My MEYLE-HD arms and end links still look as good as new a year later and are working perfectly.
Chris...
Ball joint/control arm survey
Ball Joint / Control Arm Survey
precopster
- Year and Model: Lots
- Been thanked: 128 times
For the '99 V70 I'm rebuilding I went & bought some used '94 model 850 aluminium control arms (the bushes were perfect) and replaced the ball joints with Meyle brand. BTW the Meyle end links are 1mm wider than stock and very well made.
We're fortunate around the suburbs here in Melbourne as the roads rarely have potholes and when we do have them they're pretty shallow. I found 2 sets of aluminium control arms that I will rebuild with ball joints and/or bushings.
Just for the record I have a '95 850 with 82K miles that is still running the original control arms (that's 17 years)
db130
- Year and Model: 2002 V70 T5
i have a set of 93-94 aluminum control arms sitting in the basement with the bushings already having been pressed out
i am waiting for set of powerflex poly bushings to arrive and i will be installing moog ball joints.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Bilstein/Febi, Lemforder. I've found these brands to be pertty much OK. I used Lemforder parts on my 85 MB diesel and the parts I put in have been fine for at least the past 100K.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
rmmagow
OTOH FCP offers lifetime on all their parts right? Buy cheap and do it over every few years.
precopster
Read the fine print. Warranty only applies when fitted by certified mechanic.rmmagow wrote:OTOH FCP offers lifetime on all their parts right? Buy cheap and do it over every few years.
I did the same. My A arms were not rebuildable; went to the wrecking yard and got a set of 93 aluminum A arms. I replaced the bushings (forgot the brand) and ball joints with Moog balljoints. I have used Moog suspension parts on several cars i have owned over the years and they have never let me down. I actually prefer Moog over factory suspension parts; however I am new to Volvo cars. For some reason my 850 had the non-rebuildable A arms, they were OEM. What I noticed about the Moog Volvo balljoints was that the rubber boot was a little thinner and did not have the zerk fittings that the previous Moog balljoints I replaced on other makes had. Still, I am confident that they will last.db130 wrote:i have a set of 93-94 aluminum control arms sitting in the basement with the bushings already having been pressed out
I'm also interested in this thread. Things seem especially bad for the cars with the newer 4-bolt design like this:
The bushings /are/ available, but so far the best price I've found for them is about $40US/per, so that's $80 to do one side of the car.... and there's still no way to replace the ball joint! It's hardly worth it at that point.
I checked to see if the similarly-shaped front bushing on the P2 cars would fit, but it turns out it's much too large in both dimensions (around the bushing and between the bolt holes).
I considered trying to make a custom control arm with replaceable parts from DOM steel and parts from a controls supplier like Midwest www.midwestcontrol.com/
However, I'm not only NOT a trained welder, but I don't even own or have access to a small hobby welder. There's no way I can do this on my own and when I approached a local shop about it they backed away immediately - I think they were concerned about liability issues.
I envisioned something like the lower control arms pictured here:http://www.trzmotorsports.com/images/315/315set.jpg
They would certainly be more expensive than one set of control arms, but you'd likely never need to replace any of the various joints, and you could design it around a common (GM?) ball joint that would be cheap to replace, so it wouldn't take long to recoup the cost.
I currently have a Deeza from RockAuto.com on my passenger side and I have to say it seemed to be very high quality. We'll see how it holds up I guess.
Just had new control arms (OEM) put on a new addition to the family fleet (97 854 GLT) and the car feels like a new car they way it feels. I also subscribe to the school of OEM parts for these cars. The trick is to find the best rates on parts so you can afford OEM over aftermarket. I just put a fresh set of Nivomats on my 96 Platinum wagon and the ride is back to what it ought to be. I have had good luck with prices from Tasca Parts in RI. I got the Nivomats for $214/each which was a huge savings over the local dealer.
2019 XC60
1997 854 GLT (sold)
1996 855 Platinum (sold)
1994 854 GLT 5 speed (sold)
1995 854 (RIP saved my kid)
2005 V70R (sadly missed)
1998 V70 AWD (sold)
1997 854 GLT (sold)
1998 V70 AWD (sold)
- 4712 Views
Last post by oragex
- 15 Replies
- 3727 Views
- 4152 Views
Last post by Tonyx
- 12 Replies
- 5605 Views
Last post by darrylrobert
- 7187 Views
Last post by BrianV70
