Drove the car for ~ 10 miles, slight miss under power in one cylinder. Let sit overnight.
Compression cold, dry: 220 / 215 / 220 / 215 / 215 Beautifull
Took the car for another, "more spirited" drive, miss seems to be clearing up. Lifter tick calmed down too....
I think this project is done. Thanks to you all for a marvelous site and your moral support.
P.S. Guinness still on ice, I will drink them at my leisure.... they will not go to waste.
98 S70 Low Compression after Timing Belt
- Been thanked: 4064 times
Never on ice for a Guinness.
42 Fahrenheit, 6 Celsius
Note the convergence of the first perfect number with the answer to the question of the Universe
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
So I guess we could say that everything has been solved with a liquid of some sort
( For me, it's Guinness in a frosted mug. Heresy I know, but damn orthodoxy !)
1999 V70 GLT
1999 V70 GLT
arnermd
- Year and Model: 1998 S70
- Has thanked: 7 times
- Been thanked: 6 times
Took it for a 25 mile ride today, slight miss under power when cold, but clears up when the temp comes to normal. Other than that it seems to run great.
Re Guinness on ice.... you are correct of course, stouts are better chilled and not ice cold. I drink em slow though so I start a little cooler... time weighted average temp.
Not sure what the actual fix was, me cranking it through every day to take compression readings or the seafoam... maybe both. The world may never know....and that's OK.
Again... Thanks to you all.
- Has thanked: 2197 times
- Been thanked: 1850 times
The poor cold running could the the ECT (coolant sensor). It acts like an old fashioned choke/enrichment device until the engine comes up to temp. It may not be doing it's work and causing the cold engine roughness.
- 1723 Views
Last post by Livens
- 1193 Views
- 23 Replies
- 17035 Views
Last post by jonesg
- 862 Views
Last post by precopster
- 23 Replies
- 6345 Views
