Assembling additional parts list for a new Failed Parts poll
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Please look at this list, then add parts that have failed, meaning parts that have actually broken or failed.
What we don't want are consumables like struts, windshield wipers, tires, etc. Those are meant to wear out, and expected to be replaced.
The following are the 22 items we have in the current poll. At that time, I was limited to 22 items. Now I can up to 100.
This topic is not the new poll, only the harvesting of parts that should have been in the current poll. After a few weeks, I'll take your additions that you add to this topic and make a new topic with a new Failed Parts poll. It will be much better, more complete, obviously. I'll do the same for the other forums, including Volvo V70, XC-70, S60 (2001-2010), Volvo S80 Forum, Volvo XC90 Forum, Volvo V70 Forum, XC70 Forum (2008+) Forum, and maybe the rest.
If you have suggestions on breaking some of the current ones out into two or more, please speak up.
Please don't list anything you'd find in a Volvo's maintenance schedule. We've got to draw the line between consumables and everything else, so let's use maintenance schedules as the "yardstick".
Ok, all that said, please fire away. Please list your items on their own line, like this:
Radar dish
Missile launcher
Torpedo loader
So far we have:
  • Timing belt [I'm going to remove this because it's a consumable]
  • Top engine mount bushing
  • Thermostat
  • Door check strap or hinge
  • ABS module
  • Rear main seal
  • Wheel bearing
  • AC evaporator
  • ETM
  • Battery cable
  • Any keyless entry component
  • Any interior switch
  • Camshaft position sensor
  • Fuel pump or relay
  • Heater core/ blower / resistor
  • AWD's driveshaft or bevel gear
  • Power antenna
  • Sway bar links
  • Mass airflow sensor
  • Air pump
  • Glovebox lock
  • Head gasket
Also -> Amazon link
Jono51
Year and Model: V70XC, 1999
Post by Jono51 »
ignition coil pack (the one per spark plug kind on the later cars) - or do you consider these a consumable?
If God had meant cars to have fuel injection, he never would have given us the SU carburetter
matthew1
Site Admin
Post by matthew1 »
Perfect. I have little reason to suspect those are considered consumables. Thanks.
Also -> Amazon link
Fish stick88
Year and Model: 1994 - 850 Sedan
Post by Fish stick88 »
Does defroster plate count? mine cracks more every time I hit a bump.
Also, heated seats,
Window buttons/(main module)
Spring seats.
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
power door locks
emergency flasher
engine mounts
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Front motor mount (near the crank).
Door lock latches.
Antenna mast.
Interior light dimmer.
Cruise control linkage at the gas pedal.
Throttle control linkage at the TCV.
Turbo oil cooling line at the radiator.
Coolant expansion tank cap.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Every stupid freaking hose in the entire stupid car.
'98 S70 T5
2016 Chevy Cruze Premier
Ben850
Been thanked: 7 times
Post by Ben850 »
Right front, lower motor mount (icon photo)
Shift-lock microswitch.
console armrest.
Airguide/Skidplate.
Exhaust hanger.
trunk lid dampers
dash pad.
Speakers.
I've done more, but it escapes me right now. I've done almost everything on the original list as well.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
On my now sold burgundy 850 '95 wagon:
New ignition switch (genuine from FCP)
A/C pressure switch at firewall
lower crank side engine mount
Receiver-drier for a/c
and a lot of other consumables which hadn't been done for a while. Must say though she was a very sweet ride and I miss her now!!
fazool
Year and Model: S60, 2007
Post by fazool »
Center hood latch extension lever
Grill retaining clips
Cloth Seat Covers
Dash ungluing
Headliner ungluing
Door panel ungluing
Power antenna (internal toothed cable)
A/C clutch/compressor
2007 S60 2.5T AWD (Daily Driver)
2001 S60 2.4T (Daughter's Car)
2003 S80 2.9 (Son's Car)
1995 850 2.4 (Daughter's Car - sold off)
2005 S40 2.4i (Bought new - since sold)
1986 740GLE 2.3(First Volvo - sold off)
