Dash and console lights (incl. radio!)
Add Justin's "every damn hose on the car"
Cargo cover in Wagons (Break!)
Brakes too weak/small
P-2 "Rain squeal" (Design flaw)
Assembling additional parts list for a new Failed Parts poll
- instarx
- Year and Model: XC70 T6 2011
- Has thanked: 1 time
spark plug ignition coil
front lower motor mount
upper motor mount
front brake caliper (not a wear item)
heater core
PNP interlock circuit
electric seat adjustment switch
driver side hood latch rubber pad (stopped popping hood open)
upper motor mount
heater core
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
odometer gear
trunk struts
heater blower motor 2X (bearing fail both times)
radiator 2X (same spot pass side tank interior 2/3 down)
ABS /TRACS
drivers side CV joint
strut mount 2X
ignition coil
crank sensor
trunk struts
ABS /TRACS
strut mount 2X
ignition coil
crank sensor
foresthump
- Year and Model: C70 2001
Brake booster check valve
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
1998 V70 T5 Original Owner; Current miles: 180,526
Drivers door-lock switch
Drivers passenger-window switch
ABS module (I fixed)
Pass side wheel bearing
Both front spring seats
Upper torque mount
Lower engine mount (at crank)
Heater Core (soon...)
AC Evaporator Core (very slow leak)
Drivers side door check
Power steering rack (@ 70k mi)
Alternator
Rear Pass-side light switch
Vinyl separating from Driver & pass door panels-eco glue (both already replaced once all ready)
Both sway bar links
Emissions Air pump
Leather covering on front seats badly cracking
Rear Washer Pump
Front Washer Pump
Coolant expansion tank (3x)
Coolant tank cap
12v Battery (3x or 4?)
Radiator
Interior tailgate panel mounts
Electrical emission vac valve on fan shroud (Evap valve)
02 sensor
Tailgate strut
Front brake hoses
All vacuum hoses
PCV System
Turbo oil cooler lines
Key Fob Housing
CV boots
Vac system check valves
Upper torque mount
Alternator
Both sway bar links
Emissions Air pump
Rear Washer Pump
Front Washer Pump
Coolant tank cap
Radiator
02 sensor
Tailgate strut
Front brake hoses
All vacuum hoses
PCV System
Key Fob Housing
CV boots
- LamboSE5
- Year and Model: Empty
HAHAH, Hilarious!jblackburn wrote:Every stupid freaking hose in the entire stupid car.
and, if timing belt (consumable) is being taken off the list...I wonder about other 'associated' parts? What about the tensioner pulley and stuff...Consumable too I guess. I think I remember that (the mechanical type anyway) is supposed to be changed at the same interval as the belt? In a 70 series/850, no?
Antenna mast (I've seen one that works)
Power Window Module (main)
ABS module
PNP switch (automatic)
...are some my failed parts.
c70_lindsay
- Year and Model: 99 S70 T5.
2000 C70 between Feb of last year (167,000km) to now (194,000)
Ignition lock cylinder
abs module
passenger window assembly (ten cent plastic cable roller failed destroying a $600 window assembly)
drivers window switch
fuel door latch or interior switch( haven't looked at it yet)
suspect wheel bearing going( will update)
abs module
Power seat cable
Windshield washer tank
Ball joints
Heater core lines
Steering wheel, top part unglued
Shifter unlock button, the little one at the base of the shifter
Seat belt release
Center arm rest release
Ball joints
Heater core lines
Seat belt release
- 428 Views
Last post by JimBee
- 1333 Views
Last post by greg850r
- 2001 Views
Last post by volvolugnut
- 710 Views
Last post by erikv11
- 392 Views
Last post by jaywats
