I feel your pain. This was a multi week ordeal for me. I went thought the metal pipe URO crap and then went to brass. I also learned about filing down the square corner. I posted a pic of that I believe. I took a razor saw to the timing cover as you mentioned. Having that slight extra seal is not worth the pain. Besides, where I live, it hardly ever gets bad weather so there no dirty water or slush being flung into that area. When I took the belt cover off, everything looked practically brand new.
The final frustration for me was the length of the straight brass pipe. Another user used a shorter piece but I couldn't get that to work. I had to get a 1/2" longer piece before I could complete the job. I took off the housing at least 3 times.
I'm glad to say that several months and thousands of miles later, everything is holding up wonderfully.
t6 thermostat housing bleeder line
songzunhuang
- Year and Model: 98 V70 T5
- Has thanked: 2 times
- Been thanked: 30 times
Song Huang
1998 V70 T5 - Hurt your eyes red
2000 Honda S2000 - Berlina Black
1984 BMW 633CSi - Dolphin Grey
2024 Lexus - Eminent White Pearl
2004 XC90 T6 AWD Ruby red (RIP)
Biovince49
- Year and Model: 2001 S80
Bought one of the metal replacement bleeder fittings from e-bay. When received found it was too small to make a tight seal. Cannot remember how much smaller than original, but enough to not seal. anyway I scratched my head for awhile, and came up with a solution. Used small piece of 1/4" shrink tubing over the metal nipple to compensate. Greased it before installing, and all is well. Cannot break the metal one installing/removing the timing cover
songzunhuang
Interesting idea, but I'm wondering if heat shrink tubing will provide a watertight seal when the joint is under pressure and it heats up in a hot day? You'll have to let us know how it goes.
Song Huang
Biovince49
The heat shrink tubing is still providing a watertight seal after 2 months. I know it sounds like a hokey fix, but it worked.
Biovince49
Also want to mention there is not much pressure at this junction due to the small size of the hose.
Hope this helps someone with this issue. Was a quick and easy solution.
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Thanks for letting us know the longer-term result, sounds like a great fix for this sub-standard URO part, hats off to you!
- 1820 Views
Last post by kahl
- 14 Replies
- 3569 Views
Last post by ktuuri
- 2030 Views
Last post by F250
- 649 Views
Last post by Foursightho
- 2462 Views
Last post by cn90
