Yup, as abscate says, carrier bearing.
P2 front wheel bearing Timken, SKF or FAG ? 31329980
- Has thanked: 2199 times
- Has thanked: 311 times
- Been thanked: 817 times
On Monday the shop looked at it. Same guy still running it, which is great. The only info I gave him was "noise with rotation" and he came back with "you've got a bad RF wheel bearing, no charge for diagnosis but cost for us to do it is just under $600."
So Monday night and Tuesday night I did the bearing job (FAG). Once the old one was removed it was more obviously bad - felt dry and a little rough when turning by hand. I spent at least an hour cleaning corrosion from the hub interior, that was not pleasant.
By comparison to before, the car rolls whisper quiet now 0-45 mph. Highway testing to come but I'm calling this one fixed.
I'll have to follow up on the tick in the carrier bearing. I was unable to alter that sound by oiling the bearing.
Volvo horns!vtl wrote: 16 May 2022, 04:57 My observation is the right side (passenger) bearings fail first, followed by the driver side somewhat shortly.
I may do the drivers side soon, preventively, partly just get it done before another season/year/etc. of corrosion to the hub. We drive this XC70 the most among the fleet.
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
My front hubs both failed at ~150k miles, passenger side just a tad earlier. Later they were transplanted to a donor body. The donor had the rear hub failed at 245k miles. I thought it was the old dirty one and replaced it, just to find out I replaced a good, solid factory installed wheel hub that still was snug and quiet. The real problem was a new shiny Optima wheel hub on the other side, installed by a P.O. only ~30k miles ago and already falling apart.erikv11 wrote: 18 May 2022, 11:34 I may do the drivers side soon, preventively, partly just get it done before another season/year/etc. of corrosion to the hub. We drive this XC70 the most among the fleet.
Oops I'm saying hub where I mean "steering knuckle." The knuckle surface had a lot of scale/corrosion buildup where the hub bearing mounts.
Car sits at 185k, may be time ...
Awarded for the careful, correct diagnosis and repair of a Volvo with verve and élan.
It pays not to russet those jobs…
- 56CB85B4-8814-4267-A6CD-DB29082784EB.jpeg (58.88 KiB) Viewed 4371 times
I noticed you swapped sides from the initial diagnosis. Doing the wrong side would suck potatoes and eggs. Any insight other than running it up in the air?
- famfeld
- Year and Model: 04 xc70
- Has thanked: 9 times
- Been thanked: 6 times
FAG worked well for me 25k miles ago. Don't forget the inner dust protector as mentioned above (not sure if they are really important, but I always put them back or replace if they are damaged). FCP euro, for the most part doesn't sell poor quality parts, also lifetime warranty so as long as the labor 8s not too involved its low risk. This job is not that bad imo.
Yeah, I became uncertain on which side and that led me to put it in the air, for the most part. Then even after running it up the air and deciding on the right side, I couldn't confirm that from inside the car, running straight or by swerve test. Really wanted the noise to change with load/unload but it wasn't happening. So for this one yes, the critical test was getting the wheels up and getting outside the car. I checked all four.abscate wrote: 21 May 2022, 01:14 I noticed you swapped sides from the initial diagnosis. Doing the wrong side would suck potatoes and eggs. Any insight other than running it up in the air?
The original dust protector fell to pieces when I popped the axle out of the hub during the job. I agree, always have a new one on hand if the axle is leaving the hub.
