Volvo Noob with Ignition Issues
gillette
Year and Model: 1999 S70
Re: Volvo Noob with Ignition Issues
Post by gillette »
Worked!! Thank you very much! I ran the wire between the two pins and it started up, idled great and had throttle response. I cleaned the old relay and put it back in and it started and died so this must be it. I am going to go get a new one now.
Thanks everyone for your help.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Glad you found the problem.
Sorry for the run-around at first, but usually a fuel pump relay issue rears its ugly head when the engine is already hot and going down the road or something.
Our Saab died in the middle of a busy intersection when I was younger from the same issue - not a fun memory trying to push the car out of the way!
'98 S70 T5
2016 Chevy Cruze Premier
gillette
Post by gillette »
Well I was on the way back from Delaware and had driven close to 2 hours already and had just stopped for gas so maybe that makes sense now. It is not a problem at all! Thanks all for the input.
Does anyone have any comments on the question I had about the ETM not closing fully? Should it have a gap on the bottom when at rest like that?
Thank you
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
There's an entire forum section
here at MVS dedicated to ETM's.
You may find an answer there.
https://www.matthewsvolvosite.com/forums ... m.php?f=12
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
There should be a small gap, I would look at moving the throttle flap with your fingers and cleaning off the carbon near the spindle as this can cause it to stick further open than it should do - Mike
