2001 V70XC - 200,000 Miles Makeover Topic is solved
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
- Pete - wrote: 28 Apr 2020, 10:14 Is that a groove in the belt? As in, can you catch your fingernail in it? Or is it just a different color? It’s hard to tell from the photo.
If it’s a groove I’d definitely get a replacement from FCP. They’ll take care of you I’m sure.
The ribs/grooves are full, continuous, but the change is felt on finger tip -- can pick with nail.
The FCP team says "We have checked multiple belts and they all have this mark, presumably it's a point of reference since both sides are grooved." FCP also confirmed the belt is installed correctly.
Returning to tapping noise troubles.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
xHeart wrote: 17 Apr 2020, 19:30
- Pete - wrote: 17 Apr 2020, 13:12 Your 01 may be different, but taking that bracket down to inspect won't hurt a thing. There are a few (3, I think) plastic retainers that secure rigid brake/PS lines and one that retains the wire for your rear O2 sensor. Just squeeze those with a needle-nose to allow the metal plate to drop down. Remove the 4 12mm bolts & the plate should just drop down. There are separate "hangers" (#4) helping to hold up your downpipe/catalytic converter above this plate, so no worries about the flex joint.
I am suspecting the rigid brake line knocking on bracket. One plastic retainer was out.
Here is progress pix:
your lucky, you can easily update this to the newer version
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
xHeart
Post by xHeart »
darrylrobert wrote: 05 May 2020, 06:24
@darrylrobert - what do you mean^?
darrylrobert
xHeart wrote: 18 Apr 2020, 18:38 Cleaned off rust on the hanger and gave it a hight temp rust prevention coating. The two retainers are good, no crack or tounge damage. Inserting 2 rubber rollers as spacers around the hard brake line.
This part is subject to an update says VIDA. Looking at your subframe you dont need to drill holes to update new style bracket..lucky
darrylrobert
Sorry part number 4 is the updated bracket. its attached to the subframe instead of that (part 4) crossmember. The crossmember then only supports one brake line.
VIDA lists this part as a recall item or similar. Not sure what the design problem is, i replaced it because one of the (item 10) rubber mounts was torn. I had to drill holes into the subframe which wasnt easy.
Its definatly more secure than it was before, if your mounts are not torn then i wouldnt worry.
xHeart
Post by xHeart »
All weather ac port plug, and Viking trickle battery charger/maintainer from HFT.
xHeart
Post by xHeart »
Owner since June 2001, it is now over 200,000 miles on original tranny...
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
xHeart wrote: 31 Jul 2020, 09:47 Owner since June 2001, it is now over 200,000 miles on original tranny...
Any work like Servo, regular drain and fills and which fluid is so? Trans issues has kept me from looking at those years even if the car was in great shape.
xHeart
Post by xHeart »
MoVolvos wrote: 01 Aug 2020, 13:27
Same! Remembering JRL, he would assign junk label to all 2001 trannies. Never needed B4 Servo. Frequent Simple D&F using Mobil ATF 3309 has worked fo me.
All fluid carrying hoses and pipes were replaced. All seals and gaskets were replaced with OE/Volvo. Lubrication and Cooling systems were fully restored to factory.
xHeart
Post by xHeart »
xHeart wrote: 06 Apr 2020, 10:15
OK, great. All looks dry under the engine. Now, moving to this fix -- loud at the cat/flex connection:
xHeart wrote: 02 Feb 2020, 12:38
oragex wrote: 30 Jan 2020, 09:27 That would be good to listen with the hood open, may even use a hose at the ear approached carefully away from rotating belt/pulleys. I'm thinking maybe the tensioner is not adjusted on cold engine ?
Not sure how to upload an .mp4 file. Here it is... tapping audio/video sound under the carriage:
download/file.php?id=51383
The tapping noise remains an unresolved mystery. Here is a video clip taken from the ground on passenger side download/file.php?id=51383.
I am open to any pointer. Intermittently comes and goes away.
