Brake lag after starting
Apparently, that's his theory.
As expected the 25V gives the pump more power; however, the sound/surge of power makes me a little nervous.
Any thoughts on this sound?
2003 Volvo XC90 T6
2007 Volvo XC90 3.2 (Wifey)
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The fuse is there to interrupt the power supply in case of shorted wiring or excessive current consumption by components on the circuit protected by the fuse. The fuse is nothing more than a selectively sized strip of wire made of a metal alloy with a lower melting temperature. When the current exceeds the fuse rating by a small amount the metal strip melts.
Did the pump fuse blow? If the pump fuse was the reason the pump stopped then the pump may be faulty. Unplugging the pump and using a jumper lead for ground and using an ammeter for the power supply connected to motor wire and the other end to power source and checking the amperage while pump runs is the way to see if the pump is blowing fuse.
Fuses do not increase voltage.
The sound in the video sounds normal to me for one of those pumps. The sound quality of youtube videos heard over laptop speakers isn't the best so it may be worse sounding in person.
I am assuming your mechanic replaced the fuse and the pump now works.
jimmy57
OK,
What I do know without having seen your XC90: The vacuum switches that switch the pump on and off have been failing. Many that fail switch the pump on and off every few seconds and the vacuum pump gets hot and blows the fuse.
If it were mine I would replace the vacuum switch and see if the problems stops there.
I ordered the vacuum pump from ErieVovo yesterday. $85 w/ shipping not too bad.
Today while driving into work I got the following error codes:
P2178
P2180
My mechanic did mention that using the 25V could cause other issues-- or maybe it exposed other issues?
Any thoughts?
P2178
P2180
Any thoughts?
2003 Volvo XC90 T6
jimmy57
It is a 25 AMP fuse he used, not 25 volts.
The codes are for rich mixture off idle. Leakage between turbos and intake, intake leaks, MAF sensor, or faulty O2 sensor(s). are possibilities.
The air leakage you'd get from any of the vac pump plumbing would usually give you poor idle and lean codes at idle but it is possible. The leak on vac pump plumbing would give you a fairly easily heard hissing noise.
Leaks on the plumbing between turbos through hoses and intercooler and to the throttle is usually leakage only when under boost and results in the MAF sensor registering air mass that gives more injected fuel but the air is not there for combustion since it has escaped. O2 sensors report rich and ECM adjusts and reaches an adjustment percentage that triggers the code as it is out of normal range for the adjustment or possibly at the limit of the adjustment range.
Jimmy,
Thanks for clarifying the codes.
I just checked VADIS and didn't see any instructions for replacing the vacuum pump. Replacement seems fairy straightforward.
Has anyone replaced one of these before?
2003 Volvo XC90 T6
- 2172 Views
- 1217 Views
Last post by Homebrand
- 3373 Views
Last post by RussB
- 22 Replies
- 4080 Views
Last post by alexv702003
- 751 Views
Last post by PeterBagge
