A photo is worth a thousand words. Thanks for posting them.
Another useful note for this specific case. Installing the spring correctly as depicted in the photos is much more difficult than installing it incorrectly. It requires much more effort and great care to install the spring correctly.
Remember: "If it was easy you probably installed it wrong"
S60 No Pedal after Changing pads & rotors
tulrazorback
- Year and Model: 2001 S60
Great sight and thanks for posting your issue. I had installed the spring incorrectly on my 2001 S60. I new it was something I did but never figured something so small could cause such a major issue. I was about to spend major dollars on a master cylinder or brake booster.
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
I saw a used S60 for sale and lowered the sale price by $1000 because he had the same poor brake response because he put the springs on wrong. Bingo!
Offshoregrass
- Year and Model: V70 2004
Excellent,
changed my brake pads this weekend and had almost no brakes. Exactly as described in the post.
Found post this morning, borrowed screwdriver and plyers over lunch and 10minutes later the clips were in correct position without even taking the wheels off. 5minute test drive later and everything ok.
Thanks to all contributers especially E170 for the pics
Ch
Ch
Unrelated to the springs but referring to the op's question if there is something special about bleeding ABS, I learned the hard way on an early Audi A4 that you always bleed ABS equipped vehicles with the engine running, not sure if that still applies to these newer Volvos but don't see how it would hurt either.
Greetz, Ben
Greetz, Ben
‘14 BMW i3
‘09 BMW 535XiT
‘09 BMW 535XiT
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Why do you say that?
Jan: The picture you posted of the correct disk pad retainer spring position is MONEY !! I had the "squishy petal" syndrome after changing my pads, and it was the retainer spring problem.
Amazing that just such a small difference in a little spring makes that much difference to the brakes.
Wildman
2001 S60 2.4T @110K Miles
- regent
- Has thanked: 2 times
- Been thanked: 12 times
This is one very useful thread. I find it very encouraging cause I have gone through the same brake spring exercise: We create a problem, then we solve it, and then finally we call ourselves 'The Problem Solvers'
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
- 1442 Views
Last post by jonesg
- 1302 Views
Last post by pshdars
- 12 Replies
- 2044 Views
Last post by PapaHepcat
- 998 Views
Last post by oragex
- 912 Views
Last post by regent
