A throwout bearing makes noise when the clutch is OUT (engaged)
It's usually quiet when depressed
Considering a Volvo or another Mercedes
Volvo Wagon or Mercedes Wagon?
chuckcintron
- Year and Model:
Could be a worn pilot bushing, too much slop on the output shaft, allowing the plates to rumble around down there...just a guess...
-Chuck
-Chuck
1997 855GLT
- volvoaddict007
- Year and Model: 760 Turbo
JRL wrote:A throwout bearing makes noise when the clutch is OUT (engaged)
Bottom line is clutch or something is not good making that noise when the clutch is in.
...It's time for volvoaddict007's....
If we remove the word 'good' from the sample sentence the new sentence would then read:
"Bottom line is clutch or something is not making that noise when the clutch is in."
Just messin' with you Equinutok and JRL... You are right. I believe you are referring to a 'dry' bearing which is what I was referring to as can last for a long time. It's when that bearing makes a lot of noise when depressing the clutch as to bad news time.
It's been about 25 years since I had a bad throwout bearing. But IF I'm not mistaken, ( always a good possibility ) a FURTHER deteriorated bearing will make more noise when depressed as I believe is what you meant with your itallicization of the word usually.
VOLVO OWNERS WARNING: volvoaddict007's posts are meant for entertainment purposes only. Always ask a real mechanic before taking his 'advice' seriously!!!...
1990 5 speed 760 Turbo Wagon 310K.
( '91 940 turbo eng. + trans.)
Konis, diesel springs, 2.5" exhst., 850 T5 wheels
1993 300ZX 2+2, 171K
1999 Ford Windstar LX, 90K
- Year and Model: Many Volvos
- Been thanked: 76 times
Holy thread bump!
There is a 99% chance that you ABS problem is the ABS module itself. All of the post '95 modules fail at some point.
You can either get the module rebuilt by Victor Rocha, Module Masters, or the eBay guys. If you are decent with a soldering iron you can fix it yourself for free.
https://www.matthewsvolvosite.com/chat/p ... 6827#46827
PS - I am not a moderator here or anywhere else but you might just want to post a new thread the next time you have a problem unless it is a real current thread that you are jumping in on.
- Has thanked: 2857 times
- Been thanked: 1332 times
TomPaol, please use this thread:
https://www.matthewsvolvosite.com/chat/p ... hp?p=56950
I'm going to delete your, Ozark's and my posts here later today so as to leave this thread like it was.
Thanks!
Matt
Thanks!
Matt
- 3528 Views
Last post by Fishman009
- 34 Replies
- 4131 Views
- 1691 Views
Last post by erikv11
- 1260 Views
Last post by alschnertz
- 388 Views
Last post by T64me
