Hello again,
Thanks for the replies i'll keep all this in mind for the future.
I did make a silly mistake though. I measured the oil LEVEL with the dipstick while the engine was still warm just shut down a couple minutes. That means the oil level looked lower than it really was. It was actually just 1/2 quart down but it's been like that for over a year now so it cant be triggering any stall symptom, unless maybe some sensor was bad i guess. If there is no sensor that can do that though then that cant be a problem.
Can the ECU detect low oil 1998 v70 ?
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Thank you for your answer.BEJinFbk wrote: 10 Nov 2022, 11:50 Being a quart low is not gonna cause a stall.
If it did, you’d have much bigger problems.
Any Check Engine Light? OBD ll codes?
Regarding whether or not the sensor and
warning light are tied into the ECU, have
you downloaded the manual of schematics?
It should be clearly indicated therehappy wheels
Volvo Technical Publication TP 3932202
- 693 Views
Last post by xc70dude
- 16 Replies
- 4434 Views
Last post by ZionXIX
- 11 Replies
- 3121 Views
Last post by tryingbe
- 4424 Views
Last post by Clemens
- 2414 Views
Last post by shaker_chi
