Vida CEM swapping
sirloins
Year and Model: 2010 V50 T5 AWD M66
Been thanked: 3 times
Post by sirloins »
I didn't think I was spoiling the precision.. Instead of "1 latency == 1us" now "1 latency == 0.25us" ... So there is more precision?
I admit the naming in the patch/code is not great, I didn't know what to call it.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
sirloins wrote: 17 Feb 2022, 10:36 I didn't think I was spoiling the precision.. Instead of "1 latency == 1us" now "1 latency == 0.25us" ... So there is more precision?
In your patch - yes. In my patch I just collect the total CPU cycles, so the precision is even greater than in your patch. This is what makes me a bit nervous: cracks with precision improved only slightly, does not with a full possible precision.
May I ask you to collect the 720 logs w/ your patch and my patch, with DUMP_BUCKETS defined?
Cheapest 8690720 is $150 on ebay :(
sirloins
Post by sirloins »
Okay, sorry, yes I see what you are saying.
I am assuming the weighted product being used makes the difference, but let me get the logs and we can see for ourselves what is going on exactly.
vtl
Post by vtl »
Thinking about precision.
MCU runs at 8 MHz, each clock cycle is 0.125 us. It looks like egress CAN frame starts at arbitrary time, aligned to MCU clock rate, not CAN clock rate. In this case the other side (Teensy) will see a clock-accurate latency.
Of course, every signal has some noise. By switching the histogram resolution from 1 us to 0.25 us you make it functioning like a primitive filter that recovers a real clock cycles. In that case, using 0.125 us buckets would make it even better?
sirloins
Post by sirloins »
Attached are two logs from the first round of the first byte and part of the second round.
The correct byte is 13 for the first position.
I can run them longer or to completion as well, let me know if you think that would be useful.
P1-720-sirloin_patch.txt
(137.8 KiB) Downloaded 87 times
P1-720-vtl_patch.txt
(51.94 KiB) Downloaded 104 times
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
vtl wrote: 17 Feb 2022, 10:31 Didn't work... Interesting. And yet rounding the result up to a quarter of microsecond, or, in other words spoiling the precision in a terrible way, makes it work?
Spoils the precision or the accuracy?
Accuracy is how close the measured value is to the true value.
Precision is the smallest unit of measurement. ( how many decimal places ).
Active
Past
sirloins
Post by sirloins »
vtl wrote: 17 Feb 2022, 11:02 Thinking about precision.
Good points, let me try with 0.125us and the dump_buckets set. I will update the logs.
sirloins
Post by sirloins »
Ok, first of all, thanks for questioning why my change works... turns out I don't even know why it works lol. Lets get to the bottom of it.
When attempting to do the 0.125us change (ie set my LATENCY_RESOLUTION to 8 ) I found a bug in the change I submitted.
Specifically here (my change):
Code: Select all
/* maximum time to collect our samples */
limit = TSC + 2 * 1000 * clockCyclesPerLatencyUnit();
Recall this function returns clockCyclesPerMicrosecond / LATENCY_RESOLUTION... So by setting the LATENCY_RESOLUTION to 4 I was limiting the maximum time that we would wait for a sample.
Instead of the timeout being 2ms, it was now 0.5ms.
I should have left this alone since it is just a timeout.
So I fixed this, and set it back to:
Code: Select all
limit = TSC + 2 * 1000 * clockCyclesPerMicrosecond();
Interesting, now everything doesn't work again, even with the histogram in 0.25us.
So I tried your patch again vtl, this time with the following:
Code: Select all
limit = TSC + 2 * 1000 * clockCyclesPerMicrosecond()/4;
It works now. *edit: I also checked with this single change from the master branch and it also works
So this means the only thing making this work was limiting the timeout (limit) in the cem_unlock function. Now, obviously, we don't need the change I submitted, and I can log a bit more so we can create a more effective algorithm.
sirloins
Post by sirloins »
Attached are four log files.
p1_master_div4.txt - Master branch with: limit = TSC + 2 * 1000 * clockCyclesPerMicrosecond()/4;
p1_master_div4_full.txt - full log to completion of the above file.
p1_31254749_div4_full.txt - full log on my 31254749 (in car)
p2_master_nodiv.txt - Master branch, no changes.
p1_master_div4.txt
(69.63 KiB) Downloaded 114 times
p1_master_nodiv.txt
(42.78 KiB) Downloaded 90 times
(398.33 KiB) Downloaded 97 times
P1_31254749_div4_full.txt
(122.01 KiB) Downloaded 86 times
Sh4rp
Year and Model: See below.
Has thanked: 2 times
Post by Sh4rp »
With the code change sirloins proposed I was able to crack my 8690720 CEM.
2004 - V50 T5 AWD M66 - Flint Grey
1996 - 850 T-5R M56 - Dark Olive Pearl
