It is a CAN simulator. Use to test CAN devices and software under development. Like a flight simulator, i produces the environment and experience without the real thing. It has limits it is not going to respond to a CEM crack the way a real one would.gnalan wrote: 21 Dec 2020, 14:14 Has anyone tried the above program? Not sure if it'll give you the codes you're looking for, but it seems to be a decent program.
Vida CEM swapping
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
jcdillin
- Year and Model: 06 V70R
- Been thanked: 3 times
Ok, so I picked up a Teensy 4.0 and a couple 3.3V can transceivers. I'm testing this all out on a spare CEM on the desk before I unleash it on my V70R.
I have the CEM powered up with the following wires.
Brown Wire (D6) = Ground
Large Red (E:A) = Constant 12V
Large Red (E:B) = Constant 12V
Yellow (D15) = Switched 12V
Violet (D8) = Switched 12V
Blue-Red (D16) = Switched 12V
I have the can transceiver connected to
White CAN-H = (D:33)
Green CAN-L = (D:48)
So when I apply the switched 12V, relays click and the unit starts drawing ~400mA.
I start the teensy and get the following. I double-checked and I am connected to the HS CAN pins from the DLC.
Is the teensy 4.0 code not reliable yet or am I missing something?
Code: Select all
CPU Maximum Frequency: 600000000
CPU Frequency: 180000000
Execution Rate: 180 cycles/us
Minimum CEM Reply Time: 30us
Platform: P2
PIN bytes to measure: 3
Number of samples: 30
Number of loops: 1000
Initialization done.
sending CEM into programming mode
send: ID=000ffffe data=ff 86 00 00 00 00 00 00
recv: ID=0042406c data=80 88 00 00 60 00 a0 03
recv: ID=0042406c data=c0 a8 00 00 60 00 a0 03
reading part number
send: ID=000ffffe data=50 88 00 00 00 00 00 00
recv: ID=0042406c data=c0 88 00 00 60 00 a0 03
calculating bytes 0-2
Timeout waiting for CEM reply!
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Start the Teensy first, wait for "sending CEM into programming mode", then immediately power on the CEM. CEM on the bench needs to see the ff 86 message in the first 20 ms or so, otherwise it goes into standby mode.
- 9221 Views
Last post by RickHaleParker
- 9137 Views
- 27 Replies
- 28331 Views
Last post by cn90
- 10596 Views
Last post by jonesg
- 5733 Views
