in my Bavarian money waster do using it for local errands to get the tank level down
Watch your weather window coming up, it’s that nasty time of year
Starbuck
Post by Starbuck »
I hear ya, gotta figure out how to disassemble it to put the new boots on though.
I just did that on my E46 this past summer! That and the starter from the top. I wish I were closer to you, I'd be happy to help.
Yes about the weather. If it comes to it I can drive my MX5 up but I'm selling it come warmer weather so I don't want to put all those miles on. Plus it's winter up North! Those tires will not work if the roads are anything but clean. I'll only have room for my work stuff too. So many checks in the no column.
Bottom line is I have to get Ben sorted.
