-40C loss of boost
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Re: -40C loss of boost
Post by BEJinFbk »
IVIUSTANG wrote:It was minus 37C today and my car sat outside for 7 hours facing the wind. It started pretty good, but it sure felt like a brick. The boost loss must have been a fluke as it is working 100% now. I can really feel the transmission and brake fluids being really stiff though, does dot 5.1 and synthetic transmission fluid help with this? I already run 5w30 synthetic oil which I strongly credit with unassisted cold weather starting. I normally park in an unheated garage which helps ALOT, but was in the countryside today... -37C makes things so stiff!
- Jesse
That sounds familiar. Love those rock hard seats...
But, "Unassisted?" I sure hope you're plugging in at those temps!
Cold starts at temps that low are Not Good for the engine, regardless of oil.
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
I park indoors usually, but the odd time I have to park outside and my car isn't plugged in. Such was the case in -40 the other day.
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
BEJinFbk
Post by BEJinFbk »
IVIUSTANG wrote:I park indoors usually, but the odd time I have to park outside and my car isn't plugged in. Such was the case in -40 the other day.
- Jesse
If I'm outside for any length of time at less that 20F above, I plug in.
Fairbanks is in a bowl that's subject to temperature inversions, so
we try to keep the emisions to a minimum. A warm engine helps loads.
AND, a warm engine and a pan fulla warm oil is Cheap insurance for
a car that I really enjoy. I want it to last forever! It's Great for this town.
Heated seats, AWD and the ability to squirt ahead and stay outta trouble.
8) Oh Yeah... Accept no substitute!
At home, I've got the same unheated garage situation. It really does
make a huge difference. It's usually well above outside temps.
Just kinda of a pain to work on the car in. I've gotta set up heaters for that.
But best of all, I don't have to brush snow and scrape ice! :mrgreen:
monty
Year and Model: 2000 V70XC SE
Has thanked: 2 times
Post by monty »
Changed out my TCV to the Acdelco TBCS and car is a lot better now. TCV looked to be original!
'00 XC70 SE 240,000mi. - a real car
IVIUSTANG
Post by IVIUSTANG »
This low temperature loss of boost is still plaguing me on occasion. Yesterday my car was undriveable above 2000 RPM for 20 minutes; got way better as the car warmed up. Is there a permanent fix for this problem? My car wouldn't go below 15" of vacuum at first, it was brutal.
- Jesse
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
A new set of turbo hoses may help. It sounds like one is freezing up and collapsing, or that darn intercooler's freezing still. Stylin Motors has a cool set of silicone ones I've been wanting to get.
'98 S70 T5
2016 Chevy Cruze Premier
palebird
Year and Model: 1994 850 Turbo Wagon
Post by palebird »
I am having a hard time with these collapsing turbo hoses..how can a hose collapse if the turbo is boosting atmospheric or higher, which is what it does normally ? As far as the power problems in cold weather I have experienced the same thing and it is the intercooler freezing up on my 850, was about - 20C when I really noticed this, it would idle but that is all till the rad warmed up and, in turn, warmed up the intercooler.. I had a 900 16 valve Turbo Saab for years and never had this problem with the intercooler, even in -40 weather.
kcodyjr
Year and Model: 2006 S60 2.5T AWD
Has thanked: 17 times
Been thanked: 23 times
Post by kcodyjr »
I've never encountered this personally, but maybe it's worth taking the intercooler out, bringing it inside, and sloshing it out in the bathtub? Maybe tape a hairdryer to one end and force some hot air through while the unit itself is good and warm?
- Kevin
5 others that came and went
IVIUSTANG
Post by IVIUSTANG »
palebird wrote:I am having a hard time with these collapsing turbo hoses..how can a hose collapse if the turbo is boosting atmospheric or higher, which is what it does normally ? As far as the power problems in cold weather I have experienced the same thing and it is the intercooler freezing up on my 850, was about - 20C when I really noticed this, it would idle but that is all till the rad warmed up and, in turn, warmed up the intercooler.. I had a 900 16 valve Turbo Saab for years and never had this problem with the intercooler, even in -40 weather.
My thought exactly, I also don't understand how a boosted line could collapse?
- Jesse
jblackburn
*shrug* I don't know the physics of it, but I have seen it happen to my friends Subaru on cold mornings. That was the same morning my Honda's little carburetor just froze up and wouldn't start. The hoses are just a suggestion anyway :mrgreen:
Most likely still the intercooler though, if you're not having trouble except when it's really cold. Kevin had a good suggestion trying to get all the liquid out of the intercooler by taking it out and cleaning it. Someone, I think it was Klaus, suggested plugging up the bottom hole and filling it with soapy water and letting it soak for a few minutes, then rinsing it thoroughly, letting it dry, and then reconnecting it.
A plug-in heater might be something you could look into to avoid that problem and help your car warm up easier in the mornings.
'98 S70 T5
