Parts failure poll: P2 Volvos: V70/S60/XC70 from 2001-2007
This topic is in the MVS Volvo Repair Database » Failed Parts Poll for P2 Volvos
What has failed on your P2 Volvo: V70/S60/XC70 from 2001-2007?
abs module
62
1%
ac compressor
62
1%
alarm system
126
3%
alternator
86
2%
axle shafts
95
2%
blower motor
66
2%
brake cylinder position sensor
18
0%
brake master cylinder
22
1%
broken ignition lock
26
1%
cabin switches
30
1%
catalytic converter
30
1%
cem (central electronic module)
33
1%
center console cover
65
2%
center console cup holder
62
1%
climate control fan
29
1%
climate system (including software upgrades)
26
1%
control arm bushings
177
4%
delaminated shoe on the parking brake mechanism
54
1%
discolored roof trim strips
113
3%
door whether strip
56
1%
engine cooling fan
29
1%
etm (electronic throttle module)
85
2%
exhaust flex down pipe
20
0%
exhaust pipe hanger broken (rusted, etc)
91
2%
front strut mounts
161
4%
front struts
146
3%
front window mechanism, slider or switch
76
2%
fuel pump
66
2%
fuel door hinge
123
3%
fuel door latch (not hinge)
84
2%
fuel tank pressure sensor
16
0%
headlamp ballasts (volvo calls them "Control units")
13
0%
headlamp leaky seal
38
1%
ignition coils
115
3%
ignition key failure (key replacement, programming)
13
0%
immobilizer antenna (start prevented error)
15
0%
lower ball joints
104
2%
lower torque rod
48
1%
oil sump seals
20
0%
other cup holder
28
1%
oxygen sensors
66
2%
parking brake cable
26
1%
passenger airbag sensor
6
0%
pcv system
123
3%
premature lightbulb/bulb socket failures
119
3%
radiator leak
79
2%
radio display
34
1%
rear view mirror
59
1%
rear bearing housing ("Knuckle")
6
0%
rear latch mechanism
27
1%
rear main seal
19
0%
seat controls cover
15
0%
seat motor
5
0%
siren control module
86
2%
spring clip to hold head light bulb
9
0%
spring seats
48
1%
steering rack
31
1%
steering wheel
4
0%
steering wheel controls
3
0%
sway bar links
135
3%
the turbocharger (whole thing)
17
0%
tie rods
128
3%
transmission (including software upgrades)
100
2%
transmission mount
93
2%
turbo valve
21
0%
turn signals
45
1%
upper engine mount
215
5%
vacuum pump/vacuum switch
18
0%
vvt solenoid
37
1%
water pump
29
1%
wheel bearings
98
2%
yaw sensor (anti-skid service required)
18
0%
Total votes: 4248
tomvv11
Year and Model: 2002 XC70
Post by tomvv11 »
That's not much wrong, and pretty minor, for 156K and 13 years. I've twice had crappy clunky downshifting, which both times went away with thorough fluid maintenance.
Vovo_merz
Year and Model: 2007 s60R
Post by Vovo_merz »
I had to mark all the things I had to fix wasn't all my cars some of customer/friends/family cars but totaled out to 35 options
1995 - 850 1st
1995-97 - 850 R 3 Black, Red, Yellow
2000-04 - $40 (4)
2005-06 - $80 (8)
2001-09 - $60 (38)
2005 xc90 (2)
2001 xc70 (wifes first car)
2001-07 v70 (5)
2007 $60R (2)
2008 XC90 sport V8
1998 Merz $500 custom
2009 Merz $550
2013 chevy 2500HD
Mike T
Year and Model: 2003 XC70
Post by Mike T »
Hi All. Add starter to the list. We have replaced 2 so far.
Cees Klumper
Year and Model: 2002 S80 T6
Has thanked: 46 times
Been thanked: 33 times
Post by Cees Klumper »
4 of them in 200K miles. Very happy with the car.
BigNerd
Year and Model: 2004 XC70
Post by BigNerd »
I put it down as axle shafts, but I had the front CV on my propeller shaft fail. It's the front/rear driveshaft on an XC. Its failure was bizarre, the symptoms were EXACTLY the same as upper strut bearings. I only discovered the issue by changing the front struts and strut caps and being surprised that the problem persisted.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Twice now the front windshield wiper mechanism on our '04 V70. I don't see a way to add it to the poll.
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Passenger airbag sensor on mine started working better when I used a proper/suitable conditioner for the leather (vinyl coated) seats. Once the vinyl coating/upholstery softened back up the airbag disable behavior has been consistent and appropriate. Knock on wood.
Has thanked: 1610 times
Been thanked: 4067 times
Bought my P2 from Jim at 80k miles
Now at 110k. 32 mpg. Quiet and smooth as a tomb.
Did timing belt at 105, oil changes, filters
williamj1
Year and Model: 2001
Post by williamj1 »
I just had my 2001 v70 cx trans rebuilt,transmission kept shifting hard and still did the same thing. i went to the junk yard and pick up 2 transmission sensors, shifter selector (mounts on top of trans), after that transmiossion shifts smooth 30t045 mins it shift down really hard so not sure what todo now i also replace the tcm. help
williamj1
Post by williamj1 »
