Both ways...one way I strip it...
I suspect it's clockwise to remove due to counter clockwise rotation on pulley. But I can wait for an expert...
I'm amazed the Haynes manual has nothing on this.
Another problem...can't get IPD cam locking tool into position. It wants to go for 3 out of
4 prongs. If they had tapered the ends slightly it would work...
Timing Belt /Serpentine Belt Change In Progress Questions
1997volvo850
- Year and Model: 1997 Volvo 850
NcTrooper10722001
- Year and Model: 1998 850
Nothing specific on alldata.. seems to me that it would be a lefty-loosey.. Drive tensioners are usually the one with the bass-ackwards bolts when applicable..
NcTrooper10722001
I wouldnt hold my breath waiting.. when you can try it both ways and see which way it goes.. Ive been doin it 18 years and hasnt failed me yet..10-4
1997volvo850
I suppose you're right. If it were strange (right-loosey) then I suspect it would be mentioned in a lot
of places in red type.
With this group I'm usually talking about waiting only five minutes. Thanks.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
It's a Counter-clockwise bolt (to remove). No idea about that old grease, but I'd be inclined to leave it alone if it's anything like the old cans of stuff I find in my dad's garage.
'98 S70 T5
2016 Chevy Cruze Premier
- Been thanked: 504 times
No Timing Belt lasts 230K miles. I am sure it was changed at 100-120K or so.
If I were you, at 230K, I'd replace everything in that area!
- Timing belt for sure.
- Cam seals x2
- Crank seal x1
- TB tensioner + Pulley
- Idler Pulley
- Water Pump for sure.
For Drive belt:
- New Drive Belt
- New Tensioner and Pulley Combo
- New Idler Pulley
Items #2 and 7:
- Cam seals x2
- Crank seal x1
- Idler Pulley
For Drive belt:
- New Drive Belt
- New Idler Pulley
Items #2 and 7:
1997volvo850
[quote="cn90"]No Timing Belt lasts 230K miles. I am sure it was changed at 100-120K or so.
/quote]
I have a new OEM water pump, OEM timing belt kit, new auxiliary belt.
1) - Timing belt for sure. YES
2) - Cam seals x2 I'm new to all of this. I don't think I am knowledgeable enough to do the cam
seals and crank seals. I believe I need a tool to lock the cams when I have
things apart. Tell me how much the dealer charges and I may reconsider.
3) - Crank seal x1
4) - TB tensioner + Pulley YES
5) - Idler Pulley YES
6) - Water Pump for sure. YES
For Drive belt:
7) - New Drive Belt YES
- New Tensioner and Pulley Combo NO I don't believe this makes any noise. The roller turns smoothly. I was planning
to grease the roller as preventative maintenance. What about replacing just the
tensioner pulley? FCP Groton sells these (aftermarket) separately.
9) - New Idler Pulley NO This squeals a little. I was planning to apply grease and see if the noise
goes away. Other forums report success doing this. I would definitely
keep an eye (more like ear) on it.
I still have potential white smoke problem so doing too much now doesn't make sense if I can't pass inspection.
I am willing to revisit #2, #3, #8, #9 if car passes inspection. #8 and #9 should be easy.
Thanks for the feedback...
/quote]
3) - Crank seal x1
For Drive belt:
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
$500 for a TB job at the dealer? Maybe if you are married to them
Prices are usually upwards of $900.
1997volvo850
No response to my difficulties with getting the IPD locking tool on.
As noted in the picture in a previous post the marks were not perfect.
I'm wondering if this is why the IPD cam tool is not going in properly.
Should I remove the belt and move the cam slightly to install the cam tool?
- 21 Replies
- 5393 Views
Last post by viper69
- 692 Views
Last post by rspi
- 1092 Views
Last post by beigg
- 20 Replies
- 17710 Views
Last post by Hurtfeelings
- 22 Replies
- 36127 Views
Last post by erikv11
