Yes, intake is pulling the exhaust.
Yes, exhaust shaft is turning. Sprocket is attached and not moving independantly.
OKay: Are you saying that as long as the marks are lining up consistantly I should NOT worry about the slack between the cams. That it will roll out with tensioner when i pull the pin?
That's so obvious... but i didn't want to release the pin prematurely and make things more difficult if i had to re-do...I am using a bungee on the tensioner to keep it taught. I know that is not the same. Plus, i think i just had this little step backwards. Well, that is good news...i'm a boob, but it is good news none-the-less.
When i go back i will check again to see that the bolts are centered in the sprockets. Recheck my marks...then pull the pin, and rotate CW to check.
i will report back.
i really appreciate it.
T
