where do you keep your phone in your 850?
Has thanked: 2205 times
Been thanked: 1852 times
Unless you are using the phone as a GPS, do as I do and leave it in your pocket or in the glove box. Problem solved!
I have fitted a bluetooth head unit in my Toyota which allows programming of the steering wheel buttons. That way I need absolute minimum eyes off the road. For our 2 Volvo's no Bluetooth so phones not in use while driving.
As for GPS, seldom use it but I have a windshield stick-on Garmin that works fine.
duke1
Year and Model: 855 1994 10v
Has thanked: 416 times
Been thanked: 34 times
Post by duke1 »
P80GLT wrote: 25 Mar 2024, 01:21 I keep mine in my pocket. If anyone calls me while I'm driving they can leave a voice mail and I'll call them back when I've stopped.
same and i think a pocket in my jacket hanging in the back so no chance of getting nicked for using it whilst driving,i just got a tom tom sat nav given to me i been testing and is much better than a phone!as i get older and roads keep changing i sometimes have to count on it finding the way home.cheers
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
I use magnetic ones that clamps on the vents in all my cars, the V70 and the Subie have thick enough vents to support them.
The 940 however has thin ones (similar to an 850iirc), which eventually broke off. To avoid breaking them again when I replaced the vent, i made a small 3d printed support to replace the clamp that just slides between the horizontal vents from behind. It does stop them from being adjustable, but i dont really mind it.
Cant find a picture so here's the 3d model
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
ZionXIX wrote: 06 Apr 2024, 17:08
tjmartin317 wrote: 06 Apr 2024, 15:12 I lean it on the plastic of the gauge cluster, blocking my Speedo. It’s not like I need to know how fast I’m going because there’s no way I’m speeding in my NA S70 lol
I have done that in the past for navigation. It fits rather snugly.
I'm going to have to try that. It's not often I have to use GPS, but every once in a while I get to go someplace besides work. :roll:
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Clemens
Has thanked: 500 times
Been thanked: 228 times
Post by Clemens »
So I bought one of these clamp to the vent units, but the vents just don't support the weight of the phone. So Instarted hacking and came up with a nice solution that has the phone near enough to speak while driving and have Waze online to warn me of speed traps.
I used a blank switch hole cover and mounted half the phine mount to it. I just had to relocate some of the switches a bit.
1996 855 R,
2010 V70 D5,
atucker1
Year and Model: 1995 850 Turbo
Has thanked: 11 times
Been thanked: 15 times
Post by atucker1 »
I second under the parking brake! Fits perfectly
1995 850 Turbo, Sedan
1996 850 N/A, Sedan
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
The best mounts are from Kuda. They are fiberglass, custom designed for each year/make/model, wrapped in leather which matches interior trim. I had one on my 2002 Mercedes E320 and it looked like a factory accessory. Their 850 mounts appear to be available, including a lovely side mount. I remember buying one from a USA based branch of Kuda, not the German site I linked, so look around for that. I mounted a ProClip holder to the base by carefully drilling mounting holes into its fiberglass frame, then using screws and nuts with threadlock to hold it in place.
ZionXIX wrote: 04 Apr 2024, 20:25 Proclipusa used to make one that attached to the right side of the centered area. It wedged itself between the dash pad and the dashboard and did not block any vents. I don't see it available anymore.
ProClip is great, offering dashboard mounts designed for each specific year/make/model of car. I have been using one in my 2000 V70s since I first got the car in 2002. The model I use, #852426, snaps into the trim gaps above and below the air vent, blocking some of it. A totally fine trade off since it puts the phone up close to the windshield requiring minimal eye movement from the road. I ordered two more last year so they are available, though took a while to arrive.
The 850 mount which similarly goes over the vents, #852127, appears to be still available. The side mount one which ZionXIX mentioned appears gone. Anyone who wants it might try asking ProClip if they could still make one, since I suspect they make the old ones on demand. VPrints, maybe this is a part you could redesign. ProClip cuts their mounts out of thick slabs of plastic, gluing them together as necessary. I bet they stopped making the 850 side mount one because it required too much gluing and demand was too low.
FireFox31
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
I put mine in the ashtray too, nice and secure there.
Long term though I plan to have my dashboard/dashpad repaired and I'm considering a permanent mount for either a phone holder or some sort of Android Auto screen. Either flip up from the center, over the vents, or maybe something in front of the A/C controls since they mostly don't work.
The first option I feel is better in terms of field of vision, the second would look like a cleaner install.
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
juicywheat
Post by juicywheat »
I have a Belkin MagSafe holder that sticks to the ac vent. With my MagSafe it works perfectly. No need to fiddle with the clamp. I see products that sticks to the windshield but I like mine that sits right in front the vent since phone can overheat easily from the sun. The holder cools down my phone very well.
Clemens
Post by Clemens »
I finally got that Kuda Phonebase unit. It fits excellently.
1996 855 R,
2010 V70 D5,
