Boost Gauge Install
This topic is in the MVS Volvo Repair Database » Boost Gauge Install DIY
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Heck, I might get a cluster frame from the salvage yard and drop it in there between the current turbo gauge and the left turn signal. Wait, I have a cluster already torn apart. Maybe I'll try there. I was going to install in in the speaker mesh on the dash near the A pillar.
mecheng
Year and Model: 1998 Volvo S70 T5
Has thanked: 15 times
Been thanked: 21 times
Post by mecheng »
Great pics guys. Ok, so I found the pass through (pretty neat) and figured a way to fish the hose up to the A-pillar. I will be going with a Pod mount, I think it looks the cleanest.
My question is for those with a 1998 S70; where did you tap in the boost line. On the 850s I assume you guys put a tee on the existing line for the boost guage, but the S70s didn't come with a boost gauge.
I was thinking of the tree for the IACV, but the line is smaller. I've read that you should put a hole in the rubber caps and feed the line through. I don't see how that will seal properly, it doesn't seem right. Maybe some kind of adapter to feed the line directly into the tee?
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
mecheng
Post by mecheng »
Also, has anybody compared the IPD pod to the one you can get at Gauge Pods? Are they the same?
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
Here's mine. The pod was for a Honda IIRC. It required some sanding for fit. It's held with a 2-part epoxy to the A pillar plastic. B+ for the light is tapped of the light switch and it only comes on when the lights are on, and is controlled by the dimmer.
I got it from Summit Racing, and chose it because it visually "matched" the Volvo dash lettering and colors
'00 S70, '04 S60 and the never ending quest for Stage Zero
rspi
Post by rspi »
mecheng wrote:My question is for those with a 1998 S70; where did you tap in the boost line.
The instructions that came with my gauge said to tap into the vac line from the boost controller into the air intake tube (from the MAF to turbo). So, that would be the blue line from the TCV.
rspi
Post by rspi »
Installed the boost gauge today, took me about 2 hours to do the 30 minute job.
Has thanked: 1610 times
Been thanked: 4071 times
This install is incomplete without a synthesized
"Whoop whoop.....overboost!!"
Accessory.
mecheng
Post by mecheng »
micah861 wrote:Turns out it was the pink wire. My connector can come apart and fold on the side (see picture) which makes it alot easier to connect the new wires to the original without cutting them.
Then put the gauge cluster up, and ta-dum!
Does the pink and black wire come free of the connector. I can open it on the side as well but I'd like
It to come free so I can solder it to the upper female plug
rspi
Post by rspi »
Hey, this was my 5000th post. Woo hoo! Check in the mail. ;)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
I send them at 4999 ;-)
Guys, put the gauges where you can see them while you're driving. I'm not criticizing anyone's placement. I don't know your height or seating position. Just saying.
Also -> Amazon link
