Cylinder head removal
- Has thanked: 311 times
- Been thanked: 817 times
Be certain you get 6 point impact socket for the head bolts. NO 12-pointers allowed.
uniqueusername
- Year and Model: 2000 S70 N/A
way ahead of you, do you know how to take off the wierd clamps on some of these hoses?
uniqueusername
nvm, i just tore it off, oh well, i'll have to use a regular screw clamp i guess...
uniqueusername
Yay! i pulled the head!!! two noticibly bad exaust valves on cylinder 3, the rest look seated, but maybe a touch bent, gonna have to get my hands an a valve puller thingie tomorrow, only took 25 hours to get off!!!
- Year and Model: Many Volvos
- Been thanked: 76 times
My suggestion is to take the head to a machine shop where they can thoroughly go over it. It will run a couple of hundred dollars but a good machine shop will deck it and make sure all of the valves are right. This is a big enough of a PITA job that you really don't want to do it over.
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Nice job. You can drop some WD40 (or whatever liquid you like) behind each of the valves to gauge how well they are seating. Taking it to a machine shop is certainly prudent, but its very satisfying to do it yourself. You can measure the surface with a steel ruler or other straight edge to see if it is in spec. If not, then I would get the head surface skimmed.
Most of the valve spring tools you will come across might be for OHV rather than OHC, so be sure they give you the right one!
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
cjep
- Year and Model: 1998 C70 HPT
I just pushed it aside (i.e. towards the firewall). I did some of the bolting unbolting from the timing belt side, some from the exhaust side. It only moves a couple of inches, so you dont have heaps of room.uniqueusername wrote:@Clinton
oh my god, how did you get to the lower bolt on the water hose in the back by the exaust without totally removing the exaust manifold?
Good luck!
/Clinton
1998 C70 HPT - Saffran - Auto - 150,000 km
If you are in Brisbane, Australia, PM me. I would love to meet other volvo enthusiasts!
uniqueusername
Thank you guys for all your help, i really appreciate it! I would take it to a proper machine shop and get it looked over by professionals, but i have to do this on the cheap, but i have access to a machine shop if i need one, i just have to do all the work myself.
uniqueusername
OH! i was wondering what i should use to degrease the head and all the other oily bits, should i clean off the pistons, thay look gnarly.
uniqueusername
I got everthing together, and IT RUNS!!! I just want to thank everyone, for all their help.
- 2201 Views
Last post by precopster
- 13 Replies
- 8438 Views
Last post by lifeofgold
- 1446 Views
Last post by Squirk
- 1778 Views
Last post by SuperHerman
- 876 Views
Last post by lummert
