I wish one of us was closer to do your oil change for you and troubleshoot your warning. Hopefully you can keep putting some miles on to burn through the old gas.gnalan wrote: 23 Feb 2022, 01:08 Monday I got my S60 back up and running, and even drove it a little. Took it out for a longer drive on Tuesday.
It's been sitting since September, and I had to charge the battery from a completely dead state. Thankfully the battery isn't very old and sprang back to life with the charger I used. The full tank of gas may not be in the best shape, judging by the way the exhaust smells, and the way the car drives. Plus I keep getting the drive slow urgent service required message popping up on the dash. The laptop I have no longer works, so I have no way of checking with my DiCE and VIDA to see what's going on. I'm hoping it's just the bad gas, and once I can run some fuel system cleaner, and new gas, through it that it'll be back to where it was before it was parked.
An oil change will be next on my list, when I'm able to get up and down from the ground. I still have limited range of motion in my knees, and I walk with a cane, so trying to get down or up from anything any lower than the driver's seat isn't an easy thing to do yet.
I also need to schedule to have my airbag replaced, so that's on my list as well.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- gnalan
- Year and Model: 2001 S60
- Has thanked: 557 times
- Been thanked: 135 times
I appreciate that. I'm assuming the warning is just from the bad gas, but if I can get an extension cord plugged in, and drug out to the car to power my laptop and battery charger, I can see what's going on.Krons wrote: 25 Feb 2022, 22:15 I wish one of us was closer to do your oil change for you and troubleshoot your warning. Hopefully you can keep putting some miles on to burn through the old gas.
I'm planning on putting some more miles on it this weekend, and next week. Still just doing short trips of around 20 miles or so at a time around town (that way if I happen to break down I won't be too far away from home).
I don't trust regular oil change places, so hopefully it'll be ok until I can change it. I already have plenty of new oil filters, orings, plus a new filter housing and oil drain bolt if needed.
I'm wondering if I should wait until I'm down to the gas light coming on before I fill the tank back up or if I should add new gas before then. The way I'm thinking is I should run as much out as I can before adding new gas to the tank so there's less old gas running through the engine since it won't continually get diluted and run through over a longer amount of time. I don't know which would be better. Any thoughts?
- Krons
I don't trust the oil change places either...unknown filters/oil and I've had a couple drain plugs I swear had an impact on them.gnalan wrote: 26 Feb 2022, 00:28I appreciate that. I'm assuming the warning is just from the bad gas, but if I can get an extension cord plugged in, and drug out to the car to power my laptop and battery charger, I can see what's going on.Krons wrote: 25 Feb 2022, 22:15 I wish one of us was closer to do your oil change for you and troubleshoot your warning. Hopefully you can keep putting some miles on to burn through the old gas.
I have had the same question on fuel when my motorcycle hits the off season. I like to keep the tank full to prevent condensation, so even with Stabil can be a few months old as it is used. Personally I'd run at below 1/4 tank and top off with a high quality gas plus a bottle of Techron or Marvel Mystery Oil to give the fuel system a clean. Maybe Stabil too if you won't be driving a lot. At some point worth changing your fuel filter if you haven't. My 2002 S60 had an external one on passenger side back by the tank...was not bad to change, not sure on your 2000. Steel and plastic tanks had different filter setups.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- gnalan
I changed the fuel filter less than 1,000 miles ago. Easy job to do, thankfully. 2001 is in the same place.Krons wrote: 26 Feb 2022, 06:25 I don't trust the oil change places either...unknown filters/oil and I've had a couple drain plugs I swear had an impact on them.
That's what I was thinking, too. Run it down as low as I can, add a high level detergent fuel cleaner, fill it back up with the same 93 octane I normally use, that's ethanol free, and, if needed, change the spark plugs again (also with less than 1,000 miles on them).
I did make sure the tank was full before parking it, but forgot to put any Stabil in it.
- Krons
You should be fine. Even with no Stabil a non-ethanol 93 should be good for 6 months or more. I have a motorcycle riding buddy who never used Stabil on several bikes (just good non-ethanol Premium) and claims to never have a fuel problem. I'd be shocked if spark plug are needed, shouldn't hurt them to be sitting.gnalan wrote: 26 Feb 2022, 07:00 I changed the fuel filter less than 1,000 miles ago. Easy job to do, thankfully. 2001 is in the same place.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- Has thanked: 1613 times
- Been thanked: 4077 times
My T5 sat for 2k months with ethanol87 in it, started and ran fine
Bad gas is usually a fools ( fuels) analysis
- gnalan
2,000 months? That's a pretty long time lol.abscate wrote: 26 Feb 2022, 08:54 My T5 sat for 2k months with ethanol87 in it, started and ran fine
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
I agree, there’s unfortunately a lot of wasting of money running non-oxy in a modern fuel injected car (that gets driven regularly). I could see keeping non-oxy in it if the car was going to be in a climate controlled storage for an unknown amount of time. I say that because if you are storing something in a non-climate controlled environment the temp swings from day to night will create condensation in the fuel/tank regardless of what kind of fuel (ethanol or non) occupies that space.
The alcohol in ethanol fuels will actually help keep your injectors cleaner. I ran non-oxy in a Mazdaspeed6 for a long time. Periodically (every 4-5 fills of non-oxy) I would have to run a tank of ethanol 92-93 because my injectors would get loaded up & engine would get bucky. Running a tank of Ethanol cleared it right up. I did this over about 2 years, averaging about 30k miles per year. This was a direct injected MZR engine.
Non-oxy is great for small engines, boats, motorcycles, old carbureted cars/trucks & the such but doesn’t really make sense to run it in a fuel injected car. Not saying this to degrade your decision or belittle you, just trying to give some friendly advice to save you some money on fuel.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Well I’m sold. Only putting 87 in from now on with these crazy fuel prices.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- gnalan
Stopped and had the battery and alternator tested on my car. Both are ok, but the battery still isn't fully charged. I guess my short trips aren't enough to finish topping of the battery, and trying to keep the rpms up to spin the alternator faster makes my drive slowly service urgent message pop up (which goes away when I drop the rpms back down). I'll throw it back on the charger to finish charging it all the way, then see if it runs normal again.
One odd thing I've noticed is I get a message that my right turn signal bulb is out, and the fast flashing dash light, but the longer I drive, and the voltage starts to come back up, that message goes away and all of my turn signal bulbs work just fine.
- 12198 Replies
- 1679143 Views
Last post by RedBrickCollector
- 97 Replies
- 209623 Views
Last post by br0dy519
- 59 Replies
- 61435 Views
Last post by smacknab
- 6946 Views
Last post by xHeart
- 12188 Views
