1996 Volvo 850 will not start in cold
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Re: 1996 Volvo 850 will not start in cold
Post by misha »
Before condamning an ECT...carefully inspect the connector for corrosion and check if it is fully "home".
I had never seen an original ECT failed on it's own....it's usually a connector or it's wiring.
Mine is still original.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
misha wrote: 10 Jan 2019, 09:51 Before condamning an ECT...carefully inspect the connector for corrosion and check if it is fully "home".
We've put 3 on the S70.
The resistance specs for temperature readings are somewhere around here on the site to confirm if it is/isn't bad.
'98 S70 T5
2016 Chevy Cruze Premier
Has thanked: 1498 times
Been thanked: 3810 times
Search P80 ECT resistance and Ye shall Find:
viewtopic.php?f=1&t=79330&p=427389&hili ... ce#p427389
VdubTheran
Year and Model: 1996 850 sportswagon
Post by VdubTheran »
Where is the ect located and do you know how much one costs? i would think it would be one of the cheapest parts to replace.
jblackburn
VdubTheran wrote: 10 Jan 2019, 10:00 Where is the ect located and do you know how much one costs? i would think it would be one of the cheapest parts to replace.
Just under the thermostat housing. If you have a multimeter, check the specs abscate linked above on a cold engine in temps you'd normally have trouble starting in.
Looks like it's in the $50-60 range now.
'98 S70 T5
Follow the upper radiator hose on the right side of car, left as you face the engine, towards the rear of the car.
When you reach a metal part,the ECT is bolted into that, under the hose.
You will need to catch or replace the coolant you lose when you unthread it, an don’t let that coolant run into the alternator
VdubTheran
Ect 8.31 in 20k thats 16k right? The connections are loose and some corrosion. Its 28* outside temp, ect reads 30*f, on dash reads 29*f batt at 13.7v it tries to start thats with donor car hooked up to batt cranking at 10sec intervals with 1min plus in between. No start yet after about 10min ect reads 33*f, it seems to be working well enough. Still no start
misha
Post by misha »
jblackburn wrote: 10 Jan 2019, 09:54 ...We've put 3 on the S70.
Mine is still original...300k+ km,right within spec(just like new)...i'm checking it every 3rd year (just in case)when time comes for coolant replacement.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
VdubTheran
I got it started, it started really rough though. Im letting it warm up, then i will erase codes and check again. But i do think that the plugs, wires, cap and rotor need to be changed; i havent replaced them because when i bought the car 4 years ago they were new.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
In our '97 850 there is a IAT sensor #6A with barn door located where fresh air enters the air box. Unless it's a myth, to assist with colder condition cold-start the barn door closes and then a more friendly temp air is drawn from via the silver foil tube.
Item 20 in this diagram:
Penzzoil EURO 5W40 motor oil worked this morning too.
