high miles 2011 xc90 3.2L rich/lean
- Has thanked: 1611 times
- Been thanked: 4075 times
Put on 4 new denso oxy sensors, ….again. Only code now is p0430. Bank 2 cat. Still smells rich…
Long/short trims all normal around 3-5%…
2 new aftermarket cats installed.
Bank 2 upstream voltage is steady at .95-.99 volts, and bank 2 downstream cycles up and down from .3V to .7V.
stubbornly still throwing the 430?
Update: I've finally fixed it. The initial 2 upstteam lambda sensors (A/F) sensors I put in, came in Toyota boxes... but had the correct Denso part number on them. I put 2 new upstream A/F sensors on it from FCP euro, and it fixed all my problems. All indications, including Denso website, say they cross... I don't know, my Volvo XC90 didn't like them. Both types of sensors showed normal values plotting in VIDA
Good part from FCP Euro lamba A/F sensor: Denso box; DOX-0526, no number stamped on actual sensor.
Bad Part XC90 didn't like: Toyota box with 234-9151, Denso 30713864 and 234-9151 stamped on sensor.
All those numbers cross.... so I have no idea. But it runs great now, no lights or codes. Didn't have to go to the dealer.
- 517 Views
Last post by MagneB
- 1600 Views
Last post by kcodyjr
- 14 Replies
- 4246 Views
Last post by chitownV
- 19 Replies
- 5661 Views
Last post by Sommerfeldt
- 1823 Views
Last post by Gdane4x4
